SCS WHEELS WRONG BORE
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rigz22, Dec 22, 2022.
Thread Status:
Not open for further replies.
  1. Dec 22, 2022 at 4:19 PM
    Rigz22
    Rigz22 [OP] Well-Known Member
    California
    2019 tacoma sport 4x4
    I purchased some
    Blaze 10 for my
    Tacoma.
    My professional tire shop is telling me
    2 wheels are correct and 2 wheels are not machine properly
    Both wheels will not sit properly.
    Has anyone else had this issue?
    Is like the inner bore is wrong and not machined properly.
  2. Dec 22, 2022 at 4:20 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    :worthless:
    eurowner likes this.
  3. Dec 22, 2022 at 4:49 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    In all of the SCS posts, I've never heard of this being an issue. Seems HIGHLY unlikely that you'd get 2 wheels with the same issue.
    Do you have calipers to measure the bores? Try to mount the wheels yourself? Were the two "defective" wheels tried on different hubs? Example, doesn't fit the rear hub, try that wheel on the front hub...
    landphil likes this.
  4. Dec 22, 2022 at 4:55 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Haven't heard of the issue with SCS, but machining defects can happen any time. It's also possible for the powder coat to be laid on too thick. Had that happen with StopTech brake discs.
    Did you measure the centerbore? They're supposed to be just over 106mm.
  5. Dec 22, 2022 at 5:28 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
  6. Dec 22, 2022 at 5:38 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Where won't they fit front, back, or both?
  7. Dec 22, 2022 at 5:42 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
    Rigo,
    We've already discussed this via email and we've also spoke with the shop on the phone regarding your truck and wheels. I've already replied to your email with a couple of solution options. Let me know what you decide you want to do. At least give us more than 30min to come up with a solution before causing other folks to panic.
    Go check your email!
    Thanks
    Vin
    02TRDXTRA, BRFab, DCSBMurph and 24 others like this.
  8. Dec 22, 2022 at 6:11 PM
    Rigz22
    California
    @SCS i don’t want anyone to panic. I simply wanted to know if anyone had this same issues.
    Today was my
    Birthday, and I had small surgery and I was hoping my brother in law would take care of this.
    I appreciate the quick response from SCS and taking responsibility
  9. Dec 22, 2022 at 6:21 PM
    eurowner
    eurowner Duke Sky
    Scoty
    From Who, what Part numbers, and do you still have the boxes?
  10. Dec 22, 2022 at 6:22 PM
    Rigz22
    California
    Yeah
    The boxes are correct. I purchased through SCS.
    It was just that the manufacturer made a mistake on 2 wheels
  11. Dec 22, 2022 at 6:25 PM
    eurowner
    eurowner Duke Sky
    Scoty
    :crazy:
  12. Dec 22, 2022 at 6:27 PM
    eurowner
    eurowner Duke Sky
    Scoty
  13. Dec 22, 2022 at 6:37 PM
    MGMDesertTaco
    At least post some pictures of the wheels you've chosen. How do they look? :popcorn::boink:
    Casey182 likes this.
  14. Dec 22, 2022 at 6:39 PM
    erok81
    erok81 Well-Known Member
    Imposter
    Sounds to me like it might be a mfg mistake like OP said. SCS wouldn’t reply with multiple solutions if the wheels were right.
    Not sure why you linked that other thread.
  15. Dec 22, 2022 at 6:40 PM
    Rigz22
    California
    I don’t have pictures because the tire shop took them off and put my
    Stock back when they discover the problem.
    Sorry for not posting the pictures of what they had
  16. Dec 22, 2022 at 6:43 PM
    na8rboy
    WI
    Hey shit happens. Good company, they will handle it.
    DavesTaco68 likes this.
  17. Dec 22, 2022 at 6:44 PM
    Rigz22
    California
    I know that SCS will handle it.
    They have been in contact with me and they make very nice wheels
  18. Dec 22, 2022 at 6:52 PM
    5465
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    I’m on my 3rd set of SCS wheels, zero issues.
  19. Dec 22, 2022 at 6:53 PM
    MGMDesertTaco
    Which model/color are they? :popcorn:
  20. Dec 22, 2022 at 6:53 PM
    uurx
    '12 t|x pro
    could include this tid bit of info into your original post...
    b_r_o, GI Pro and 5465 like this.
Thread Status:
