seal leaking oil after replacing
Discussion in '1st Gen. Tacomas (1995-2004)' started by houndsmen, Aug 11, 2011.
  1. Aug 11, 2011 at 12:28 PM
    houndsmen
    houndsmen [OP] Well-Known Member
    I replaced the front diff seal on my 01 tacoma on the passenger side after it had a small leak. Well after putting the new seal on and new cv joints it still has a leak??? Does anyone know what the problem could be???
  2. Aug 11, 2011 at 12:35 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    gotta be the seal......
  3. Aug 11, 2011 at 12:45 PM
    houndsmen
    Do you think it went in wrong? I have a toytec coil over lift and its set at 3" right now my axles have a litte bit of an angle... Do you think that could be the issue!?
  4. Aug 11, 2011 at 12:56 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    i dont think thats the issue but i am no expert.....
    it took my dealer 3 times to get my front diff seals right.....
    when yiour putting in the seal n cv it must be perfect.....
    your breather isnt clogged or non working is it..that would cause a buildup of pressure insdie the diff and blow the seals out......
    but since its the same one "same side" i would say seal got messes up or something
  5. Aug 11, 2011 at 1:10 PM
    houndsmen
    Where is the breather??? I have not checked that yet. I just called the dealer and they can not give me a part number without the vin... i think they gave me the wrong one
  6. Aug 11, 2011 at 1:34 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    not sure you have a 1st gen. right?
  7. Aug 11, 2011 at 2:08 PM
    houndsmen
    yes correct...
  8. Aug 11, 2011 at 6:19 PM
    brutalguyracing
    F.U> GUYZ
    broken mods
    not sure
