Seafoam
Discussion in '1st Gen. Tacomas (1995-2004)' started by Scosh, Dec 5, 2009.
  1. Apr 5, 2010 at 6:28 PM
    #81
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    seafoamed the motor for the first time ever tonight. The idle sounds better i know but im not sure about acceleration just yet. Put 1/3 of the can into the vacuum line as per instructions then just saved the rest for some other time. Didnt bother putting it in my tank since i run supreme gas all the time anyway.
  2. Apr 6, 2010 at 8:40 AM
    #82
    ST77
    ST77 Wandering doesn't mean you're lost
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    If you run it through the fuel system it will clean out the injectors... that's where you may see a difference in throttle response or acceleration.
  3. Apr 6, 2010 at 1:34 PM
    #83
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    oh ok good to know, should i put the other 2/3 of the can into the tank then. I got less then half a tank right now maybe i should wait until next fillup
  4. Apr 6, 2010 at 1:36 PM
    #84
    ST77
    Brian
    Sandy, Or
    2018 TRD OR DCSB
    Bone Stock
    Just dump it in with a full tank...
  5. Apr 6, 2010 at 1:44 PM
    #85
    KnurledNut
    KnurledNut Cracker in a Taco
    Sonova Beach
    '10 PreRunner SR5
    I've always used Sea Foam in my outboard motors and motorcycles. Good stuff. My Taco is too new for a Sea Foam treatment, but it worked wonders on my Subaru.
  6. Apr 6, 2010 at 2:05 PM
    #86
    moe1967
    moe1967 Well-Known Member
    2010 TRD DC Off-Road PreRunner
    Worked great on my yammy outboard.
  7. Apr 6, 2010 at 2:19 PM
    #87
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    Just picked up a can really nervous about the vacuum line hahah
  8. Apr 6, 2010 at 2:32 PM
    #88
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    kinda like sex for a virgin....go slow with it bud.:D no worries.
    tacobienhecho likes this.
  9. Sep 8, 2010 at 8:21 PM
    #89
    Mike P
    Mike P New Member
    Chattanooga TN
    Tacoma
    go to a Dodge/Jeep dealership and get a can of Mopar Combustion Camber Cleaner. Spray carfully directly into a warn engines TB with throttle closed. It will sound like it's about to die, hold off until engine recovers then spray more until can is emoty. When can is depleted let sit for 5 minutes....start it but don't rev it, smoke up your street and get same if not better results. No vacum line hassle. Gets all cylinders and works great. I use Seafoam myself sometimes but only straight into the gas. for more direct results the Mopar CCC is the shizzle. Been using it for years.
  10. Sep 10, 2010 at 11:24 PM
    #90
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    They also make aerosol Sea Foam... called Deep Creep.
    I just did mine through the vac line and it worked about as expected. Smoked for probably 5 minutes with the first little bit was really bad. Mine also did the diesel "run away" thing after I shut it off. It kept sputtering and shaking around for maybe 10 seconds but it eventually stopped. Then I drove around the school parking lot for awhile like a madman (with all the guys from auto class cheering me on) And changed the oil immediately after. She's runnin great now.
  11. Sep 10, 2010 at 11:49 PM
    #91
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Is this for older vehicles? or can it be used on an 06 DC with 72k miles?.
  12. Sep 11, 2010 at 11:36 AM
    #92
    Quast
    Quast Well-Known Member
    Dustin
    Mission, BC
    03 toyota tacoma 3.4L
    3'' OME lift, Deck plate mod, spidertrax wheel spacers, 12'' alpine type S sub.
    yes you can use it doesn't matter how old the engine is it will still benefit it by cleaning out the carbon build up. do as it instructs you too though 1/3 in the oil 1/3 in the gas tank and 1/3 in the vacuum line. you'll notice a difference.
  13. Sep 11, 2010 at 12:42 PM
    #93
    jandrews
    '09 FourDubDee TRD OR
    I still don't believe in it. If it was useful at all for the engine, Toyota would make money from it by adding it in as scheduled maintenance.
    Snake oil, and I'd bet money most of the smoke that comes puffing out during a seafoam "treatment" is just like the smoke that comes puffing out when your engine is consuming oil...the combustion chamber burning something other than fuel...
  14. Sep 12, 2010 at 2:43 PM
    #94
    StatutoryAPE
    StatutoryAPE Well-Known Member
    Joey
    Phoenix,AZ
    2000 Prerunner xtracab
    TRD Headers,CAI, dynomax super turbo, blacked out headlights, Smoked LED tails, Billy 5100 w/OME 881's and 5125's in rear, rear tube bumper, tint 35% front 3 windows & 5% in rear 3. fiberwerx 4.5's
    i just seafoamed my taco. feels like the truck idles a lot smoother now. didnt notice power gains though.
  15. Sep 12, 2010 at 2:51 PM
    #95
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'll continue to use seafoam, as i see the benefits from it, especially how it will clean an intake/combustion chamber out.
  16. Sep 13, 2010 at 8:11 AM
    #96
    StatutoryAPE
    Joey
    Phoenix,AZ
    My truck didnt really shoot out much white smoke. i have 126xxx miles and was sure i was gunna see a cloud behind me but it wasn't that bad, especially compared to my nissan maxima when i did it to that one it was a shit load of smoke!
    I might have done the process wrong though.
    I poured about 1/3 into the vacuum hose, then turned the truck off. put 1/3 into the oil crankcase, and the rest into the gas tank. Then waited about 2 minutes and turned the truck back on. I think i shouldve waited a little longer before i turned it back on. FYI this is the instructions straight from seafoam.com
  17. Oct 19, 2010 at 9:35 PM
    #97
    tacoman79
    tacoman79 Member
    Tommy
    Portland, OR
    "00" - 4x4,V6,AT
    I used Seafoam for the first time today and let me just warn anyone who hasn't used it yet... Get ready to be F-ing embarassed for about 15-20 min!! Shit, I didn't realize how much stuff was going to come out of my exhaust pipe. I did about a 60-40 split (40 in the vacuum line, 60 in the gas tank). I did it right before a 50 mile trip to my mom's house and I was completely embarassed going through my neighborhood billowing smoke everywhere, LOL. I had let it run in my driveway for about 5 minutes until the initial smoke stopped (after waiting 15 min for the stuff to set in) and thought it was done doing what it needed to do... Not so much. Once you get on the gas it REALLY starts coming out!! Well, once it was done smoking I do believe my truck was running smoother and it accelerated a lot better than before. I have 141,000 miles so I guess it was long overdue :)
    Colchicine likes this.
  18. Oct 20, 2010 at 8:25 PM
    #98
    MowTaco
    Kansas
    I've noticed a 1-2 mpg increase as well... went from 17-18 to 19-20 (100% stop and go in the city, much of which is pulling a trailer). I'm pretty satisfied.
  19. Oct 20, 2010 at 8:38 PM
    #99
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    your supposed to let it idle for a bit then take it for a hard drive
  20. Oct 21, 2010 at 11:11 AM
    #100
    40950
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    LOL!
    My buddy loaded up his volks bug with a tank of diesel by accident,,it looked like he was towing a fog bank when he pulled out of the station. it sputtered to a instant death a mile down the road.
    I have a can of Seafoam down in the shop,,been there for quite some time. I might try a fresh can in the tank, just to see.
