Sealing rear vents on back wall ... bad idea?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2Loud, Jan 4, 2019.
  1. Jan 4, 2019 at 8:00 AM
    2Loud
    2Loud [OP] Well-Known Member
    TRD Pro Grille Predator Step Tube 17" Maverick Alloy Wheels Nitto A/T Terra Grappler (265/65R17) Tri-Fold Hard Tonneau Cover with LED Lights V6 Tow Package Chrome Exhaust Tip XP Badging Stereo Pioneer AVH-X5800BHS Arc Audio 900.6 - 6 channel amplifier (4x60 watts + 1x550 watts bridged) Arc Audio 300.2 - 2 channel amplifier (2x180 watts) Hybrid Audio Technologies Clarus 1" tweeter Hybrid Audio Technologies Legatia 3.5" mids Hybrid Audio Technologies Legatia 6.5" midbass Image Dynamics IDQ10v4D2 10" DVC sub Stinger Roadkill Sound Deadner 200 AMP Circuit Breaker: Rockford 200 Amp Circuit Breaker Krystal Kable RCA Cable KnuKoncepts wiring and interconnects
    Sooo... What would happen if I sealed the two rear vents on the back wall behind the storage bins? What are they for exactly? Equalizing pressure inside the cab to the outside pressure?
    Each bass note from the sub makes them rattle.
  2. Jan 4, 2019 at 8:03 AM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Your doors wouldn't close easily and when you went to turn the heat or AC on there wouldn't be nearly as much air flow. Probably fog up a lot inside windows too because the moisture from breathing would build up.
  3. Jan 4, 2019 at 8:04 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Bad idea. You will struggle to shut the doors with the windows up and moisture will be much worse. Also, your HVAC is not going to pump air.
    I haven't looked at them, but they are usually flappy rubber. It might not be them rattling? Maybe some sound mat?
    shakerhood likes this.
  4. Jan 4, 2019 at 8:42 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    They are for the above and your HVAC system. Effectively, if you block them off your HVAC would not have the ability for fresh air (flow through) setting.
    tonered likes this.
  5. Jan 4, 2019 at 8:45 AM
    skiploder
    skiploder Well-Known Member
    Somewhere NE of Kanab
    FZJ80/XJ LS swap
    The smell of your farts will linger in the cab for a long time.
  6. Jan 4, 2019 at 8:46 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    This would be good enough for me not to try it. I let out some monsters.
  7. Jan 4, 2019 at 8:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    Root cause analysis would suggest to fix the cause, not the symptoms.
    And doubtful the vents are what is rattling anyway.
    MR E30, tonered and El Duderino like this.
  8. Jan 4, 2019 at 9:04 AM
    TacoGreg
    TacoGreg Well-Known Member
    Tomball TX
    2017 Tacoma TRD Sport 4x4
  9. Jan 4, 2019 at 9:12 AM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Put Noico or Dynamat on back wall, cover that with a layer of 1lb sq ft MLV layered in foam. I used Dynapad on the back wall, and cut some pieces to make a curve over the vents so they were double covered. You do lose a bit of air flow, but after doing the back and the doors it is much, much quieter in the cab.
    ShirtTucker and tonered like this.
  10. Jan 4, 2019 at 9:43 AM
    Yardmachines
    Yardmachines Member
    Al
    Pa
    18 limited white dbl cab
    Led interior,ocd dividers. Blacked out badges
    Doors will be hard to close. Interior will fog up. Hvac wont work well. And. The smell of ass gas will kill you.
    tonered likes this.
  11. Jan 4, 2019 at 10:00 AM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Oh come on now everyone likes their own brand! :D
    oscolivar1 and tonered like this.
  12. Jan 4, 2019 at 10:04 AM
    El Duderino
    Jeremy
    HI->PNW
    Only about 60%, the other 40% would make the Sphinx happy he doesn’t have a nose
    trazerr[QUOTED] and tonered like this.
  13. Jan 4, 2019 at 10:05 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Youll bust your back glass closing your rear doors.
    El Duderino likes this.
  14. Jan 4, 2019 at 11:00 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    What is rattling is the whole vent unit....not the flaps themselves. If you look at them, the plastic unit does NOT fit tight and is VERY loose... Silicone around the "unit" to holt it against the cab will fix rattle.
    tonered likes this.
  15. Jan 4, 2019 at 11:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Great info, right there! :cheers:
    over60[QUOTED] likes this.
  16. Jan 4, 2019 at 11:21 AM
    2Loud
    That's an excellent point. Already have double layers of sound deadener (Stinger Roadkill), but have not thought of this. Thanks!
  17. Jan 4, 2019 at 11:29 AM
    stealthmode
    stealthmode Well-Known Member
    Alberta
    2016 Short N Stubby Bed- MGM
    Front and Rear lifts Tires ECGS bushing Lots of other crap +HP sticker
    Negative air pressure. Bad idea.
    Next time you go into a public bathroom look at the vents on the bottom of the doors. Same purpose and intent for cab vents.
    tonered and over60 like this.
