SCS Stealth 6 wheels 17x8.5
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, Sep 9, 2012.
  1. Jun 27, 2013 at 7:30 PM
    #941
    acdronin
    acdronin Well-Known Member
    Thanks guys, I'm so stoked to finally get these on my truck:)
  2. Jun 27, 2013 at 7:37 PM
    #942
    dand
    dand You can't see me
    Dan
    SE VA
    TRD Tundra DC 4x4 Blue Ribbon M.
    Planning stage
    :headbang: very nice..^^^^^
  3. Jun 27, 2013 at 9:25 PM
    #943
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    Cant go wrong with black on MGM, i went with gloss black, pictures in my build
    Looks awesome!
  4. Jun 27, 2013 at 9:32 PM
    #944
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    I've seen BAMFer....:p
  5. Jun 27, 2013 at 10:18 PM
    #945
    Hairy Taco
    Hairy Taco Bush Pusher
    Manitoba
    08 TRD
    5100's, Eibachs, ome dakar, spc lr uca, Homertaco Satoshi, Andres horns, ImMrYo, Yakima, Thule, Torza Top, weather tech's, oem bed mat and divider, SCS stealth6, 33"rubber, bird turd's and dirt nugs
    Nice. That is a serious rack you've got on there. What are you putting on it?
  6. Jun 27, 2013 at 10:28 PM
    #946
    acdronin
    Thanks!
    Thanks!
    lol
    It's a Rack-It lumber rack, sucker weighs about 250 lbs, I have loaded 800-900 pounds of lumber on there, most of the time though it's lighter amounts of lumber and PVC pipe.
  7. Jun 28, 2013 at 6:44 AM
    #947
    acdronin
    I thought I'd post these, these are the balance numbers on three of the wheels/tires (the fourth was just as good but i didn't click a pic), to give you a perspective, these are Vin's rims with new Terra Grapplers, my last set was Wrangler AT/S's on the Sport alloys and those numbers where in the 3.5 to 6 range. Granted different tires and the tires have a lot to do with it but, these wheels are very well balanced, very well built. Nice work Vin!
  8. Jun 28, 2013 at 7:23 AM
    #948
    916 YATES
    916 YATES Well-Known Member
    Brian
    Sacramento
    2010 DCLB Grey TRD Sport
    emblems and decals removed, added TRD special edition badges, Sway A Way's front and rear, SCS stealth 6's, Toyo A/T II 265/70/17
    Truck looks great with the Stealth's and Nitto's. A great deal on both. How do you like the way it drives now? I really like the wider stance they provide. We spun one of Stealth 6 wheels with out a tire--0.00. Seems most of the balancing is the tire and TPMS sensors.
  9. Jun 28, 2013 at 7:35 AM
    #949
    acdronin
    Thanks!
    Exceptional, my first impressions are, compared to the Wrangler AT/S's, (which had a much harder compound and stiffer sidewalls), these Nittos ride much smoother than I thought for an off-road tire, very quiet and smooth. The AT/S's where 275/70/17's so these are a little bit narrower and shorter overall, but the backspacing on the rims is 2.20 more than the stock rims, the combo looks more proportionate than the old set up. I was kickin around going for 285's but the need for some additional trimming and MPG's where against that. The look is a tid bit shorter but wider which looks way cool. I saw a lot of these tires up at the OR dunes so I'm excited to try them out up there. Chris 4x4 called me this morning, he said I shouldn't have to air down as much as I did with the AT/S's which was 25 PSI, I have the Nitto's at 40 PSI right now which is a tid bit high, but when I go to OR and the end of July I'll play with the PSI to find the sweet spot.
  10. Jun 28, 2013 at 7:38 AM
    #950
    acdronin
    Glad you spun one with out the tire, I didn't think of that, yeah, most of it is the tire and the TPMS, the Nittos have a little yellow mark to tell you to position that mark where the stem is.
  11. Jun 29, 2013 at 8:03 AM
    #951
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    Cali
    MGM 2012 4x4
    Icon stage 2 kit, LR UCA, SCS wheels wrapped in 33s,
    Here is an updated photo I recently took with the new suspension and tires/wheels.
  12. Jun 29, 2013 at 8:21 AM
    #952
    Hairy Taco
    Manitoba
    08 TRD
    ^^lookin great man. Do your tires clear the cab mount?
  13. Jun 29, 2013 at 8:54 AM
    #953
    916 YATES
    Brian
    Sacramento
    Here is an updated photo I recently took with the new suspension and tires/wheels.[/QUOTE]
    Truck looks mean. Good photo, where is that at? Nevada?
  14. Jun 29, 2013 at 8:55 AM
    #954
    acdronin
    Truck looks mean. Good photo, where is that at? Nevada?[/QUOTE]
    That looks like the Mono Lake Basin to me
  15. Jun 29, 2013 at 12:54 PM
    #955
    meantaco
    meantaco Well-Known Member
    Andres
    2005 Prerunner. Gone,but not forgotten.
    Retrofit,bull bar,hellas and color matched grill.
    bump for the sneak peek
  16. Jun 29, 2013 at 5:16 PM
    #956
    BBtacosurfer
    Dave
    Cali
    MGM 2012 4x4
    Yes sir! Did the cab chop and hammered the pinch weld like a mofo. Trimmed a bunch of the fender and there is no rubbing.
  17. Jun 29, 2013 at 5:17 PM
    #957
    BBtacosurfer
    Dave
    Cali
    MGM 2012 4x4
    That looks like the Mono Lake Basin to me[/QUOTE]
    Damn you are good...It's actually just outside of Mammoth Lakes :D
  18. Jun 29, 2013 at 5:18 PM
    #958
    acdronin
    Damn you are good...It's actually just outside of Mammoth Lakes :D[/QUOTE]
    I was close!:D
  19. Jun 29, 2013 at 5:31 PM
    #959
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    After some time whoopin' up on 'em, I can say these wheels stay away from rock rash very well because of the recessed design.
    Only the rim by the bead takes any abuse. The rest looks pristine. Very welcome to us frequent-wheelers.
  20. Jun 30, 2013 at 7:35 PM
    #960
    BBtacosurfer
    Dave
    Cali
    MGM 2012 4x4
    One more pic to slut out my truck for the time being. Loving these wheels Vin!
