SeaFoaming!
Discussion in 'Performance and Tuning' started by ETaco23, Jan 3, 2009.
  1. Jan 3, 2009 at 3:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sorry. I was out. Looks like you got the right info. ;)
  2. Jan 3, 2009 at 3:38 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    used to run Auto tranny fluid through the carb on my old trucks every now and then, does it smoke that much?
  3. Jan 3, 2009 at 4:16 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  4. Jan 3, 2009 at 4:33 PM
    Cobra69
    Cobra69 Well-Known Member
    Taxachusetts (Massachusetts)
    02 Tocoma TRD Expedition Setup
    2002 Tacoma TRD Access Cab, Deckplate Mod.,Grey wire Mod.,Cobra CB,Ext. Diff. Breather,E-locker rear only for now,CBI Custom Winch bumper, SAW 2.0, All Pro 5" leaf packs+Bilstiens 5150-10" shocks,Cooper STT 285x75x16 on Wheelers Type B 16x8 rims, Budbuilt front+Mid skid plates, Custom transfer crossmember+skidplate,Trail-Gear sliders,custom roof-rack,Ultimate-air CO2 tank,4-Hella 500 H.I.D. Lights,Atlas 10,000 lbs winch. Custom Half-doors for the summer.
    ^^^^.........wow.........lol
  5. Jan 3, 2009 at 4:38 PM
    hoosiertaco
    ^^^yep, lotsa smoke, I think the tranny fluid through the carb made a little more smoke though, but I'm sure it was not as beneficial....
  6. Jan 3, 2009 at 5:08 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Mine smoked alot! for about 5-10 min. Good thing I live on 5 acres, out in... no where! lol. I drove around and red lined it a couple of times and it helped alot with my idle, now I just gotta check my MPG's.:)
    I did about 1/3 of the can, but I kinda think I should've done a little more.
  7. Jan 3, 2009 at 5:55 PM
    Cobra69
    So if i read the directions correct..........you disconnect the brake boost Vaccum line WHILE the truck is running and pour 1/3 to 1/2 into it then turn off the truck......wiat 5 minutes.........then turn it on to clean it out...........correct.
  8. Jan 3, 2009 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yep. BUT, pur it in slowly. If you just dump it in, you can hydrolock your engine.
  9. Jan 4, 2009 at 12:58 PM
    Cobra69
    Evertaco23 notice any improvements?
  10. Jan 4, 2009 at 1:04 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    Have done the same on some olddd engines. I have also used the sea foam on some late model vehicles and did not notice near the amount of smoke that the trans fluid produced.
    I'm not sure if it was just a coincidence or not, but the last time i used sea foam on a late model pickup of mine I threw a trouble code for a faulty o2 sensor shortly there after. Used as prescribed, and ended up having to replaced the sensor. This could have been a coincidence but I'm not sure:confused:
  11. Jan 4, 2009 at 5:58 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i do mine...........i usually shove the hose into the can, and when it feels like the engine is about to shut off.....i'll pull the hose out a bit, then back in. never have had a problem doing it this way either. and the difference is a great impovement in the way the truck idles and all.
  12. Jan 4, 2009 at 6:23 PM
    ETaco23
    Evan
    PNW
    Yep! I dont have a rough idle anymore and it seems to start and run alot better as well. I still want to check my MPG's to see if they improved.
  13. Jan 5, 2009 at 10:52 AM
    Cobra69
    So I must have a pretty clean engine................sea foamed it today just like you guys said. When I started it back up after the 5 minutes........I got a small amount of smoke for about a minute,but could definately smell carbon coming outta the exhuast.........took it for a run down the road. I must say its a noticable improvement over how it was before.
  14. Jan 8, 2009 at 6:42 AM
    hashemg
    hashemg Well-Known Member
    Eastern MA
    08 Black Reg Cab 4x4
    3" Lift, Camburg Coil-Overs and UCA, 3" All Pro Leafs and OME rear shock, 33X12.5R17 Mickey Thompson on teflon coated American racing rims, Black headlight mod, Black taillight mod, tourneau cover, cargo divider, door sil protecors.
    It does smoke pretty good.......but man does it clean the crap out your intake system.
    great product
  15. Jan 8, 2009 at 11:27 PM
    #35
    ERdept
    ERdept Well-Known Member
    Is all this necessary? Just curious.
    Aren't these engines pretty tight and efficient and not needing anything like this?
    I mean if it's that good wouldn't the dealer do it?
    Not arguing here, just playing devil's advocate and trying to get answers before I do it.
  16. Jan 8, 2009 at 11:32 PM
    #36
    TRD4x4858
    TRD4x4858 Taco Traitor!
    San Diego
    95 Jeep XJ
    BONE STOCK! lol
    If you get the 120 dollar fuel injection service they do it at the dealer, or you can go get a can for under 10 dollars and do it yourself
  17. Jan 9, 2009 at 2:02 PM
    #37
    Cobra69
  18. Jan 9, 2009 at 2:08 PM
    #38
    beastlytaco
    beastlytaco Well-Known Member
    Ian
    08 Access Cab SR5
    buddy wants to do this to his Camry. he wants to know if it could damage his car in any way.
  19. Jan 9, 2009 at 2:23 PM
    #39
    Cobra69
    Um..............no unless he dumps the can in at once instead of trickling it in. dumping it in.............you can Hydrolock the engine like Chris4x4 siad. Just take your time and do it slowly.
  20. Feb 4, 2009 at 3:49 PM
    #40
    09 tacoma trd
    09 tacoma trd Well-Known Member
    ontario, canada
    2009 black tacoma dbl cab trd sport
    i just poured seafoam in the gas tank, a lot easier
