seal between fender flare and body
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01tacoprerunner, Oct 12, 2009.
  1. May 25, 2017 at 2:07 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    This is correct. I replaced all of my rubber "seals" with factory replacements. They come with 3m moulding tape already on them, but you have to trim them to size. The hardest part is removing the old nasty rubber. There are only screws holding the flare on from below.
    The 01-04 flares have screws on the bottom as well as clips.
  2. May 25, 2017 at 2:14 PM
    GW 2000 TACOMA
    GW 2000 TACOMA Member
    2000 Tacoma, SR5
    None
    WOW!!! you are a life saver, thanks for the info. Since this is a new install removing the old nasty rubber wont be a problem. Do you happen to know the Toyota OEM number of the 3M tape?? I buying some used Toyota OEM flares but they don't have the 3M tape on them anymore.
  3. May 25, 2017 at 4:34 PM
    nzbrock
    Noah
    San Marcos, TX
  4. Aug 15, 2017 at 10:16 AM
    GW 2000 TACOMA
    2000 Tacoma, SR5
    None
    Here is what happened, I bought a set of black Toyota fender flares(plastic) on Craig's list that fit on my 2000 SR5 just fine. You were right the old tape was hard to get off and they connect under the wheel well edge without clips. I bought new flare pads and additional 10mm bolts/screws from Toyota. Here is a picture of my Tacoma SR5 w/fender flares, thanks to all who helped!
    Toddb63 and nzbrock like this.
