Seafoam
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scosh, Dec 5, 2009.
  1. Sep 9, 2013 at 9:33 PM
    #301
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
    well i did it and ran truck for around 15 mins. i didnt see much smoke. is that good?
    half in tank and 1/3 in intake hose like gear head
  2. Sep 9, 2013 at 10:00 PM
    #302
    seedless024
    seedless024 Well-Known Member
    norman
    SL,UT
    01' TRD ext cab white
    learn something new everytime i come on this site.
  3. Sep 9, 2013 at 10:21 PM
    #303
    seedless024
    norman
    SL,UT
    at 3,300 miles since my last change, but just got laid off so whenever i get one my first checks going to a trusty can of seafoam
    ive always just dumped it in my tank and never thought adding to a vacuum line or even the crankcase. ive read the bottle but didnt think of the relevance it might truly have. dumb statement i know but gimme a break lol and on top of that i wouldnt have never known what line or how much... good part about loosing my job is the ammount of reading on this site ive done
  4. Sep 10, 2013 at 6:58 AM
    #304
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
  5. Sep 10, 2013 at 7:12 AM
    #305
    JuansTaco
    Juan
    gilbert az
    gunna put some in my oil and drive to school and back then change my oil
  6. Sep 13, 2013 at 6:27 AM
    #306
    Tribull
    Little Rock, AR
    I did mine last night: 1/2 in the gas tank, about 1/3 in the vacuum line, the last almost 1/6 in the crank (will be changing the oil this weekend after a short trip). Saw almost zero smoke, I guess she was clean!
  7. Feb 11, 2014 at 4:48 AM
    #307
    flatblack
    flatblack Well-Known Member
    CDA
    95.5 Tacoma 3.4 Manual
    HMMMMMM!!!
    Thanks, man: I might actually do this now
    I never did cause, like you mentioned, I read the way it's typically done doesn't distribute it to all the cylinders on our yotas
    I just turned 223k; so, it could probably use it
  8. Feb 11, 2014 at 2:08 PM
    #308
    Gear Head
    Gear Head Well-Known Member
    Jacob
    Winston Salem, NC
    96 Tacoma
    fj60 front, fj80 rear, full hydro, 5.29's, welded, twin sticked 2.28/4.70 duals, 39.5's, inboarded 63's
    Nice man! 241k here and running strong
  9. Feb 12, 2014 at 6:59 PM
    #309
    Gear Head
    Jacob
    Winston Salem, NC
    96 Tacoma
    Smoking in the engine bay? Exhaust or vacuum leaks maybe :notsure:
  10. Feb 23, 2014 at 3:43 PM
    #310
    Icemansurf
    Icemansurf Member
    02 TRD
    Seems like everybody seafoamed the intake and the gas tank at the same time. Is this a better way to do it or does it matter if I do them at separate times? I was going to do the oil today and the engine/gas tank later this week. This will be my first time seafoaming my '02 with 210k miles.
  11. Feb 23, 2014 at 3:47 PM
    #311
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    They sell a aerosol can now. That's what I used. I sprayed half the can in the intake, let it sit the 15 min it said to, and then ran the truck hard. Came back and used the rest of the can and let I sit a few hours, them again ran the truck hard. You would not believe the crap that came out of the tailpipe
  12. Feb 23, 2014 at 4:35 PM
    #312
    Got2ryde
    Got2ryde Well-Known Member
    Ryder
    Maryland
    AC OR 6spd silverstreak
    Off Road tow pac. GTCovers wetskinz seat covers, Direct wired Escort 9500xi, Leer 180 w/ARB awning, bed mat, extra d-rings, rear dif breather relocated, Weathertec mats, Elite front with Warn M8000-s and Rigid D2's, BAMF sliders, ABS killswitch, Kicker Hideaway sub, UltraGauge, ATO rear with flush mount duallys, FJ Trail Team black rims w/Duratracs.
    Need to do this to my 04 and MAF cleaning too.
  13. Feb 28, 2014 at 10:21 AM
    #313
    mischieval
    mischieval New Member
    Tammy
    Florida
    02 DBL Cab Tacoma Prerunner
    Used seafoam in my 2002 2wd automatic Prerunner and really liked the results. Put half a can in the oil and slowly poured the other half in the brake booster vacume line. I let the truck sit about 10 minutes drove it about 40 miles and changed the oil. Oil was pretty thin and very nasty. Truck didn't smoke as bad as others I've seen. My taco is around 191000 miles. This was my first time using it anywhere but the gas tank and I definitely felt the truck is quicker on acceleration and idles smoother. My 2 cents.
  14. Feb 28, 2014 at 5:02 PM
    #314
    DecaturTide
    DecaturTide Well-Known Member
    River City
    2016 SR AC BARCELONA RED
    If I was going to use Seafoam just in the gas tank, how much should I use?
  15. Feb 28, 2014 at 6:29 PM
    #315
    smmarine
    Melbourne FL
    I ran 2 bottles at once in mine while low. Wanted to get a real good concentration of it. Didn't hurt anything, no CEL
  16. Feb 28, 2014 at 6:38 PM
    #316
    DecaturTide
    River City
  17. Feb 8, 2015 at 3:08 PM
    #317
    tacolover87
    tacolover87 Well-Known Member
    Eugene, Oregon
    2005 DCSB TRD Sport
    Did a seafoam treatment through the vac line Gear Head directed to use. It smoked really good for almost 10 min. I also cleaned the intake, throttle body, and maf. At 227k it runs like new again. Feels more responsive with throttle and idles smoother. I plan on doing a fuel treatment when i get closer to empty and will do a oil treatment in a couple thousand before oil change.
  18. Feb 8, 2015 at 6:12 PM
    #318
    Darryle
    Darryle It is just a truck
    Darryle
    Weatherford, Texas
    If you have a squalling power steering pump, put a couple of thimble full amounts in and sit back and listen.
    I had a Napa store back in the early 90's when one day the owner of Seafoam showed up and wanted to go demo this stuff to customers. I had never heard of it before then. We did about 30 demos over the next few days, but 2 stood out.
    Bart May had a 4wd 81 Silverado with a 305 automatic, dog of dogs. Power steering whine, hard shifts and would not run unless you kept your foot on the pedal feathering it. Seafoam cured them all in one treatment.
    20 minutes later, he ordered 10 cases of the stuff.
    School district had a diesel bus that would run for a few hundred miles and then slowly choke down and have to be towed back to the bus barn. Pulled the fuel filter off and filled it with Seafoam. We took it on a 30 minute drive, it would barely run as we pulled out of the barn. When we came back it was idling like it should and Brian said it didn't run this good or smooth when it was new. The school bought this stuff in 55gal drums after that.
    With anything, you can improperly use the product, but when used correctly, there is no harm to be done.
    If it wasn't for a love of fishing, Seafoam wouldn't exist.
  19. Feb 15, 2015 at 11:10 AM
    #319
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Seafoam makes an awesome transmission additive too.
  20. Feb 16, 2015 at 4:41 AM
    #320
    hondamxracer
    hondamxracer Well-Known Member
    When using seafoam in the crankcase, how many oil changes does it take after the initial drain to flush the system? Do you recommend running a cheaper oil for 500 miles to finish removing all the gunk before switching back to the oil of your choice?
