Seafoam - Do you use it?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Orian99, Jun 7, 2016.
  1. Jun 7, 2016 at 5:18 PM
    blur
    blur Well-Known Member
  2. Jun 7, 2016 at 5:21 PM
    eon_blue
    Azusa, CA
    ^^ That was the way I used it, turned my neighborhood into a smoke show for several minutes as I drove around after the treatment.
  3. Jun 7, 2016 at 5:39 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
  4. Jun 7, 2016 at 5:51 PM
    GREENBIRD56
    GREENBIRD56 Well-Known Member
    Casper / Tucson
    014 Taco 4Dr 4wd
    Sorry, don't see the connection between carbon on a piston crown and cleaning fuel injectors. GM has been selling a very effective combustion chamber cleaner since the 1960's - but it is a solvent not a detergent. It worked wonders on my high compression motors and even our 2002 Z-28 - but it doesn't do much for fuel injectors.
    SilverBullet19 likes this.
  5. Jun 7, 2016 at 8:39 PM
    Iasco
    Iasco Well-Known Member
    +1 for 44k, good shit.
    I've seen it fix a p0420 code on a subaru too.
  6. Jun 8, 2016 at 12:32 PM
    Orian99
    Orian99 [OP] Active Member
    Jake
    2015 Black Double Cab Tacoma TRD (Off Road)
  7. Jun 8, 2016 at 12:51 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    At my 25k oil change for my 2014 v6 Tacoma I checked the oil on the dipstick two nights before I planned to do the oil change. It looked fairly new, mostly gold in color. That night I poured in 5oz of SeaFoam into the crankcase as instructed on the can. Drove it to work and back (30 mile rt) and did the oil change the following morning. The oil was like straight black. I'm guessing the SeaFoam cleaned out some stuff gunked up in the engine?
    Norton likes this.
  8. Jun 8, 2016 at 12:55 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    The detergents likely broke loose some crud in the system.
  9. Jun 8, 2016 at 1:49 PM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I get their "may" be a benefit to using this on much older vehicles (10yr plus). But why even bother using this on a vehicle that is a few years old and only has under 100K miles?
  10. Jun 8, 2016 at 4:59 PM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    I use this gadget when using Seafoam. It turns the liquid into a vapor like substance before it goes in the vacuum line.
    Seafoam really helps some older cars I have worked on. Like others said not so much on newer vehicles in my experience.
    Capt. Obvious and Norton like this.
  11. Jun 8, 2016 at 5:17 PM
    Lthompson
    Lthompson Well-Known Member
    ive used it in everything. Used the spray into the air intake. Poured it into the vacuum tube. Put it in oil before oil changes. Put it in gas. Also used the lucus treatment. Who knows if it works.. I just use it because it gives me peace of mind. Same reason I use synthetic oil and lucas oil stabilizer in everything.
  12. Jun 9, 2016 at 7:26 AM
    hotrod53
    hotrod53 Well-Known Member
    Lynd
    Pittsburgh, PA
    ‘14 DCLB Sport, ‘18 TCH, ‘13 TCH
    Weathertech floor liners moded to hold OEM floor mats, weathertech vent visors, Toyota bed mat, LEER 100XL cap, hood gasket mod to stop whistling.
    I'm a big fan in BG products,mad used them for many years when I worked at a place where I had a connection.
    As far as the Seafoam, I had just poured it in the fuel tank of my Camry when I had that oil burning issue.
  13. Jun 24, 2016 at 1:00 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    I just used a full can of BG 44K in a full tank of 92 octane, and HOLY COW. My truck has 206k miles on it, never had a single fuel injector service. I did run a Seafoam treatment a couple years ago that seemed to do some good, but nothing like the BG. Within 50 miles, I had amazing throttle response improvement. By the end of the tank, the truck drove like new. I used to have some serious hesitation when I had the AC on and going up hills or having to smash the gas pedal, but this stuff did amazing things. Never threw a code, never had a single hiccup with the motor. No smoke came out like with Seafoam, and now I have the smoothest idle ever and I gained 1.2MPG back, even with my RTT and rack installed. I'm rather impressed and will be using this stuff in the future.
  14. Jun 24, 2016 at 1:06 PM
    ZRXDean
    ZRXDean Well-Known Member
    Langhorne PA
    DCLB - Pabst Metallic
    OME 885, Billstein 5100, Deaver 2" AAL, ARE CX Cap, Go Rhino Dominator steps
    I use it in this every so often..... not the kids, but the bike.......
    Capt. Obvious and jammer like this.
  15. Jun 24, 2016 at 1:06 PM
    #35
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Try it in the kids, then post vids.
    ZRXDean[QUOTED] likes this.
  16. Jun 24, 2016 at 1:11 PM
    #36
    jammer
    jammer 2003 Toyota PreRunner 3.4L
    Ben
    Bentonville, AR
    2003 Lunar Mist Tacoma PreRunner 3.4l
    OME Coils/Bilstein 5100's front / 5125's rear 105 Amp Denso Alternator
    +1 for 44k. Expensive and can only find it at our local Toyota Dealership.
  17. Jun 24, 2016 at 1:12 PM
    #37
    jammer
    Ben
    Bentonville, AR
    That bike is sweet!
  18. Jun 24, 2016 at 1:13 PM
    #38
    ZRXDean
    Langhorne PA
    :rofl:They're a bit older now - that's an old pic. The boy would be all for it though...... the girl.... not so much.
  19. Jun 24, 2016 at 1:14 PM
    #39
    ZRXDean
    Langhorne PA
    Thanks - it's been a labor of love. I have a lot of sweat into it and probably more than a few tears....
  20. Jun 24, 2016 at 1:17 PM
    #40
    jammer
    Ben
    Bentonville, AR
    Understood. Man after having fuel injection, I would never won't to back to a carburetor. Again, beautiful bike. I've only seen one of those around our parts, but it's not that clean.
