Seafoam
Discussion in '1st Gen. Tacomas (1995-2004)' started by TruthInLies313, Feb 25, 2009.
  1. Feb 25, 2009 at 11:29 AM
    TruthInLies313
    TruthInLies313 [OP] Well-Known Member
    Blaine
    Texas
    05 V6 TRD Sport DC
    Tinted, 5701 Viper Alarm Electric Start, 6 Inch Fabtech Lift, 17'' XD Hoss Rims, K&N 77 Series Intake, BHLM, Black Emblems, Color Matched Dash rings, 2 JL 10's, Pioneer Double Din Head Unit
    How do you do it? What will I need? Where can I get it? Can a somewhat handy person do it? :confused:
  2. Feb 25, 2009 at 11:55 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    You can it at any auto parts store, and you just need a little cup so that its easy to suck up into your brake booster line. Its real easy! Just dont suck too fast and kill your engine.
  3. Feb 25, 2009 at 1:56 PM
    2004Taco
    2004Taco Financially Irresponsible
    Lou
    California
    04 Double Cab PreRunner SR5 TRD
    wait... what kind there a bunch of different seafoams... i use the Fuel ad. Just pour the hole thing with you fill up.
  4. Feb 25, 2009 at 1:59 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    i want something that could clean the engine. if there is any. i have done the fuel one. but what is the one for the brake booster line? what does that do?
  5. Feb 25, 2009 at 2:13 PM
    Snyperx
    Snyperx Seniore Marcos
    The stuff in the red and white can is all you need. That does the crank case, fuel, and intake.
  6. Feb 25, 2009 at 2:48 PM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    instructions are on the can, but! I've got the time. take one third of the can, pour it into a cup, remove the brake booster line or the pcv hose. they both go to the manifold and into the motor, both lines have suction, so you just suck up 1/3 of the can into either of the two lines, not so fast that the engine dies, but as fast as you can without it dieing. as soon as your done, shut off the truck, leave it for 15-20 mins, when you start the truck it's gona burn off all of the seafoam and all the gunk that was built up in the motor. it's gona smoke for about 10 minutes. thats it thats all for the brake booster/pcv hose. if you do it in the crank case, pour in 1/3 of the can in, drive 60-100miles and then change the oil and filter. for the gas tank, pour the last 1/3 of the bottle into the gas tank at fill up, run it through and your alllll done! i advise changing the fuel filter shortly after you run it through the gas tank.
    good luck! it works wonders
  7. Feb 25, 2009 at 3:01 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    Thank you. And I know this is a dumb question. What is the crank case, and where can I find the brake booster pcv hose? I know i know, i am dumb.
  8. Feb 25, 2009 at 3:06 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    PCV is the easiest to get at with our trucks, here's a pic of the pcv valve, you disconnect the hose right at the valve and feel the suction. don't be alarmed when your truck idles weird with it disconnected.
  9. Feb 25, 2009 at 3:08 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    here is another pic, your gona want to know all of these parts anyways, so just keep this pic for reference [​IMG]
  10. Feb 25, 2009 at 3:12 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    your awesome rab89
  11. Feb 25, 2009 at 3:13 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    your throttle body is clean. wish mine was.
  12. Feb 25, 2009 at 3:14 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    glad I can help!
  13. Feb 25, 2009 at 3:16 PM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    I use Seafoam Deep Creep, which is a spray version of the stuff. That way all you do is disconnect one of the vaccum lines and spray it in there. In regards to throttle body cleaning, it's generally better to remove the whole throttle body and clean it that way. You can do a much better job, plus its not the most difficult thing to do.
  14. Feb 25, 2009 at 3:21 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    is there a write up on the the throttle body cleaning?
  15. Feb 25, 2009 at 3:21 PM
    GASH
    GASH Well-Known Member
    Josh
    Albuqueruqe
    2021 AG Off-road
    I just did my truck because I was getting crappy MPG. Just so you know your check engine light might go off afterward. Mine did and I was like oh crap what did I just do! It was just a misfire and my MPG are back within my normal range.
  16. Feb 25, 2009 at 3:28 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
  17. Feb 25, 2009 at 3:42 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
  18. Feb 25, 2009 at 3:45 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    Would a throttle BODY spacer be good? Is it worth it?
  19. Feb 25, 2009 at 4:10 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    The first one on the list will do ya just perfectly
    I want you to listen hard n listen good, Throttle body spacers are 100% a myth, Never believe anyone who says theirs added power, because it didn't.
    it will make a neat sound, but that is it!
  20. Feb 25, 2009 at 4:17 PM
    TruthInLies313
    Blaine
    Texas
    05 V6 TRD Sport DC
    i listened carefully. just the gasket is all i need. save the money for better stuff.
