SeaFoam Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sproulesxrunner, Mar 10, 2011.
  1. Mar 10, 2011 at 6:15 PM
    Sproulesxrunner
    Sproulesxrunner [OP] Well-Known Member
    Canada
    08 Xrunner
    Too much for TW to know
    Hey guys and girls,
    I have read many threads of success stories of Seafoam on here and I might give it a try. However I have a couple of question on seafoam. I have heard that you put 1/3 in your fuel tank 1/3 in your oil filler and 1/3 in your brake line booster.
    Can someone take a picture of the brake line booster for me? Is there a write up on how to do it?
    Would it be alright for my engine if I just went and put 1/2 in the fuel tank and 1/2 in the brake line booster. I don't really want to ruin my oil right now.
    How long do you have to rev or idle you engine before the grey cloud of smoke goes away?
    Thanks in advanced.
  2. Mar 10, 2011 at 6:19 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    sorry i dont have an answer but ive been wanting to research using seafoam more and this could inform me more
    good luck!
  3. Mar 10, 2011 at 6:32 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I personally wouldn't do it but its your truck!
    and half in the intake and half in the gas seems pretty popular.
  4. Mar 10, 2011 at 6:35 PM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
  5. Mar 10, 2011 at 6:47 PM
    RZRob
    RZRob Well-Known Member
    Robert
    Anaheim Hills
    I know I researched adding it to the oil, and it's really something you'd only add within 500 miles of an oil change. I recently ran some in a motorcycle that'd been parked for years and it really ran better after a few tankfuls. I do recommend the vacuum or intake as that cleans air circuits that might've been affected by latent gasoline sitting there. I would NOT recommend the brake system at all as there are boiling point and other factors that that product is not designed to address. Plus brake systems don't have enough agitation to benefit from it.
    RZ Rob
  6. Mar 10, 2011 at 6:48 PM
    scocar
    Dick
    2015 DCLB 4x4 SR5
    I don't believe it it recommended for the brake system...
  7. Mar 10, 2011 at 6:48 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
  8. Mar 10, 2011 at 6:58 PM
    Sproulesxrunner
    Canada
    08 Xrunner
    Just to clarify... How does the sea foam clean the brake components? I just had my brakes flushed so I don't think need to do the brakes. To clean the engine components properly should I can just put it into the fuel tank and it will clean the engine. Thanks for the input.
  9. Mar 10, 2011 at 7:12 PM
    Sproulesxrunner
    Canada
    08 Xrunner
    So this means that it cleans the engine better than conventional STP engine cleaner? Thanks for the answers.
  10. Mar 10, 2011 at 7:22 PM
    Sproulesxrunner
    Canada
    08 Xrunner
    Do you think I would get good results if I just ran 1/2 a bottle of seafoam in a full gas tank? Thanks for explaining all of this stuff to me.
  11. Mar 10, 2011 at 7:32 PM
    Sproulesxrunner
    Canada
    08 Xrunner
    Did you get much smoke out of the exhaust? I looked at some videos on Youtube and they had massive amount of clouds of exhaust.
  12. Mar 10, 2011 at 7:36 PM
    Tlook
    Tlook Well-Known Member
    really any intake line will do the trick, back in the 80s when carbon build up was a real problem my shop teacher used to put a quart of transmission fluid b/c of its ability to be a great detergent through his intake and would smoke everyone out, anyways i seafoamed my truck and it runs fine.
  13. Mar 10, 2011 at 9:13 PM
    Yuma Taco
    Yuma Taco Well-Known Member
    Lee
    Yuma, Az
    09 PreRunner DC TRD
    35% tint windows, OEM black running boards, OEM black roof rack, Foglight mod, De-badged & Sockmonkey Horns decals added, Two ammo box storage units (removed), 110 volt & 12 volt outlets for back seat area, EGR Slimline inchannel visors (all windows), Fold-A-Cover G4, Tonneau, Bedmat.
    I put a can in the tank every 5k just to keep things clean and not have to pour it into the intake.
    Yuma Taco,
  14. Mar 10, 2011 at 9:16 PM
    Sproulesxrunner
    Canada
    08 Xrunner
    So what's the verdict... Should i pore it into the brake line booster thing? Is it hard to do? Thanks again for everyones advice.
