seafoam help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by branct06, Jul 14, 2009.
  1. Jul 14, 2009 at 7:25 PM
    branct06
    branct06 [OP] Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    can someone show me with pics or describe to me where to put the seafoam on a 2nd gen tacoma?? pics would be best!!! thanks
  2. Jul 14, 2009 at 7:41 PM
    DdayIsNear
    DdayIsNear Well-Known Member
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    google vidoe or youtube sea foam,, more than enough info\
  3. Jul 15, 2009 at 3:53 AM
    sriley727
    sriley727 Well-Known Member
    Aiken, SC
    08 Reg cab PreRunner SR5
    Bone stock
    Its pretty simple. Just put half the can in the oil filler and the other half in your gas tank.
  4. Jul 15, 2009 at 4:03 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    On a V-6, wouldn't it leak out of the oil filter as you attmpt to install it-as the filter installs threads down?
  5. Jul 15, 2009 at 4:09 AM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    It says the oil FILLER neck and half in the gas tank.
  6. Jul 15, 2009 at 6:05 AM
    Brunes
    Brunes abides.
    Rotorhead
    And check out the video if you want to try the intake method. But do be careful with that- It can destroy your cats if you do it wrong.
  7. Jul 15, 2009 at 6:08 AM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    i would not do the intake way....i think bad idea as well
  8. Jul 15, 2009 at 6:37 AM
    grivera
    Hanover, MD
    My bad!
  9. Jul 15, 2009 at 6:46 AM
    Brunes
    Brunes abides.
    Rotorhead
    IDK about a BAD idea- It's probably not recommended if you have a high mileage engine cause the deposits and gunk may be supporting seals and gaskets- Remove it and you may find leaks.
    But the guys at any firestone/quiklube type place or the dealership that do the "Intake system Treatments" are doing the same thing- so if you do it right- no biggie. (and Catalytic converters are covered under the extended 8yr 80K emissions warranty)
  10. Jul 15, 2009 at 6:48 AM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    yeah man, by bad idea i meant, if you do not know what you are doing, and just heard about this, take the safe way out. otherwise, get ready for this. OP - how many miles do you have?
  11. Jul 15, 2009 at 8:52 AM
    sriley727
    Aiken, SC
    Bone stock
    I've done the intake way on carb vehicles but it would be pointless to do so on a fuel injected vehicle. If you put it in the gas tank, it will work its way through the fuel system which is the intended purpose of it. The intake way worked on carb vehicles obviously because the carb is where the fuel enters the engine.
  12. Jul 15, 2009 at 1:27 PM
    branct06
    Thomas
    i have about 57.000 miles on my truck
  13. Jul 15, 2009 at 2:03 PM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    yeah thats a good time to do it.. follow the posts and dont do it the intake way..when your ready, we are here for you buddy
  14. Jul 15, 2009 at 2:35 PM
    branct06
    Thomas
    Just finished doing it, everything went well
  15. Jul 15, 2009 at 2:35 PM
    branct06
    Thomas
    didnt see too much smoke though.....
  16. Jul 15, 2009 at 3:37 PM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    u had low mileage...
  17. Jul 15, 2009 at 3:37 PM
    DdayIsNear
    Crazy
    NW Jersey
    TRD Offroad
    All pro sliders
    how much gas did ya have in tank?
  18. Jul 15, 2009 at 3:40 PM
    obxfishn
    obxfishn Well-Known Member
    Eastern Virginia
    2.5" ToyTec Lift, Smitty Built Nerf Bars, Scangauge unit,
    When you add 1/2 the can into the oil filler neck, how long do you run the engine before changing the oil? It just seems odd to add such a thing to your oil. I would think it would be bad on your seals and could cause them to swell up and leak.
  19. Jul 15, 2009 at 3:50 PM
    Brunes
    Brunes abides.
    Rotorhead
    I usually dump it in about 50 miles/2 days before an oil change...Not sure if it's right...but ::shrug:: makes sense to me.,
  20. Jul 15, 2009 at 4:37 PM
    URBIKESUCKS
    URBIKESUCKS Well-Known Member
    Ron
    Prescott AZ
    2014 DCSB TRD OFF ROAD 8speed auto from a lexus
    Habitat
    I have used seafoam in the oil before oil change and in the fuel tank with good results. I can assure you that it will clean some of the shit out.
    The bike is carbed but I think it will also help our FI motors.
