Seafoam Spray
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iJDub, Feb 5, 2021.
  1. Feb 6, 2021 at 8:20 AM
    rphillips
    rphillips Well-Known Member
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Don't see how Seafoam in the fuel tank nor injector cleaner will do anything for the throttle body!!! Am I missing something? And OP yes spray it in, with eng. running, it will get sucked thru, just as if pouring it in... Just my opinion.
  2. Feb 6, 2021 at 10:16 AM
    badger
    badger Well-Known Member
    07 SR5
    No, everyone else is missing the obvious. Only air goes through the throttle body. They do need cleaning though. I do mine every 90K. Seems to be about right. I clean the MAF every 30K because it's quick and easy.
  3. Feb 6, 2021 at 10:23 AM
    Waasheem
    Waasheem
    2007 xrunner
    I’ve been using Jectron for a few years. It and the one made by redline are the only ones I’ve noticed that actually makes a difference in improving how the engine runs
    In my old el camino, it wasn’t running bad but I’d put Jectron in, drive it up a miles long uphill road. Then floor it as I’d approach the top. It made a huge difference, as if I replaced the engine.
  4. Feb 6, 2021 at 10:58 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    I think the point is to do routine maintenance.
  5. Feb 6, 2021 at 7:36 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Your right, Putting it in the gas tank isn't going to clean the throttle body. That isn't what it is for.
    Remove the throttle body and clean it manually using the spray seafoam or maybe even throttle body cleaner. :eek: Crazy I know right.
  6. Feb 6, 2021 at 9:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m with Jimmy.
    If you are so inclined to use a “cleaner” the ones you pour in the gas tank will “probably” be better.
    I say this because, the cleaner will go though the entire fuel system.
    Then will be inject into the intake and onto/around the valves, where it will then enter the combustion chamber.
    Personally, I would pull the the throttle body IF I had a reason.
    And probably wouldn’t bother with a fuel system cleaner.
    You might even do the 1GR some good if you ran it a bit hard from time to time.
    I believe the 1GR uses the ACIS intake. Not sure when the “butterflies” open.
    But it’s usually active in the upper RPM range.
    Maybe @Torspd know, I have always been curious?
    Jimmyh likes this.
  7. Feb 6, 2021 at 9:34 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Using a spray bottle filled with water will clean carbon more effectively
    Shawner1974 likes this.
  8. Feb 6, 2021 at 9:35 PM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    In other vehicles I've used it on, I've always put it in via vacuum lines that feeds directly into the intake manifold, post-TB, then dumped the rest in the gas tank. Works pretty well.
  9. Feb 6, 2021 at 10:17 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    No Seafoam for me.
  10. Feb 7, 2021 at 4:58 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Ya'll haven't read the "FIRST" post in the thread. He is NOT asking about cleaning anything to do with the fuel system, he is asking about the "AIR" system. The throttle body is for the intake of AIR, nothing to do with the fuel system. Nothing you put in the fuel tank will ever get close to the throttle body, fuel is delivered downstream of the throttle body. Years ago, 1980's, there were throttle body injection systems where the fuel was injected into the throttle body, but that was years ago.... As always, just my opinion.
  11. Feb 7, 2021 at 5:50 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    We know. We do know how to read.
    You are correct it is an Air System, why spray a liquid into it.
  12. Feb 7, 2021 at 7:24 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Same reason I spray Windex on a window, or carburetor cleaner into a carburetor, to clean it.
  13. Feb 7, 2021 at 7:27 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    I don't use Windex.
    Just a bit of soap and water with a squeegee to clean windows.
  14. Feb 7, 2021 at 7:34 AM
    rphillips
    Rick
    Norene TN.
    2013 Reg. cab 4x4
    none
    Squeegee won't fit into a throttle body. Try a little Seafoam on your windows, I'll bet it will works wonders
  15. Feb 7, 2021 at 7:43 AM
    #35
    Knute
    Yeah....I had to seriously trim the squeegee to fit. Its tight, but we all know tight is good.
    SR-71A likes this.
  16. Feb 7, 2021 at 9:16 AM
    #36
    AL W
    AL W 11 years old and still running strong
    Youngstown, OH
    2013 PreRunner
    Truxdeo Lo Pro QT Tonneau Cover Hewitt Technologies Gen2 SAIS By-pass kit
    I have read that Seaform was originally formulated for 2 stroke marine outboard motors. Not something I would want to run through my engine.
  17. Feb 7, 2021 at 2:49 PM
    #37
    Jimmyh
    SC
    2012 Prerunner SR5
    :rolleyes:
  18. Feb 8, 2021 at 9:08 AM
    #38
    93yotasr5
    93yotasr5 Well-Known Member
    Sacramento
    I use sea foam in both of my Toyota’s. I run some in the crankcase a few days before and oil change and it works great. I’ve confirmed by removing the valve cover(s). My 80series has 330k and the top end looks super clean.
    I also run it through the vacuum lines on the 80. It cleared out a CEL that kept reoccurring. I think of used properly it’s a good product.
    shift957 and coopcooper like this.
  19. Feb 8, 2021 at 9:39 AM
    #39
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    That's like saying ide never run Lucas cause they make 2 stroke motor oil.
    you know theres different formulas for different applications right.
