Sea foam?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by victor in the desert, Oct 22, 2018.
  1. Oct 27, 2018 at 1:12 PM
    #41
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Sig45 likes this.
  2. Oct 27, 2018 at 1:16 PM
    #42
    PerazziMx14
    PerazziMx14 I'm fat but identify as skinny, I'm Trans-slender
    Close to 39.9609243°N, -77.5763777°W
    Lucas fuel system cleaner is 60 to 100% hydrotreated heavy paraffinic or more commonly known mineral oil. MSDS/SDS sheets are real bubble busters.
    Atlas86 likes this.
  3. Oct 27, 2018 at 3:33 PM
    #43
    LivinLoud
    LivinLoud Miller Latte Advocate
    TJ
    Western mass
    ECOBOOST
    I mean… it’s a Ford, you don’t care
    Woah really? Perhaps I’ll have to look for something more effective then. Thanks for the heads up
  4. Oct 27, 2018 at 8:42 PM
    #44
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    Sea foam is pretty old technology and was originally designed for 2 cycle boat motors. There are better products using PEA. The gumout All-in-One has a lot of PEA. I use that in my gas. The other competing product with sea foam is gumouts multi system cleaner. That also has PEA. I’ve used it very successfully to degunk an old generator by putting it in the oil.
    Benny123 likes this.
  5. Oct 28, 2018 at 7:04 AM
    #45
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
  6. Oct 28, 2018 at 7:11 AM
    #46
    Armed in Utah
    2003 Lexus LX 470
    lynyrd3 likes this.
  7. Oct 28, 2018 at 7:19 AM
    #47
    Armed in Utah
    2003 Lexus LX 470
    interesting......proven ?
    lynyrd3 likes this.
  8. Oct 28, 2018 at 10:52 AM
    #48
    PerazziMx14
    Since SeaFoam is comprised of 80/20 Naphtha and Kerosene mixing the 2 together in the same percentages is proven by every can of SeaFoam that ever rolled off the filing line
    Has SeaFoam actually proven to do anything thats another kettle of fish.
  9. Oct 28, 2018 at 10:54 AM
    #49
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I'm seeing lots of "I think it's doing something in there" opinions in this thread.
    smithe3006 likes this.
  10. Oct 28, 2018 at 2:30 PM
    #50
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    I run E85 in my FRS and after a lot of research I have found that regular gas burns very dirty mostly because of all the additives used, the ethanol burns clean and is better for the engine if properly tuned for it. So all that smoke you see in the video is creating carbon in the engine. Combined with the pcv system that allows oil to inter the intake, over time carbon is going to build up. It seams a lot of these treatments do a good job of cleaning out the fuel system and carbon..
    https://www.youtube.com/watch?v=-o5D-nic9WM
    Atlas86 likes this.
  11. Oct 28, 2018 at 2:59 PM
    #51
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I think washing your truck gives the same effect of dumping sea foam in your tank.
  12. Oct 28, 2018 at 5:04 PM
    #52
    lynyrd3
    Bill
    East Central Upstate NY
    :rofl:
  13. Oct 28, 2018 at 5:07 PM
    #53
    spitdog
    Yep, every time I wash and wax, the truck always seems to run better.
    Sprig and lynyrd3 like this.
  14. Oct 29, 2018 at 7:05 AM
    #54
    Armed in Utah
    2003 Lexus LX 470
    Clean on the inside & out !
    Happy Taco Truck !
  15. Oct 29, 2018 at 8:09 AM
    #55
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Yeah, I'd need to see some actual rigorous studies done proving this stuff actually does anything and if so under what conditions. Nothing said in this thread means jack shit.
  16. Nov 2, 2018 at 3:06 PM
    #56
    Armed in Utah
    2003 Lexus LX 470
  17. Nov 2, 2018 at 5:33 PM
    #57
    GreenYoda
    GreenYoda Well-Known Member
    Great info at that link. Again I have seen it work wonders on engines that have sat for months on end. Mostly boat motors but on some cars too.
  18. Nov 2, 2018 at 7:19 PM
    #58
    PerazziMx14
    Again.......................its not a miracle elixir its genius marketing. Mix 2 readily available inexpensive products together, put in a fancy can and sell t for 10x the profit.
    Sprig and JGO like this.
  19. Nov 3, 2018 at 6:50 AM
    #59
    Armed in Utah
    2003 Lexus LX 470
    Bought some Crown Kerosene & White gas/camp fuel yesterday
    80% gas & 20% Kerosene
  20. Nov 3, 2018 at 7:09 AM
    #60
    coreseller
    coreseller Well-Known Member
