Seafoam and Cleaning Throttle Body
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cabsav214, Feb 9, 2010.
  1. Feb 9, 2010 at 9:23 PM
    cabsav214
    cabsav214 [OP] Active Member
    NOR CAL
    08 DC 4x4
    I just rolled over 100,000 and wanted to seafoam the crankcase and clean the throttle body, from what I know, you add seafoam to the gas tank, crankcase (through engine oil) and then add 1/3 can through the brake booster hose while its idling, wait five minutes then turn the engine over.
    After all of this I was planning on changing the engine oil. Is there a specific order I should do all this in to keep everything clean as possible?
  2. Feb 9, 2010 at 9:41 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    nope, add it to the crankcase and gas take about 100 miles before you do the brake booster and change the oil, when your doing the brake booster, shut the truck off as soon as you get all of the seafoam in the brake booster, leave it for 20 mins to an hour, then watch the smoke show!
    and change the oil too.
    here's my write up on cleaning the throttle body,
    http://www.tacomaworld.com/forum/technical-chat/50153-how-cleaning-throttle-body.html
    also get the O gasket for the throttle body while you have it off.
  3. Feb 9, 2010 at 9:44 PM
    awymore997
    awymore997 Quitting is for Quitters
    Andrew
    Charlotte, NC
    08 Access Cab TRD OFRD 6 speed
    Just go down and pick up a can and read the Destructions.....you cant go wrong
  4. Feb 10, 2010 at 2:55 PM
    cabsav214
    NOR CAL
    08 DC 4x4
    When doing the crank case, I've heard different recommendations concerning how long to leave the seafoam with the oil. Some say let it idle for 5-10 minutes while others say take it out and drive 100 miles. Can I damage the the crankcase or oil seals by leaving it in that long?
