SCS Stealth 6 wheels 17x8.5
Discussion in 'Wheels & Tires Marketplace' started by SCSPerformance, Sep 9, 2012.
  1. Dec 9, 2013 at 12:52 PM
    #1301
    SCSPerformance
    SCSPerformance [OP] Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Matte Black custom paint
  2. Dec 9, 2013 at 1:17 PM
    #1302
    Hairy Taco
    Hairy Taco Bush Pusher
    Manitoba
    08 TRD
  3. Dec 9, 2013 at 1:27 PM
    #1303
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Scott has matte gunmetal;). Low lighting makes them almost matte black and in direct sunlight, you get a nice charcoal shade.
  4. Dec 12, 2013 at 10:06 PM
    #1304
    FlintsTaco
    FlintsTaco Member
    Tropix
    Sonoma County
    2013 Silver 4x4 Sr5
    20% Tint all Around Bilstein Adjustable lift kit with 5100 shocks LR UCA BAMF Cab Mount Chop MagnaFlow Exhaust 1.5 TSB AAL + 1" Block U-Bolt flip Kit
    Has any body ran the stealth 6 wheel on a 33" tire with out a CMC?
    I have a 3" lift and LR UCA.
    My truck only has 4500 miles on it and the only thing keeping me from going with this rim is cutting the shit out of my truck!
  5. Dec 13, 2013 at 2:31 AM
    #1305
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    There is alot of factors when it comes to the CMC, and because of that no one can give you a yes or no answer, so IMO i wouldn't go with 285/70/17 or anything bigger if you absolutely do not want to cut. I am sure there are plenty of guys who have these wheels and did not have to do the CMC, i had to cut right away. My setup when i first got the wheels: OME 885s and nitros, no top plate spacer, about 2.5" of lift (23" hub to fender) light racing UCAs set to add 2 degrees of caster (this increases chance of rubbing) duratrac 285/70/17. I was hitting the body mount at full turn during regular driving. Since you already have the suspension done check to see how much clearance you have right now. If you have your heart set on 285s just do it, its worth the cutting, this tire size looks badass on these wheels.
  6. Dec 13, 2013 at 4:11 AM
    #1306
    nj636
    nj636 Hub Master General
    Kev
    Jersey
    OME lift 4x sliders 4x skids
    Besides a CMC you will likely be cutting the inner fenderwell & fenders with 285's
  7. Dec 13, 2013 at 6:14 AM
    #1307
    Sfearl1
    Sfearl1 Active Member
    Stl, MO
    07 TRD SR5 4x4
    Stock
    I have 285/70/17 duratracs and only had to trim fender liners and a small part of the fender (minimal). I rub reversing out of my driveway at full lock. That's it though. I'm running 5100's and an Icon AAL.
  8. Dec 13, 2013 at 6:21 AM
    #1308
    Hairy Taco
    Manitoba
    08 TRD
    stock uca's?
  9. Dec 13, 2013 at 7:16 AM
    #1309
    Sfearl1
    Stl, MO
    07 TRD SR5 4x4
    Stock
    Yes.. adding LR UCAs after Christmas.
  10. Dec 13, 2013 at 2:37 PM
    #1310
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Kevin and Evan are correct. When stepping up to 33s, I always like to recommend the CMC mod just for the extra clearance when the suspension is flexed out. Along with that, some minor plastic trimming is also necessary.
    You have to keep in mind that this rule basically applies to most wheels wen you're going up in size. Typically, a highway or an all-terrain tire will rub less than a comparable mud-terrain tire so a lot of actors come into play.
    As far as the CMC mod goes, it's far from cutting the crap out of the truck. If done right, it's barely noticeable and very stock like.
    Jerry from BAMF sells precut plates that makes the job a breeze. A decent welder can get it done under an hour. Here's some reference photos that I helped a friend do on his truck.
    http://www.tacomaworld.com/forum/ba...-cmc-plates-cab-mount-chop-4.html#post4601098
  11. Dec 13, 2013 at 2:57 PM
    #1311
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    13 4x4 DCLB tacoma V6 TRD Sport
    5100 Bilstiens set at 1.75, progressive leaf pack, BFGs, All-Pro rear Bumper(white), Storm troopered out
    Do you think the OEM wheels will fit on these rims. I currently have the Dueler H/T 684 II.
  12. Dec 13, 2013 at 3:10 PM
    #1312
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    Factory tires will fit on there without any issues. The decision to design this wheel at 8.5" wide is so that owners can use the factory size tires if they choose too.
  13. Dec 13, 2013 at 3:21 PM
    #1313
    Jhodgman
    Jhodgman ...
    Justin
    So Cal
    Perfect, There pretty cool lookng, I know ill get them eventually hopefully from that give away you guys are doing. if not maybe in a few years when i can save up the cash.
  14. Dec 13, 2013 at 3:32 PM
    #1314
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    :cheers: and good luck to you in the contest!!!
  15. Dec 14, 2013 at 12:52 AM
    #1315
    tn2012taco
    tn2012taco Well-Known Member
    Nathan
    Nashville, TN
    '12 PreRunnin Trooper
    Plasti-dipped wheels, Bilstein 5100's @ 1.75, 1 in. block in rear, CB in center console, 12V outlet in console, weathertechs, N-FAB wheel-to-wheel 3in. tube, Action packer cheap toolbox, Spidertraxx 1.25" spacers, Kensun 5000K in fogs, K&N drop-in filter, foglight anytime mod, Anytime Panty-dropper mod.
    Are there any well lit photos of gunmetal on a super white? Trying to decide between matte black and gunmetal and just haven't seen any good pictures.
  16. Dec 15, 2013 at 5:31 PM
    #1316
    Rustbucket
    Rustbucket God Bless America
    Garrett
    Bay Area
    06 V6 Access Cab SR5 Manual in Speedway Blue
    Good lord I love these wheels. Got mine on with the 35s last night and threw on my stealth customs vinyl
  17. Dec 16, 2013 at 7:23 AM
    #1317
    HHogrider
    HHogrider Well-Known Member
    Mark
    Lexington, KY
    11 Tacoma Sport Pyrite Mica
    Tint, ARE Z-Series Cap, Yakima rack on cap, ROLA basket, SCS Stealth 6 Matte Gunmetal with full size spare, 285 Terra Grappler, OME lift (885's with Top Plate Spacers, full DAKARS, Carrier bearing drop, stainless extended rear brake lines, BORLA cat back exhaust, color matched All-Pro rear bumper
    Awaiting other mods. Factory tires fit great...
  18. Dec 16, 2013 at 8:04 AM
    #1318
    Sfearl1
    Stl, MO
    07 TRD SR5 4x4
    Stock
  19. Dec 16, 2013 at 8:21 PM
    #1319
    SCSPerformance
    Vin
    Bay Area, CA
    2005 Tacoma
    You guys are posting some amazing pictures. Thank you so much for posting and for helping out one another here with the questions.
    tn2012taco, unfortunately, I do not have any photos of matte gunmetal on white.
  20. Dec 16, 2013 at 9:23 PM
    #1320
    wrmathis
    wrmathis Dark Lord of the Sith
    Ryan Mathis
    Lives: Fountain, Colorado/Home: Leesburg, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Here is a better pic of mine without the blue tape
