Seafoam vs chevron techron
Discussion in '1st Gen. Tacomas (1995-2004)' started by CRiz, Dec 21, 2013.
  1. Dec 21, 2013 at 10:26 AM
    CRiz
    CRiz [OP] Well-Known Member
    Christopher
    PHX , AZ
    99 PreRunner 2.7L
    Hey guys just wondering for what i should use, and just curious on which one you guys think is better?
  2. Dec 21, 2013 at 10:47 AM
    YoTaVIdA
    YoTaVIdA NWEST
    Portland, OR
    2001 SR5 Imperial Jade
    Cheveron techron fuel cleaner? After reading many seafoam threads I decided to give it a try. I put some in my vac line, crank case, gas tank. I definitely noticed a + difference in idle and throttle response after I seafoamed the vac line. I have never seen a toyota engine idle as quiet as mine did 30 min after using seafoam and that was with a very gunky TB , MAF, and 80k on my worn out plugs and wires. Im going to drive another 100 miles before replacing my engine oil and fuel filter.
  3. Dec 21, 2013 at 10:59 AM
    Buckoma
    Buckoma Well-Known Member
    Buckeye, AZ
    2016 TRD Sport 4x4
    I heard Techron is pretty good stuff but I have always used Gumout with Regane, complete fuel system cleaner ($9-$10) at every oil change as a maintainer/preventative measure.
    I would definitely do a good seafoam treatment as a deep cleaning, you'll notice the difference right away.
  4. Dec 21, 2013 at 12:37 PM
    twp
    twp Well-Known Member
    Ky
    2002 trd
    What vac line do you put it in?
  5. Dec 21, 2013 at 12:43 PM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Seafoam isnt good for your o2 sensors and isnt good for engines that have underlying issues. If you are going to use it then follow all of the instructions including changing the oil after and possibly changing the fuel filter.
  6. Dec 21, 2013 at 1:37 PM
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    They're both good products. Techron can be used more regularly as a fuel system treatment. Seafoam can be used in the fuel system, crankcase, and vacuum lines. In light of reported O2 sensor and/or catalytic converter impacts, I use it less frequently, and exactly as prescribed.
    I aspirated it into the brake booster line.
  7. Dec 21, 2013 at 1:42 PM
    BDSKJChris
    BDSKJChris Well-Known Member
    Albany, NY
    2019 Quicksand TRD OR DCSB
    Id go with chevron techron...if you feel a need for anything more than an in tank additive check out bgprod.com I wouldnt use anything else.
  8. Dec 21, 2013 at 7:00 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I personally use B12 chemtool, if I'm looking for a serious system cleaning.
    The napalm mixture called "B12 chemtool", makes seafoam look like milk...
    If I want a fuel additive, I use redline SI-1, as it actually contains PEA. (The reason people originally liked techron...)(it doesn't anymore, btw)
    ThunderOne likes this.
  9. Dec 23, 2013 at 2:11 PM
    Bsheriff11
    Bsheriff11 Remember Your ABC's. Always. Be. Casual.
    Brandon
    Virginia livin', South Carolina raised
    2000 Limited T4R
    Click My Sig Homie
    Sea foam has a written statement on their pints that says safe for O2 sensors.
    jammer and PapaBear like this.
  10. Dec 23, 2013 at 2:48 PM
    offrdmania
    Templeton, Ca
    If it is so safe, then why all of the writeups on the web about o2 sensors going out after seafoam use?
  11. Dec 23, 2013 at 8:30 PM
    BDSKJChris
    Albany, NY
    B12 and seafoam are way overkill for any vehicle that doesnt have serious issues (such as running shit oil for forever and never changing it, never changing spark plugs, running poor quality gasoline, there are a lot of better methods and products out there....you wouldn't wash your car with acetone when there are much more gentle and high quality shampoo/conditioners for it, so why dump something thats way too aggressive into you engine?
  12. Dec 23, 2013 at 8:41 PM
    Jakers83
    Jakers83 Well-Known Member
    Jake
    Denver
    2.7 base.
    OME lift. Tires and wanting more
    What about just oil additives?
  13. Dec 24, 2013 at 5:58 AM
    BDSKJChris
    Albany, NY
    bg moa and cf5 every oil change...cf5 goes in the tank and moa goes in the oil. they also make 44k which is a great in tank injector cleaner...also if i run synthetic the only oil i would use is bg as it exceeds european standards (better than us oil standards)
  14. Dec 24, 2013 at 7:51 AM
    Bsheriff11
    Brandon
    2000 Limited T4R
    Click My Sig Homie
    Not saying it can't happen, just saying what it says on the bottle, and I have never had it happen to me.
  15. Dec 24, 2013 at 12:44 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    What are you trying to accomplish?
    I use Techron (in my gas) twice a year as a maintenance item. Never had a need to do anything else. Truck runs fine and I've been using Mobile 1 since new.
  16. Dec 24, 2013 at 12:46 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    What is seafoam suppose to do? Ive heard this stuff does wonders. How do I know if I really need this. Thanks
    PapaBear likes this.
  17. Dec 24, 2013 at 12:55 PM
    fyremanpat
    fyremanpat Well-Known Member
    Pat
    757
    2013 DC LB TRD Sport w/Entune
    OME 886x and 5100's all the way around. Toytec AAL. Phillips x-treme vision headlights. 886 reverse lights. Borla exhaust. 20% tint. Hi 6 mod. 285/65/18 Nitto TG on 18" Moto Metal 955's. Airaid intake. Scanguage2.JBA LT's.GC Grill..more to come.
    Been using Seafoam for years on hundreds of cars without a single O2 sensor issue...or any issue at that. Very safe and simple to use. There is way harsher products out there that work better but you have to use it in moderation... OMC Engine Tuner for example...very harsh on carbon build up. Works great but will take skin off.
  18. Jul 16, 2017 at 8:15 PM
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    IMG_3178.jpg Saw this at costco today. 6 pack for 12$. Engine runs great but just wondering if it would benefit from throwing 1 in every couple of months especially for a little over 2$'s a pop. Or leave it alone at 50k with no problems yet. Thoughts?
  19. Jul 16, 2017 at 8:22 PM
    Glamisman
    Glamisman Well-Known Member
    why not just use Chevron gas with Techron all the time?
    Slvr14tacoma likes this.
  20. Jul 16, 2017 at 8:29 PM
    PapaBear
    PapaBear Never test how deep the water is with both feet.
    Austin
    SIN CITY
    07 DCSB PR 4.0... Aaaand she’s GONE
    Soft Suspension Hard Rubber ®
    I should probably be a Seafoam rep at this point. Seafoam says it's safe to use with o2's, but I would test the limits. I'm just about to do a full clean, maybe a little overkill but I'm going to test if using the spray and pour versions will help in separate ways or do the exact same thing. My AutoZone has pour seafoam on sale for $6.99. Seafoam spray is used after the maf at the throttle body, seafoam pour is used in a vacuum tube, preferrably on a Tacoma, you should disconnect the vacuum tube from the brake booster and pour slowly. Always have someone help by keeping rpms at like 1500 don't quote me but I believe your suppose to pour faster as you get to the bottom of the bottle to choke the engine and create a hot soak in the cylinders. Let it sit for 15-30 min and start her up again revving hard but not too hard to burn off carbon and create the famous white smoke. If you plan on changing your oil, pour an ounce of seafoam per qt of oil into the oil fill tube and drive at least 200 miles I believe. Some people have reported only driving like 10 miles and the oil already gets significantly darker in color. Change the oil there after. It can also be put in the fuel tank too so that it is used everywhere through the drive train to help eliminate carbon deposits. Use seafoam transtune for transmission and power steering. Pouring it in power steering will essentially do the same thing as regular seafoam does to engine oil so use it before you plan on changing PS fluid. I don't believe it is just "snake oil" as some have stated.
