Searching for a smoother ride
Discussion in '1st Gen. Tacomas (1995-2004)' started by Messy Jesse, Jul 7, 2014.
  1. Jul 7, 2014 at 8:52 PM
    Messy Jesse
    Messy Jesse [OP] Member
    Jesse
    NJ/PA
    1999 Reg. Cab 4x4
    Hi,
    Some background info:
    I've got a 99 reg cab 4x4, only 80,000 miles. My daily driver for the last 5 years. Very little off-loading. It rides like crap. To my knowledge, the suspension is bone-stock and original (worn out). It just seems way too stiff. If you hit rough road or, God forbid, a pothole 50 mph and up things get scary. I've also found that the suspension bottoms-out when hauling things, but that could just be me overloading it (bed full of dirt, motorcycles, one time a dressed Ford marine 302). Most of the time the bed is empty though.
    I need new shocks anyway. I'm looking for a suspension combo that will give me a more comfortable on-road ride (not looking for "sporty") without sacrificing the truck's usefulness for hauling things.
    I know Bilsteins are very popular. I'm considering 5100's/5125 front and rear, and maybe an Add A Leaf for the rear (I'd love to hear options on this). I would only want to lift if that extra travel added to the ride quality.
    Do you think I will be happy with the ride this gives? I would hate to spend that much coin only to find it too stiff and wish I just went with OEM replacements for less $$$.
    Thanks!
  2. Jul 7, 2014 at 11:49 PM
    m3bassman
    m3bassman Professional Web Wheeler
    Captain Jack Sparrow
    On the seven seas!
    if you want soft, smooth and quality, 5100s are not for you.
  3. Jul 7, 2014 at 11:50 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    If you want a smooth ride then buy Icon, fox or king.
  4. Jul 8, 2014 at 12:17 AM
    m3bassman
    On the seven seas!
    just wait, the seals will blow and they will get that nice mushy ride to them. ask me how i know.
  5. Jul 8, 2014 at 1:57 AM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    Sounds like you should stick with oe replacements. If your suspension is shot though, an add-a-leaf probably won't cut it because your old leafs are probably done. A new oe replacement pack would probably be required.
  6. Jul 8, 2014 at 9:16 AM
    Messy Jesse
    Jesse
    NJ/PA
    1999 Reg. Cab 4x4
    Thanks for the input. I decided to go with Monroe OE replacements with new front coils, and a new set of springs for the rear from General Springs.
    I can't wait to feel the difference. I'll report back once I get everything installed.
    Thanks again,
    Jesse
  7. Jul 8, 2014 at 9:28 AM
    eviele
    eviele Well-Known Member
    Tires too might make a difference.
    I went from Duratracs to Firestone Destination AT's and got a much better ride. The load rating for the Firestone's was C, while the Duratracs were E I think...
  8. Jul 8, 2014 at 11:08 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    he beat me to it.
    Tires can make a huge difference. I went from 10 ply to 6 ply and I thought I was in a luxury sedan! (that may be stretching it but, it was a lot smoother!) :D
  9. Jul 23, 2014 at 1:08 PM
    Messy Jesse
    Jesse
    NJ/PA
    1999 Reg. Cab 4x4
    I thought I'd give a little update in case it might help someone out one day:
    So I replaced my rear leafs and shocks, and new coils and struts up front. The ride is certainly better. It feels more "planted" when you hit bumps, and bumps are not as harsh as they were. I don't feel the back end trying to jump all over like it used to. It ain't no Cadillac, but I guess I'm happy with it.
    The worst part of the job is getting the old stuff out. The leaf bolts, u-bolts, and shackles had to be cut out out, and the struts needed the tops of those 3 bolts cut off... Be prepared to replace all that hardware on these rusted northeast trucks...
    Jesse
  10. Jul 23, 2014 at 3:14 PM
    BlackSportD
    BlackSportD Well-Known Member
    Los Angeles
    TRD S/C, TS PNP AEM FIC, TS 625cc injectors, TS 2.2 pulley, Hayden tranny cooler, AEM wideband, TRD boost gauge.
    I was going to say, you might want OME front coils as I believe their spring rate is lower than stock- at least for my application (TRD package). The TRD coils are progressive, and aggressively so. Since going OME, its smoother. I want to say the 5100s were smoother than OE yellow Billys as well, the yellows are known for being very stiff.
    And to have avoided the 5125s, they are harsh-- great if you carry a load often- wish I had gone 5100s in the rear. This is the first thread I've seen bashing the 5100s, everyone says they are so smooth, and my front 5100s haven't been bad, its the rear 5125s that Down South talked me into that are meant for a truck that always has a heavy load. I thought going with an AAL and deleting the overload leaf would have helped, but those shocks seem to have a crazy compression resistance, and not much resistance to rebound- kind of want to fork out the $$ and get something else in the back. Maybe 5160s with custom valving to help tame the rear.
    Glad to hear your updates went well, sorry my inputs were too late but like your last post states, this is to help any others that pass by.
