seanpistol's first-gen Tundra
Discussion in 'Other Builds' started by seanpistol, Dec 30, 2016.
  1. Oct 1, 2017 at 1:16 PM
    #61
    seanpistol
    seanpistol [OP] Well-Known Member
    Salt Lake City
    Got some stuff knocked off my Moab prep list. Picked up two more bottles from the local secondhand store for the washer fluid reservoir relocation project. My tire makes contact with it in the stock location at the front of the passenger wheel wheel. I ended up using the one on the right, which holds two quarts!
    I got things secured to the Bedslide that have been rolling around for a while. Hi-Lift bolted to the side, spare tire strapped down, and shovel mounted to toolbox with Quick Fists.
    65 qt RTIC cooler secured with lashing straps to the Bedslide-
    Tools and recovery gear organized!
    Drilled a hole to fit the pump, which has its own grommet. I am going to fit the bottle behind the air box and between the power steering fluid reservoir, so I whipped up this tray out of some scrap metal.
    Painted. With thick enough steel, the tab on the front corner is all that is needed to mount this. With two quarts of fluid combined with the pump and bracket, it doesn't weigh more than 5 lbs.
    This is how the tray sits-
    Installed! Tube is shortened and reattached, wiring is rerouted, and the wires for the low fluid idiot light have been clipped. No light on the dash.
    The bottle sits a little higher than most things in the engine bay. I stuck my phone inside and closed the hood to show how much room there is.
  2. Oct 1, 2017 at 3:01 PM
    #62
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
  3. Oct 1, 2017 at 3:50 PM
    #63
    BlueSTL
    BlueSTL Well-Known Member
    Always have liked the 1st gen tundras, nice build
    seanpistol[OP] likes this.
  4. Oct 1, 2017 at 3:53 PM
    #64
    TundraLivesMatter4.7
    TundraLivesMatter4.7 Well-Known Member
    Andrew
    Memphis Tennessee
    1st gen tundra Suzuki Samurai
  5. Oct 11, 2017 at 7:32 PM
    #65
    seanpistol
    Salt Lake City
    I tore another CV boot, so I pulled my axles and rebooted them with Bates Porche 930 boots. I had them on my stock CVs and they were great... I didn't tear one in 5 years. I also built my spare. I don't have a comparison photo but they're about double the size of the stock inner boots.
    Added ditch lights. Not sure that I'm a fan of how they look, but I need to get them wired and give them a shot. Also added amber covers to my LED fogs.
    Pulled my J-shift transfer case to install the FROR twin stick. I wish I did it when I installed the case the first time, but I was on a time crunch. This is the writeup I used - https://www.tacomaworld.com/threads/clints-1997-reg-cab-build.280433/page-13
    interlock pin has to be removed to allow the two shift forks to move independently-
    The overlapping tab on the far right has to be ground off-
    Shifters on to make sure it's all working like it should-
    Used a snowmobile swaybar from my scrap pile to extend the shifters 6" to line up with the tray in the doublecab center console-
    I got another junkyard console because I hacked up the last one. Pretty happy with how the finished product turned out.
    Got some wiring to do Friday and I'm ready for Rock Therapy.
  6. Oct 11, 2017 at 8:41 PM
    #66
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    That console turned out looking great.
    Edit: any rattles?
  7. Oct 11, 2017 at 8:48 PM
    #67
    seanpistol
    Salt Lake City
    There don't seem to be.
  8. Oct 11, 2017 at 8:53 PM
    #68
    Jiveydude
    Micah
    OH
    04Taco
    Hmmm, I'll have to try tightening that bolt like you did to see if that helps.
  9. Oct 11, 2017 at 8:55 PM
    #69
    bravelilshitposter
    bravelilshitposter Licks paint and eats window chips
    chandler, AZ
    widebody V8
    Less length, more girth
    @seanpistol is Mr. Productivity. Knocking out all kinds of tasks.
    I'm highly impressed you rebooted all three when only one was torn.
    The Fluffer and seanpistol[OP] like this.
  10. Oct 12, 2017 at 7:05 AM
    #70
    The Fluffer
    The Fluffer Keepin dick's hard and pussie's wet since 1990
    Andrew
    Scottsdale, AZ
    07 SWB X-runner /// 01 Jade Mica Tundra
    boughten
    What's the benefit of these over stock? I still need to get my J-shift case installed..
    Edit"The Twin-Stick allows the use of two-wheel drive low range, and a true neutral. As well as the ability to shift-on-the-fly, while in low range, from 2wd to 4wd and back easily," :eek::eek::eek: OH!!
  11. Oct 20, 2017 at 10:12 AM
    #71
    seanpistol
    Salt Lake City
  12. Oct 20, 2017 at 12:57 PM
    #72
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Ah, man. You're my Tundy inspiration for when the mods start. GLWS
  13. Oct 20, 2017 at 12:58 PM
    #73
    seanpistol
    Salt Lake City
    Can't get the mods this cheap! :)
  14. Oct 29, 2017 at 10:45 AM
    #74
    seanpistol
    Salt Lake City
    SOLD!!! New owner is in Salt Lake and intends to carry on with the build.
    Here's the new truck -
    [​IMG]Untitled by Sean Kaldhusdal, on Flickr
    2002 Dodge Ram 2500
    5.9L Cummins Turbo Diesel
    100 hp injectors
    Edge programmer
    intake, straight pipe
    NV5600 6 speed with South Bend dual disc clutch
    Raptor lift pump
    1/2" fuel lines
    4.5" Top Gun Customz long arm lift
    37x12.5x17 Nitto MTs
    Dana 60 front Dana 80 rear
    4.10 gears
    3rd gen brakes
    new leather seats
    I'm sure I'm forgetting things...
    The guy I bought it from is a friend of mine. He's super meticulous and a super skilled mechanic. Everything is rebuilt or new on it. With the programmer turned all the way up it dynoed just under 500 horsepower and 1100 foot pounds- she is FAST!
    I need to re-paint the hood and roof, retrofit some projectors, and I'm going to swap the tires for a set of Toyo R/Ts with the Mud and Snow rating. There won't be a build thread for this one.
  15. Oct 29, 2017 at 2:46 PM
    #75
    The Fluffer
    Andrew
    Scottsdale, AZ
    boughten
    Holy balls
  16. Jan 17, 2019 at 2:11 PM
    #76
    tacomakid96
    tacomakid96 Lions Not Sheep
    Phil
    Out n' about
    1996 Tacoma / 2000 4.7 Tundra TRD
    Damn just found this thread awesome build. I had a 2002 5 speed Cummins, Did injectors lift pump and vp44 and thing was a raped ape but I am back in a 1st gen Tundra now. Still have the Dodge?
