Sealed sub - rear door
Discussion in 'Audio & Video' started by soggyBottom, Jun 2, 2024.
  1. Jun 2, 2024 at 5:50 AM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    Has anyone tried using a very low VAS sub in the rear door? Without cutting or putting a bunch of wet fiberglass in the door, are there any options around this?
    I have kappa perfect 6.5 component drivers in the back and they have way less bass response than the stock non JBL speakers even on an amp.
  2. Jun 2, 2024 at 6:02 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    They didn’t design those to have much bass response, as they are 6.5” components, probably intended to be run with a subwoofer in the system.
    the response only goes down to around 45hz so this is to be expected. They are power hungry as well so running them on a normal 50w amp may not be doing them justice.
    as for putting a sub in the rear doors, I think it’s way more trouble than it’s worth. Put a shallow mount 10” behind the rear seat and call it a day.
    soundman98 likes this.
