seafoam
Discussion in '2nd Gen. Tacomas (2005-2015)' started by USAONE, Nov 21, 2011.
  1. Nov 21, 2011 at 4:42 PM
    USAONE
    USAONE [OP] Well-Known Member
    2011 DC Tacoma Prerunner SR5
    Stock
    On a new Taco with less than 5000 miles, will it hurt to add a can of Seafoam ever 6 months or so to tank of gas to help keep things clean? I have had great results with older engines. What can it hurt?
  2. Nov 21, 2011 at 4:48 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Probably wont hurt anything but I personally wouldnt waste the money. I dont think you'll gain any benefit from running 2 cans through the tank a year.
  3. Nov 21, 2011 at 4:54 PM
    USAONE
    Stock
    One can treats 8-25 gallons, I think by way of tank.
  4. Nov 21, 2011 at 4:57 PM
    USAONE
    Stock
    This one has V6 and is run about 50 miles a week. Thought it might help with moisture. you're probably right though.
  5. Nov 21, 2011 at 5:32 PM
    USAONE
    Stock
    Why? Any bad results?
  6. Nov 21, 2011 at 5:34 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    I used it. It didnt do anything bad. The engine runs a little smoother
  7. Nov 21, 2011 at 5:43 PM
    Battle Pope
    Battle Pope Christ-a-licious
    Korben
    Class 6
    Automatic 5 Lug
    squash air freshner
    put it in the crank case.
  8. Nov 21, 2011 at 5:45 PM
    Battle Pope
    Korben
    Class 6
    Automatic 5 Lug
    squash air freshner
    dont 4 get the zoloft and plastic fork.
  9. Nov 21, 2011 at 7:06 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Yes, but yours is 15 years older and with (probably) significantly more miles
  10. Nov 24, 2011 at 3:40 PM
    YodasYota
    YodasYota I'm here for the chicks.
    Yoda
    Orange County CA/the Dagobah system
    White 2005 2.7L
    aFe pro dry s drop in, secondary air filter delete, "Black Box" mod, debadged, tinted windows, Hawaiian print all weather seat covers, rubber all weather floor mats, 300mm Broadway rear view mirror, hyper yellow headlights, surf wax melted in, on and around the bed (shes dirty), LED brakes, side markers, rear turn signals, license plate, and interior lights. A cracked tail light that I fixed with some tape, 235/75/15 All Terrains. $$$$NearFuture$$$ Alloy 15x8's, DT headers, upgrade speakers and head unit, THULE bed rack or a ladder rack. Than I think I'll be pretty satisfied.
    so how much of the can do you pour into the vacume line. and the rest goes into the gas tank? also can you add it to your oil? sorry im new.
  11. Nov 24, 2011 at 7:21 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    youtube it
  12. Nov 24, 2011 at 8:45 PM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    I poured 1 can after 10,000 mile because it was on sale for $6.
    I wouldn't bother with the crankcase method until 100k. lol
  13. Nov 26, 2011 at 12:57 PM
    ToyComa92
    ToyComa92 Write your love, Then your anger.
    Jon
    Conifer, Colorado
    2006 Tacoma TRD sport Debadged
    Heated katzskin leather, Black TRD sport wheels, Bilstein 5100s, Toytec 2" Springs, Deaver 2" AAL, Pioneer AVH4400BH, Ultragauge, Weathertechs front/rear,
    With a truck at almost 112,000, Getting an oil change at 112,356 should i consider any of the above methods to help me truck out a little bit? its a V-6
  14. Nov 26, 2011 at 1:54 PM
    SCFirefighter
    SCFirefighter on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    What is the recommended interval for doing this on a 2nd gen?
  15. Nov 26, 2011 at 8:35 PM
    myname150
    myname150 Well-Known Member
    You have less than 5K miles...could deposits already build up this early on??
    Maybe just go with the fuel treatment stuff from Lucas for now...seafoam later on...waaayyy later on
  16. Mar 22, 2012 at 7:00 PM
    USAONE
    Stock
    I only put it in a full tank of gas not in intake. Once every 10,000 miles should keep it clean.
  17. Mar 22, 2012 at 7:26 PM
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    I put some in a turbo'd lexus is300(2jzge-t) around 58k miles after having repeated misfires...drove it around the block and it fixed it up, even noticeably ran better.
    i'd think maybe 1/2 a can every 10k miles should do the job. it would work better if you had an engine operating time to go off of rather than mileage.
    Used to have to use this industrial citrus cleaner on some turbine engine manifold supply lines...oh the fun of playing with JP-8..
  18. Mar 23, 2012 at 6:24 PM
    USAONE
    Stock
    Seafoam is very good> I only add to my gas and never have put it in the intake. I guess that would be ok on an old dirty engine. I think a can ever 10,000 miles in the tank will keep it clean. My 99 Taco would not idle when I got it (used 145,000) and one can fixed it right up.
