SCS SR8 wheels 16x8 & 17x8.5
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, Jan 8, 2015.
  1. Oct 27, 2015 at 10:48 AM
    #581
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    Awesome! Thanks for all of the help and great looking truck btw!
    Bsheriff11[QUOTED] likes this.
  2. Oct 28, 2015 at 3:28 PM
    #582
    drknsurfur
    drknsurfur Well-Known Member
    Nick
    Port angeles, Wa
    2008 Silver TRD Sport S/C
    there are 16" stealths? i thought they only come in 17s
  3. Oct 28, 2015 at 3:44 PM
    #583
    NV_Tacoma
    Paul
    Northern Nevada
    The SR8s and F5s come in a 16" wheel, the Stealth 6 only comes in a 17" wheel.
  4. Oct 29, 2015 at 1:47 AM
    #584
    Upsblaine
    Upsblaine member
    Blaine
    Mills, HI
    2012 MGM DC 4x4 TRD SPORT
    Pelfreybilt color matched front bumper, Baja Designs S8, TRD supercharger w/ URD pulley, King coilovers w/compression adjusters, King Resi shocks w/Dakar leaf pack, Total Chaos Uniball UCA, Wheelers Superbumps, ToyTec flip kit, CMC, SnugTop supersport w/BedRug, Murano Retrofits (ambiguous) + Vled V3 switchbacks Amber/Amber, Frontrunners rack, red extended brake lines (OCtaco), 16x8 SCS SR8 wheels w/ 285/75/16 Goodyear MTRs + spare, AFE CAI + (Coupe) cover, TRD catback exhaust, TRD Pro Grille, TRD Japan Oil cap, TRD Radiator cap, TRD shift knob, Pelfreybilt battery tray + Diehard 31M, Fumoto qwikvalve, Viair10007 Constant Duty OBA, Redline hood struts, Rigid SRM + B.A.M.F mount, WeatherTech DigitalFit & Deflectors, BlueSea fuse panel mod, Ottraw switches, (ImMrYo) mirror bracket, (Matt123) recovery shackle bracket, B.A.M.F bolt on sliders, Wet Okoles, Factor55 Hitchlink, Rigid Sr-Q, Diff Breather Mod, pop&lock pl8521, 2013 touchscreen head unit, (BeeRadd) PRO kit, (Mattgecko) Bedlight kit. Hilift w/ ATO mount, V2W Flyzeye, BlackVue DR600GW-HD, Kleinn Train Horn, IAS 10lbs CO2 tank. Coming Soon. ..Speedhut gauge, PLX gauges, ARB compressor
    Does anyone know the part number for the TRD center caps that would work with the SR8s?
  5. Oct 29, 2015 at 3:50 AM
    #585
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Look at Trdparts4u, under TRD wheels, the caps should be in there. Or just look up TRD beadlock caps on Amazon
  6. Oct 30, 2015 at 1:16 PM
    #586
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    This is the part number that you want: PTR18-35092
    angeldavid216 likes this.
  7. Oct 30, 2015 at 1:57 PM
    #587
    Upsblaine
    Upsblaine member
    Blaine
    Mills, HI
    Ordered. Thanks
  8. Oct 30, 2015 at 7:32 PM
    #588
    tacomgee
    tacomgee just ain't care....
    Blake
    NorCal - Ukiah
    2009 DCLB SAS in the works
    Picked up a set of stealth 6s for my buddy's truck today. Can't wait to get my sr8s when they come in. Thanks again Vin!
  9. Nov 8, 2015 at 4:55 AM
    #589
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    This seems like the best place to ask. I'm looking to run the SR8s with a 265/70/17 KO2... Aside from the front air dam needing to be removed should I expect any rubbing? I know with stock wheels people are saying no problem but these have a different BS.
    If it matters will have a 2.5" lift 5100 & 885
  10. Nov 8, 2015 at 4:59 AM
    #590
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    I don't think you'll have problems with rubbing.
    With 285s for sure you'll rub
  11. Nov 8, 2015 at 5:11 AM
    #591
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    Ok thanks! 285s are tempting but at least for now it's more of a DD / weekend warrior and didn't want to hit the MPG too hard or get into a load range above C.
  12. Nov 8, 2015 at 6:20 AM
    #592
    Alfred
    Alfred
    California
    You'll regret not going with 285s. They all do! Lol :)
    asudevil likes this.
  13. Nov 9, 2015 at 6:27 AM
    #593
    Jhunter
    Jhunter Well-Known Member
    Atlanta
    Black '14 TRD DCSB
    Just getting started
    This may help a few with questions about the mud flaps... I'm running the 17" x 8.5" SR8s with a 265/70-17 Handkook AT tire (stock suspension). The tire rubbed the mud flaps in the front when going 'lock to lock'. I wanted to keep the flaps in order to keep the quarter panels from getting nicked up. I did two things. First, I cut about 4" off the bottom of the mud flaps (mostly a looks issue). Next, on the Front flaps, I took a dremel tool with a cut off wheel and cut the top of the mud flap off. I did this on the truck. I ended up cutting off a section where it bolts to the inner fender panel. In doing so, you loose some support so I drilled a two small holes through the flap and the inner fender about 1/2" apart. I then took a Black zip tie through the holes to secure the flap from flopping around. Both sides took about 30 min max.
  14. Nov 9, 2015 at 2:31 PM
    #594
    Fire252fighter
    Fire252fighter The guy that comments every now and then
    Pittsburgh pa
    09 sr5 tacoma
    Nothing
    Had the same issue on my last truck. 09 acc cab. Once I lifted and had 285's on aftermarket wheels I noticed it. Spent days trying to figure out if it was a incorrect lift install then to the dealer nobody knew... Eventually looked at bed alignment taking a string down the body on each side and relized the bed was shifted about 3/4" bought torx tip and loosened bed bolts realigned and tightened it up. Prob solved.
    Just wish I saw your post before to help sooner.
  15. Nov 9, 2015 at 6:24 PM
    #595
    iK0NiK
    iK0NiK Insert custom title here.
    West
    Columbus, GA
    2015 DCSB V6 TRDOR 4WD
    Bil 6112/5160's etc.
    Hey, thanks for the info Mike! I'll pull some measurements next time I'm at the shop to see if the same thing is going on with mine.
  16. Nov 9, 2015 at 6:38 PM
    #596
    tacomgee
    Blake
    NorCal - Ukiah
    Picked mine up today. All black everything. Cant wait to get new tires and get them on!:Dimage.jpg
  17. Nov 10, 2015 at 6:17 AM
    #597
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    I want in take my money lol. @SCSPerformance I sent you a pm with my paypal. The wheels have been discussed in that same pm.
  18. Nov 10, 2015 at 6:35 AM
    #598
    drase
    drase Well-Known Member
    Winter Haven, FL
    08 PreRunner SR5 TRD Sport Access Cab
    Just paid for mine, also all murdered out. Never been so happy to spend this much money!!! Thanks Vin!
  19. Nov 10, 2015 at 6:47 AM
    #599
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    Looking at getting your SR8 in a 16" size and wonder how they will sit in relation to my fenders. How much will they stick out? I had some 1.25" Spidertrax spacers on my truck and took them off. Not because I didn't like the look but because I couldn't justify the cost for the look, especially knowing I could use that money for my SR8s.
    Using your quote above, can you give me an idea as to wether or not I would be looking at the same look as a 1.25" spacer on my factory wheel, or would it look more aggressive.
    BTW, I can't believe how reasonably priced your wheels are. Nice job on price point, looks, and quality. I think you guys have a winning formula. Can't wait to get mine in the spring.
  20. Nov 10, 2015 at 6:49 AM
    #600
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    Nice work! Truck looks awesome. Makes me wish I had gotten MGM instead of white...
