Seafoam
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scosh, Dec 5, 2009.
  1. Feb 12, 2013 at 5:00 PM
    #241
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    maybe the cat was a bit clogged before, now it's really clogged! maybe timefor a new one!
  2. Feb 12, 2013 at 5:54 PM
    #242
    toys4ever
    toys4ever Well-Known Member
    PA
    01 4x4 4-banger stick
    puff the magic dragon!!!
  3. Feb 12, 2013 at 5:56 PM
    #243
    ronman737
    ronman737 Dangerous
    Ron
    Greenville, SC
    2008 4Runner 4x4 Sport
    That sucks man. That stuff really does loosen crud up.
  4. Feb 12, 2013 at 6:31 PM
    #244
    socal16
    socal16 Well-Known Member
    Diego
    las vegas nv
    08 trd offroad black 4x4!!!
    wheels and tires, k&n cold air intake, limo tint,bhlm,TRD seatcovers, OME lift
  5. Feb 12, 2013 at 6:55 PM
    #245
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Well now the check engine lights gone and runnin better than before the sea foam so I guess it's done it's job. Just had me pretty worried for a little while
  6. Mar 17, 2013 at 5:16 AM
    #246
    Domc20
    Domc20 Well-Known Member
    Dominic
    Baltimore, MD
    2001 Tacoma
    Retro Fitted headlights,HID headlights(80000k),Satoshi Grill Mod, LED tail lights, Magnaflow exhaust , Spectre CAI, 2.5inch spacer lift , Nitto Terra Grapplers 285/70/17, XD Revolvers ,2" blocks rear
    Finally did seafoam in crankcase,gas, and vaccum line..... Not much smoke tho.
  7. Mar 17, 2013 at 9:05 AM
    #247
    Norton
    Norton Senior Member
    Colorado Springs, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C w/12TRDTacoma's Qwikchange Hub & 2.5" RIP-Modded Pulley, Roostfactor's Pulley Wrap Mod; FPR Mod; JustDSM Tune via HPT MPVI2; mightytacoman Intercooler Tank; aFe POWER Magnum FLOW Pro DRY S Air Filter; OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; NSB-AGM27F Battery w/HKB Adjustable Voltage Booster & Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Trident904's MT ADM; BFG All-Terrain T/A KO2s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; BPF TRD Skid, Tow Hook, & Cooling Panel; jsi's Locker Anytime, Up2NoGood's 2Lo Module; ramonortiz55's Always on Power Outlet Relay, ND4's Fog Light Anytime, & Crom's Speed Bleeder Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades; ThreatLevelMidnight's Wireless Charger; 4Runner 4X4 & FJ Fog Light Switches; redtaco2007-inspired LED License Plate Lights; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; loginfailed-inspired Speedhut Boost & AFR Gauges in a Lotek Pillar Pod; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; TacomaBeast Glove Box & Console Organizers; Husky Floor Liners; UltraGauge EM; mesojdm's Ultimate LED Dome & Map Lights & GASSHOLE; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Cali Raised Led Bed Stiffeners; Pop & Lock Power Tailgate Lock w/TacomaTruckParts Support Bracket; ARE Z-Series Cap, SolarGard Tint; BlendMounted & MirrorTapped Uniden R3; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    I had exactly the same experience when I did mine (with about 65K miles on the odometer).
  8. Mar 17, 2013 at 3:07 PM
    #248
    Domc20
    Dominic
    Baltimore, MD
    2001 Tacoma
    must've not been too dirty
  9. Mar 17, 2013 at 5:03 PM
    #249
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Use it at your own risk. I've thought about doing mine but there's a part of me that says don't do it. Maybe if I experimenting an issue ill try it.
  10. Mar 17, 2013 at 6:14 PM
    #250
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    If your vehicle has lots of miles and has never been seafoamed or taken care of thoroughly, seafoam is a bad idea. You'll break loose so much crap inside that that you'll destroy your cats.
    Preventative maintenance is only useful from early on.
    People with low miles or people that seafoam often won't see much smoke because there's nothing in there to burn out.
  11. Mar 17, 2013 at 7:56 PM
    #251
    Domc20
    Dominic
    Baltimore, MD
    2001 Tacoma
    i have 193,000 miles and saw little smoke
  12. Mar 17, 2013 at 11:23 PM
    #252
    RGosen
    RGosen Well-Known Member
    Christ would now agree, don't get yourself nailed to a tree
    Kamloops B,C CANADA
    2000 toyota tacoma 4x4 2.7
    Cold air intake
    Ya same with me I have 164,000 miles and didnt see much smoke and I used half a can thru the break boost vaccume line. Didnt do anything good or bad to my 2000 tacoma 2.7
  13. Mar 18, 2013 at 3:34 PM
    #253
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Just means you've taken care of your trucks and there's not much to clean out!
  14. Mar 18, 2013 at 4:24 PM
    #254
    06texasedition
    06texasedition Well-Known Member
    Picayune ms
    06 Tacoma Texas edition(RIP) 14 tundra limited 4x4
    3" rough country lift. Blue interior lights courtesy of jumper led. Led tail lights avid front and rear bumper guard with 4 Hellas on front. Borla dual exhaust blue led reverse lights color matched satoshi grille
    I have never used sea foam and don't know if my uncle or dad did when they had it. I don't have a cat on my truck. What do y'all recommend I do. To seafoam or not seafoam that is the question
  15. Mar 18, 2013 at 5:08 PM
    #255
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Well, with no cats, I don't think there's much to clog. Go for it, man!
  16. Mar 18, 2013 at 5:32 PM
    #256
    06texasedition
    Picayune ms
    Lol my cat was stolen so my dads buddy just welded a straight pipe to my exhaust
  17. Mar 18, 2013 at 6:09 PM
    #257
    Krysstoffurr
    Krysstoffurr Member
    Atlanta
    13 DCSB 4x4 OR
    What do you guys think of removing your cat before sea foaming? I'm concerned of clogging my cat on my 03 s2000 that has 81,000 miles. I'm sure it will piss off my neighbors for a little while, but im sure they will get over it
  18. Mar 19, 2013 at 3:00 PM
    #258
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Go for it! While you're at it, pull the O2 sensors so you don't coat them with the nasty stuff.
  19. Mar 25, 2013 at 9:27 PM
    #259
    fouillard13
    fouillard13 Well-Known Member
    Riley
    Canadia
    1998 tacoma 4x4
    i am going to seafom right after throttle body. how much should i use? i got 130k miles
  20. Mar 30, 2013 at 7:09 PM
    #260
    Taylor
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Doesn't really matter as long as you do it slowly. Maybe 1/3 can to start off with?
