Seafoam
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Feb 4, 2011.
  1. Feb 4, 2011 at 4:12 AM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    When is the best time to seafoam your truck to get the most out of the product? Right before an oil change? Where is the best place to pour the seafoam into?
    Thanks
  2. Feb 4, 2011 at 4:41 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    I dont use it.....
  3. Feb 4, 2011 at 9:09 AM
    DaytonLax14
    Corey
    Ohio
    congratulations would you like a cookie or something?
    anyone else?
  4. Feb 4, 2011 at 9:14 AM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Hahahaha I'm sure he would love a cookie, as do I. But I have used it a couple times and never seen any difference. Used it to clean out a old gas tank and it kinda worked.
  5. Feb 4, 2011 at 9:16 AM
    ColtsTRD
    ColtsTRD .....
    Scott
    AZ
    2005 TRD DCSB
    I heard the best place to use it is through the air intake... :notsure:
    Edit: I'd use it before an oil change...so you can drain out any shit that gets free'd up
  6. Feb 4, 2011 at 9:44 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    It's best to suck it through a vacuum hose.
    This is what I do:
    Wait until you have 1/2 tank of gas.
    while the engine is idling, you pull a vacuum hose and stick it in the can and let it suck the seafoam out of the can until the engine starts to bog, then pull the tube out and give it a little throttle via the throttle body. Repeat until you've used about half the can, then pour the rest in the gas tank.
  7. Feb 4, 2011 at 10:11 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    seafoam "suppose" to clean out dirty stuffs from your engine. i used on my small car and i can see smokes coming out foggy up the air when you step on the gas. doesn't hurt to let it sip a few. but one bottle cost you $10 or so.
  8. Feb 4, 2011 at 10:16 AM
    .Trdtaco315.
    .Trdtaco315. Well-Known Member
    Will
    Santa ana
    03 Trd SR5 Prerunner
    yeah the vaccum line is the best spot for it. i did it to my 03 taco and alot of smoke was coming out of the tail pipe. it works good, my truck runs alot smoother.
  9. Feb 4, 2011 at 10:42 AM
    DaytonLax14
    Corey
    Ohio
    i dribbled half into the vaccum line and put the rest in the gas tank....went for a drive and my truck was smoking like no other haha looks like it did it's job
  10. Feb 4, 2011 at 11:03 AM
    betardfoosier
    betardfoosier Well-Known Member
    Kansas
    2000 TRD SR5
    3" Skyjacker, 33x10.50 AT/TAs
    I was always told not to put it in the oil, and saw firsthand what it did to my dad's Cherokee. Cleaned out all the gunk and it got jammed in other places. Killed his Oil Pressure sender, and caused main seel weeps. Great when sucked up in vacuum lines and gas tho.
  11. Feb 4, 2011 at 11:07 AM
    macgyver
    Brad
    Canton, GA
    I doubt the seafoam caused the main seal leak.
    Jeeps pretty much all come from the factory with a leaky rear main seal. I think it's standard equipment when you buy it. :D
  12. Feb 4, 2011 at 11:20 AM
    kingbrian
    kingbrian Resident Big mouthed Fat ass.
    brian
    I.E. CA.
    98 2.4 5 speed xtracab
    Fagtech spindles, Doug Thorley header, Spintech muffler, JVC headunit.
    yeah seafoam is petroleum based, so it more than likely just cleaned the gunk off the leaking seal.. you should payed extra for the non leaking seal.. standard equipment sucks.. in the long run its worth it. :)
  13. Feb 4, 2011 at 11:23 AM
    mrp192
    mrp192 REALLY!!
    Brent
    Cheney WA
    98 V6 4x4 limited
    Stereo, boobies
    pull off the brake booster line.. that work the best!
  14. Feb 4, 2011 at 11:32 AM
    ERIC
    ERIC Well-Known Member
    Eric
    Orange County, CA
    2002 Impulse Red TRD PreRunner SOLD
    Pioneer double din navi head unit and four 5x7 alpine speakers, westin light bar, procomp lights, head and tail lights, black billet grille, billet antienna, gibson headers and cat back exhaust, afe cold air, uni chip programmer, Bilstein 5100's, Pro comp wheels and tires, tint, blacked out emblems, innu roof rack, yakima basket, foglight mod...
  15. Feb 4, 2011 at 11:33 AM
    racerxtaco
    racerxtaco Well-Known Member
    Joey
    virginia
    01 xtra-cab 4X4 w/cap
    i agree with not putting it in the crankcase. as a general rule of thumb, only oil goes in there, no goofy additives to water the oil down or thicken it up and no cleaning aganets. i do however like the vaccuum line and gas tank treatment. when it comes time for one of our vehicles to be treated ( once a year) i will run one can through the gas tank, then run one full tank with no treatment and then do a half can through the vaccuum line and dump the other half in the gas tank. i will run that tank to about 1/4 then fill up and change the oil. good for another year. my dad has been doing that since the eightys with all of his cars and passed that habit down to me. if anything its just something fun to do to the car that is harmless and something that reminds me of him.
  16. Feb 4, 2011 at 12:15 PM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    After about 30 years of neglect or several hundred thousand miles. Though I've never seen any noticeable results from it.
    But when I'm about to tear down a car for a rebuild or major internal engine service due to age and wear, I usually sea foam it. Can't say why. I'm impulsive.
    Did it on a series rover a while ago, and recently a volkswagen. Ended up taking the heads off... looked as gunky as any engine ever. I believe it does nothing. It might unstick a stuck valve if you were trying to pawn off a busted car on someone. But its not going to wire brush your valve stems and nothing is going to clean your injectors while still in the car.
  17. Feb 4, 2011 at 12:32 PM
    Mr.Tacoma
    Mr.Tacoma Well-Known Member
    toronto
    DoubleCab4x4
    TRD Exhaust, Side step bar & ARE cap
    I am a great FAN of it..agree with macgvyer n coltsTRD.
    Its important to add 1/2 can or less just ONLY idle for 10min or less and drain rightaway. Its a good idea to do one more oil change. Doing this procedure on a high kms/miles truck for FIRST TIME might be counter productive.
  18. Mar 7, 2011 at 7:00 PM
    jjoba79
    jjoba79 Member
    josh
    San Antonio TX
    02 4X4 SR5 Reg Cab
    Got the new frame from toyota from the big recall. Replaced a bunch of stuff underneath. I bought this truck about 8 months ago for $1k from a buddy! Deal of my life.
    Have any of you seen this fix an IAC valve problem? I am almost positive that is what I have going on. Low idle on cold days, high idle after warmed up on warm days.
  19. Mar 13, 2011 at 9:17 PM
    Kelsey
    Kelsey Camping Lover
    Jasper, Alabama
    2004 Doublecab TRD 2WD
    K&N, Redline Differential Fluid
    Why don't you just remove the IAC and manually clean it? More thorough.
  20. Mar 17, 2011 at 4:25 PM
    rockostaco
    rockostaco Member
    ryan
    bellefonte pa
    98 regular cab 4wd
    I was told to add it to the gas to clear out a valve that got carboned up from someone putting on cheap plugs and wires?
