SDS Fuel Management for 4cyl (2rz/3rz)
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by the_white_shadow, Apr 14, 2020.
  1. Apr 14, 2020 at 10:47 AM
    the_white_shadow
    the_white_shadow [OP] Well-Known Member
    I am selling a SDS fuel management kit that was used on a 22re, but can be used on any 4cyl (2/3rz). This kit allows you to program your fuel injection system on your own. Comes with everything seen in the pics.
    O2 sensor
    Upgraded coil packs
    Wideband Air/Fuel Ratio Gauge (This was a $200 add on from LCE)
    ECU and wiring harness
    Electronic Fan relay setup
    Check out the LCE link for more info. This can be used on other 4cyl engines as well.
    https://www.lceperformance.com/LCE-Pro-Fuel-Injection-Kit-3-SDS-Kit-Only-4Cyl-p/1063025.htm
    Price is $800 shipped. Thats around half price compared to retail. Reason for the sale is to do an engine swap in a project.
    Located in 77435 (TX) but will ship.
    Fw0oXEtsngHa4K3ReSIwIfLb1kw1mtWrknTgT-sG_a226ffbf7576280575eead3f83775e7b90e3d03c.jpg
  2. Apr 14, 2020 at 10:59 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Pm in bound!
  3. May 6, 2020 at 6:11 AM
    the_white_shadow
  4. May 30, 2020 at 5:26 AM
    the_white_shadow
