Seafoam
Discussion in '1st Gen. Tacomas (1995-2004)' started by bellassaiw10, Jul 9, 2010.
  1. Jul 9, 2010 at 12:26 AM
    bellassaiw10
    bellassaiw10 [OP] Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Thinking about seafoaming my taco and was wondering if there's any step by step instructions on doing this. Searched and only found a few threads thanks again
  2. Jul 9, 2010 at 7:18 AM
    toyotadan
    toyotadan Member
    washington
    98 4x4
    just pour in full tank of gas and drive.
  3. Jul 9, 2010 at 7:29 AM
    Danosabre
    Danosabre Well-Known Member
    Dan
    Gardner,Ma
    09 TRD Off Road
    Extang Trifold bed cover,DDM 55W 6000k HID, maglight, Vent visors
    Some guys put it in the vaccuum lines, but I have no idea how.
  4. Jul 9, 2010 at 7:37 AM
    kinetik873
    kinetik873 Well-Known Member
    Josh
    Springfield, Va.
    '08 TRD
    OME 3" lift, ARB bumper,DTRL, CB radio in console, 5lb fire extinguisher in bed. SockMonkey decals, Allpro rear bumper, UWS 42" bed box, Wet Okoles all around, snorkel, Pioneer Av3200, ..yadda yadda yadda
    For the vac. Lines, the search button is your friend.
  5. Jul 9, 2010 at 7:47 AM
    shift96
    shift96 Well-Known Member
    Why?
  6. Jul 9, 2010 at 8:03 AM
    dangerbird
    dangerbird Well-Known Member
    Tacoma SR5
  7. Jul 9, 2010 at 8:08 AM
    shift96
    I call Bullshit on this. Sure it probably works but why? I had 300K on my old taco and never did any Voodoo Magic Potion additives in it. Ran like a top the day I sold and burned NO oil at all. Just drive it and move on.
    What happens when you Seafoam it and break a big peice of carbon loose and it breakes a piston ring. Think about it
  8. Jul 9, 2010 at 8:45 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    +1000
  9. Jul 9, 2010 at 9:05 AM
    BajaTaco96
    BajaTaco96 Well-Known Member
    Silver Springs, FL
    1996 Toyota Tacoma 4wd, 3" suspension lift
    K&N, ToyTec 3" front spacers, 3" Fabtech AAL's, Flowmaster exhuast, no cat, Exedy Stage 2 clutch
    WE GET POINTS NOW?! :rain:
    haha I use seaform in my tank since places near me might as well be running straight water, even with me using premium. But when it comes to people putting that in their vacuum lines, I'll let them do it. I'm running nice and strong at 230k miles. Bottle in the tank every now and again.
  10. Jul 9, 2010 at 9:17 AM
    shift96
    I think you should put some Aunty Oata May's Mystery Oatmeal Extract in the Vacuum line. I hear it Douche's out the whole motor and make your radio work better
  11. Jul 9, 2010 at 9:49 AM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    i have put the seafoam in mine a few times. only after i have sunk my truck in mud or water. it dries up all the water out of the engine. i do 1/4 can in the vacume lines, 1/4 can in the oil right before i change it and the other half of the can in the gas tank.. and i have sucked water into my engine 4 or 5 times and done that right after and she still cranks after all those times ive sunk it. its good to do if you only do a very little and very seldom..
  12. Jul 9, 2010 at 9:52 AM
    shift96
    If your getting that much water in your engine you have bigger things to worry about than Seafoam :D
  13. Jul 9, 2010 at 9:54 AM
    98_Mud_bug
    lucedale Ms.
    i change all my diff fluid, oil, filters (oil and fuel), and clean the eigine out and she still runs 500+ miles a week.. ive put my truck in a few places that it shouldnt have been ha ha
  14. Jul 9, 2010 at 10:27 AM
    beefcake
    beefcake J-rob
    J-Rob
    Central California
    98 4WD V6
    Debadged,Deck Plate mod, Helix throttle body spacer, magnaflow two chamber, smoked corner marker lamps, cb radio, smoked headlights, grillcraft mesh grill, URD short throw shifter, ultagauge, billstein 5100 front struts, spidertrax 1.25 spacers on all four
    search seafoam, there is a diy thread on the 1st gen for seafoam doing it thru the vacuum line on the back of the brake booster
