Sea Foam in Brake Booster Vaccum Hose?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Apr 11, 2019.
  1. Apr 11, 2019 at 9:36 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I've done it to multiple vehicles with only positive results. Do it slowly and let it sit for awhile. Fire up and let it smoke.
  2. Apr 11, 2019 at 9:45 PM
    dustin19d
    dustin19d Well-Known Member
    Dustin
    Washington
    06 Sport, 4X4, 6-Speed
    Welds and Cuts and stuff
    Last I checked Seafoam is designed to be used this way. Read the back of the can...
  3. Apr 12, 2019 at 8:21 AM
    2009Access4x4
    2009Access4x4 [OP] Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Interesting. I do love my Tacoma. Do you know what normal cat temps should be? I started monitoring the cat temps through my obd 2.
  4. Apr 12, 2019 at 8:22 AM
    2009Access4x4
    Shane
    Right. That's why I thought my friends were taking a risk when they told me about this method of distribution but they all swear it led to way more power in their engine. It's not conventional so I thought I'd ask.
    kidthatsirish likes this.
  5. Apr 12, 2019 at 8:24 AM
    Mully
    Mully Well-Known Member
    CA
    12 DC 4x4 Lifted Sport
    Lifted, Kings, Locked, 295s and more.
    750 degrees or more.
  6. Apr 12, 2019 at 8:25 AM
    2009Access4x4
    Shane
    So far, when warm, mine run around the same temp of ~1000-1100 and I've been running seafoam in the tank for years.
  7. Apr 12, 2019 at 8:26 AM
    2009Access4x4
    Shane
    Did you notice a power increase with your old jeep when you did this? Did you suck up the seafoam through the vacuum line?
  8. Apr 12, 2019 at 8:31 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    plain old distilled water also cleans carbon. dribble in slowly in any vacuum hose or intake, will blast carbon chunklets off.
    but gas tank bg44k or techron is far easier, more reliable, but more expensive as you may need to run 5 tanks back to back
    to clear up thick carbon....expensive just because bg44k and techron 5 tanks worth costs a small bit of money
    BassAckwards[QUOTED] likes this.
  9. Apr 12, 2019 at 8:43 AM
    Mully
    CA
    They are going to plug up. Prepare to buy new ones. Good luck.
  10. Apr 12, 2019 at 8:46 AM
    Mully
    CA
    In gastank, and vacuum lines. It did idle better. Sold it, motor and drivetrain were worn out.
  11. Apr 12, 2019 at 8:57 AM
    2009Access4x4
    Shane
    Have you noticed any benefits? What is the right tool?
  12. Apr 12, 2019 at 9:08 AM
    2009Access4x4
    Shane
    Did you notice any benefits? Thanks
  13. Apr 12, 2019 at 9:11 AM
    pnw.river.junkie
    pnw.river.junkie Well-Known Member
    PNW
    I think it ran better, but I have no way of proving that. Could have been the placebo effect. It definitely didn't hurt though.
  14. Apr 12, 2019 at 9:15 AM
    2009Access4x4
    Shane
    Which stuff is meant for feeding into the vacuum line? Thanks
  15. Apr 12, 2019 at 9:21 AM
    #35
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    I've heard, for many years now and from quite a few different sources, that Seafoam will eat the injector nozzles.
    One can is okay, two cans is the limit. After that the injectors will start to erode.
    (Obviously, this is the Seafoam product that is added to the fuel tank.)
  16. Apr 12, 2019 at 9:31 AM
    #36
    Bobby18
    Bobby18 Well-Known Member
    Bobby
    2008 Tacoma Prerunner
    DTF +6 LT, Kings 2.5x10 C/O, 2.5x2 Bump, Adv Fiberglass 1 Piece Conversion
    Ive done this for years to every car as soon as i buy it. You should have a tool that looks like a little IV drip but its not necessary.
    Get a little tubing and run it in a vacuum line while trucks off, pinch the line, start it up, put the line into the bottle of seafoam and SLOWLY let it suck up some seafoam.
    DO NOT LET THE TRUCK DIE. Give it gas if it starts sputtering and im not responsible for you breaking your truck lol youll see a huge cloud of white smoke out your tail pipe. Use 1 can of seafoam in 5 minutes so letting a good amount get into the system then a second can emptying the can in about 25 minutes.
    If you go to pep boys or any shop like that this is part of their "Tune up" package
  17. Apr 12, 2019 at 9:33 AM
    #37
    dustin19d
    Dustin
    Washington
    I would do it maybe twice a year on my ‘93 civic between 200k-300k miles. It really did help keep it running smooth. Was still averaging 38.5 mpg when I sold that thing.
    I personally wouldn’t do it on the truck but I have no doubt it’s safe if done correctly.
  18. Apr 12, 2019 at 9:37 AM
    #38
    TartanEagle
    '17 ACLB 4x4 MT
    My '93 is the VX model. New was 55 mpg, now with over 270k, it is down to the middle 40s mpg. I have never used the brand Seafoam, but have used another brand fuel additive. Maybe 2 oz a tank full, 3 or 4 times a year.
  19. Apr 12, 2019 at 9:40 AM
    #39
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    You could clean the intake and valves by just using a spray bottle that sprays a very fine mist of water . Just spray water into the TB at 1500rpm and let off if the motor loads up then continue again
    Do this until you notice a cleaner idle quality
  20. Apr 12, 2019 at 9:42 AM
    #40
    dustin19d
    Dustin
    Washington
    I wish mine was a VX. Hard to find.
    Had to sell mine when I moved across the county. Picked up a dirt cheap ‘03 after the move from an old lady that didn’t want to pay a shop to fix a bunch of small issues that ended up costing me ~$200 bucks and a couple weekends.
    TartanEagle[QUOTED] likes this.
