Sea Foam in Brake Booster Vaccum Hose?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2009Access4x4, Apr 11, 2019.
  1. Apr 12, 2019 at 4:06 PM
    #41
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    I did the Seafoam through the brake hose vacuum line on my old 93 Z28 that was supercharged and it cleaned it out really well. The engine only had 45K miles on it and it still did a good cleaning. Seafoam does not damage the cats, all the carbon buildup breaking loose might do that damage but I've never had a problem. The Tacoma is not built any better than the average car/truck so if you have carbon buildup, it should really be cleaned out no matter how you decide to do it. I do think that harsh chemicals running through the fuel injectors could possibly lead to damage to the injectors so don't overdo what you put in your tank. If your engine is already burning oil which leads to the carbon buildup then you're on borrowed time anyway.
  2. Apr 12, 2019 at 4:30 PM
    #42
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I did this in my truck recently with about 2/3 of the can. I let it sit for about 30 minutes afterwards then started it up and drove it around for about 20 more minutes. It smoked like crazy burning off some of that stuff. I feel like it runs better now and I had no negative effects from doing this.
  3. Apr 12, 2019 at 4:35 PM
    #43
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    No, the carbon build up is a function of crank case ventilation which gets piped back into the air intake and also combustion in general.
    Burning oil is from blow by at the piston rings.
    Seafoam is good for carburetor engines and farm equipment fuel stabilization.
    I wouldn’t run this through the intake to clean the manifold, valves and pistons. Distilled water is almost free and less harmful and will do the same.
    For fuel and injector cleaning is get stuff like BG44K like what someone here posted some great actual results of.
    I’m on the fence about putting seafoam in the crank case a couple hundred miles before an oil change. Should probably drop lower oil pan first and make sure there’s sludge in it though otherwise there’s no reward for the risk
    Paul631 and TartanEagle like this.
  4. Apr 12, 2019 at 4:37 PM
    #44
    TireFire
    Olympic Peninsula
    That’s what I thought when I did that in my old Jeep. It made it idle better and but dyno was happy too (it always wants to be after money and time spent). Couple weeks later one of the cats went out...
    boostedka[QUOTED] likes this.
  5. Apr 12, 2019 at 6:29 PM
    #45
    boostedka
    James
    NM
    I also ran about 5oz in the engine oil for about 5 miles before changing the oil as well. I’ve been meaning to swap out the spark plugs since running into the mani. I may have fouled one or two of them since I had a few misfire codes that came up while it was smoking. None of those codes has returned since.
  6. May 4, 2019 at 5:20 PM
    #46
    twblanset
    twblanset Well-Known Member
    Todd
    Vacaville, CA
    2015 TRD OR
    Mild lift and some tasty bits
    Around 120k I used Seafoam with no problems. Sucked a little in through through the booster line, I think it stalled. Dumped the rest in the gas tank. Let it sit 20 mins. Drove it 20 miles and it smoked a lot. It felt smoother when accelerating and it idled smoother. I'm at 215k now and still on the original cat. I was about to do it again.
    Sucking in a little water will work as well. It really cleans the cylinders. That's why cylinders are so clean after a head gasket leaks.
  7. May 4, 2019 at 6:44 PM
    #47
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    I have been running it in my 94 land cruiser for years. I run it in the oil a few days before I change it, and maybe once a year I run it though the vacuum hoses. When I took the engine apart to replace some components the inside of the engine looked extremely clean with very little carbon build up and she has approximately 330,000 miles and still runs strong. I have only run sea foam in the oil on my Tacoma a few days before the oil change. I’d consider using the fogger in the future.
  8. May 4, 2019 at 7:08 PM
    #48
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Everywhere?o_O:boink:
  9. May 4, 2019 at 7:22 PM
    #49
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Amsoils powerfoam does a great job at cleaning up carbon. Although I’ve never done it to the Tacoma. I did do it to my lawnmower.
    TartanEagle likes this.
  10. May 4, 2019 at 8:16 PM
    #50
    kidthatsirish
    kidthatsirish Well-Known Member
    2006 Tacoma Access Cab, 2.7L, 4x4, Manual Transmission
    President McKinley w/KLM 203P and threw the roof antenna, ICON RXT leaf spring packs (position 2), Bilsteen 5100s, ARE Camper Shell, Pop & Lock tail gate, Dash Cam
    ive probably done ten cans over the life of my engine.
  11. May 5, 2019 at 5:43 AM
    #51
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    So, 10 cans to the fuel tank -or- through a vacuum hose?
  12. May 5, 2019 at 11:10 AM
    #52
    kidthatsirish
    4 through the brake booster vaccum line, the rest either through the tank or direct to oil via fill spout.
  13. May 5, 2019 at 11:18 AM
    #53
    BlackGT99
    BlackGT99 Well-Known Member
    Noel
    2019 VooDoo Blue Tacoma TRD Pro
    The old sea foam trick. Been doing it for years. Love the smoke show that ensues haha
  14. May 5, 2019 at 3:09 PM
    #54
    kidthatsirish
    just to be clear this is a cumulative number over the life if my truck.
  15. May 6, 2019 at 11:01 AM
    #55
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Purty much the cat took some doing. :thumbsup:
  16. May 6, 2019 at 11:11 AM
    #56
    junkyardyote
    junkyardyote Well-Known Member
    2010 4x4 sr5 4.0 crew cab/ 2023 TRD Offroad DCLB 3.5 auto
    I mixed ATF and water 50/50 in a spray bottle and set the idle about 1500,sprayed into the TB in my Jeep. Smoothed out the idle. I do it every few years.
  17. May 6, 2019 at 11:16 AM
    #57
    TireFire
    Olympic Peninsula
    Tacos have an electric throttle with no IACV so It won’t have that effect and I’m not sure why you would spray ATF into your TB to begin with
  18. May 6, 2019 at 11:17 AM
    #58
    junkyardyote
    Steam cleans carbon
  19. May 6, 2019 at 11:27 AM
    #59
    Jaypown
    Jaypown Well-Known Member
    Justin
    NE Ohio
    2020 Tundra SR5 Crew Max TRD Sport 4x4
    How much Distilled water are you adding? I've done seafoam on older vehicles but none on the tacoma. Curious to try water and see what that does.
  20. May 6, 2019 at 11:31 AM
    #60
    TireFire
    Olympic Peninsula
    Depends how you apply it, i don’t like the vacuum booster method because of the hydro lock risk. Spray bottle to throttle body is safer IMHO, maybe 4oz...
