Searching for the perfect lift for me! please lend me your advice and knowledge!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jahnd123, Aug 20, 2025 at 6:31 PM.
  1. Aug 20, 2025 at 6:31 PM
    jahnd123
    jahnd123 [OP] Member
    Yesterday
    2020 trd sport
    Hello! I’m brand new to the Tacoma world—and honestly, the modification scene in general—so any advice is greatly appreciated!
    I currently have a 2020 TRD Sport that’s completely stock. I don’t plan on doing any off-roading; the roughest terrain my truck sees is boat ramps and bumpy gravel roads.
    I know this is a question that has been asked alot, but I've honestly struggled to find concise information that isnt refuted by others. (the common one being spacers and their harm)
    Goals:
    - Lift the truck 2.5"–3"
    - Something that lasts 75,000+ miles without causing extra wear on other parts
    - Eventually fit 33" wheels
    - Maybe have fun?
    - support a after market front and rear bumper in the furture
    Budget:
    Under $2,000 (but if I can go cheaper while still keeping good quality, that would be even better).
    These are some of the kits I’ve been looking at so far. If you know anything about these brands, whether they’ll fit my goals, or if you’d recommend other kits, I’d love to hear your thoughts!
    - https://**********/products/ome-nit...-front-shocks-assembly?variant=47635726205168
    - https://**********/products/bilstein-b8-6112-5160-2-inch-tacoma-rwd-16-23-lift-kit-w-ome-leaf-springs?variant=47828994294000&Facet=Year/2020/Make/Toyota/Model/Tacoma
    - https://www.extremeterrain.com/supr...ch-rear-pro-billet-lift-kit-tyta05fk3020.html
    - https://www.extremeterrain.com/roug...rear-leaf-springs-74232.html#customer_q_and_a
    Once again thanks for any help!
  2. Aug 20, 2025 at 7:09 PM
    Jakerou
    Jakerou Well-Known Member
    Jake
    MA
    2023 Celestial Silver SR5 DCLB
    Your goal for the lift is just for looks? I’d save your money and keep it stock.
    b_r_o, petethemeat and DoubleB like this.
  3. Aug 20, 2025 at 7:14 PM
    jahnd123
    Yesterday
    2020 trd sport
    Just trying to personalize my car in a way that I like!
  4. Aug 20, 2025 at 7:27 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Scratching my head on some of your goals and drivers. First off lets just say that this desire for a lift is entirely for looks, and there is nothing wrong with that. It actually will help define your end product choices knowing this is just for "fun" as you put it. Secondly there is no way anyone can assure or even predict how long your lift will last and even more so that it won't have any impact on other suspension components. You really need to reverse your logic and assume it's going to have it's issues over time. Lifts take their toll on a vehicle and yours will too!
    Good luck brother and welcome to TW
    Chew and Jakerou like this.
  5. Aug 20, 2025 at 7:31 PM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Front and rear bumpers hanging off front and rear, change the entire weight suspension dynamic unless they are stock weight replacement, which is not really possible.
    You either start with bumpers and get suspension to hold them up to desired lift, or you go interim suspension for lift, knowing you will need to change spring strength again after adding bumpers.
    Chew, DoubleB and WheelinDev like this.
  6. Aug 20, 2025 at 7:51 PM
    jahnd123
    Yesterday
    2020 trd sport
    Well said, I guess my brain was in a perfect world where things that dont break lol!
  7. Aug 20, 2025 at 7:55 PM
    jahnd123
    Yesterday
    2020 trd sport
    Awesome, good to know! So would doing Bilstein B8 6112's in the front and just a block in the back be a good option till I add weight and need to move on to a replacement leaf spring for the rear?
  8. Aug 21, 2025 at 12:02 AM
    Mach
    Mach Well-Known Member
    2022 Lunar Rock DCLB TRD Off-Road
    You can't lift over 2 inches without significantly effecting reliability. Even 2 inches in front is likely to cause some extra wear but shouldn't be anything crazy.
    6112s at 2in or less in front would work great. I have mine set at 1.4in. In the back you can get a Toyota OEM 1in lift block and should be close to level with that setup in the front. If you want to upgrade shocks the TRD lift kit rear shocks are a good choice. If buying the components individually the TRD lift kit parts are actually cheaper than aftermarket despite being oem. You could even do the TRD lift kit front shocks if you want a more budget option than the 6112s. The 6112s are really nice though.....
    Chew likes this.
  9. Aug 21, 2025 at 12:03 AM
    Mach
    Dont do more than a 1in block in the rear. Axlewrap will be awful and you will likely have vibration issues from your drive line angle.
  10. Aug 21, 2025 at 8:04 AM
    jahnd123
    Yesterday
    2020 trd sport
    I have been doing some more reaserch on the side and I also agree that 2 inches is the best lift for me. I have also heard the praise of the 6112s sung to much for me to skip out on those. As for the rear, If I decide to only do the 1in block and not replacement rear shocks how would that affect ride quality? Should I just bite the bullet and buy rear shocks to? Once again thank you for the tips guys!
  11. Aug 21, 2025 at 9:07 AM
    Mach
    Without replacing the shocks you will lose 1in of down travel. Not certain the length of the sport shocks but if they are similar to the off-road and 5100s then it may not be an issue on road. Lots of people run 5100s with blocks. Also you will notice a significant difference between the front and the rear although there is no 6112 equivalent for the rear so that is unavoidable. No downside to installing the blocks first and seeing how it rides. The rear shocks are very easy to swap.
    In order to install the blocks you will need longer u-bolts. There are OEM ones available designed to go with the blocks. If you want a little extra off-road clearance you could also go with something like archive garages u bolt flip with his upgraded bump stops.
    Upgraded bump stops are mainly important off-road but you will also notice a significant difference with speedbumps and other large bumps on road. If you want to stick with OEM u bolts then Perry parts rear bump stops are a good choice.
  12. Aug 21, 2025 at 9:40 AM
    Garymvvvvvv
    Garymvvvvvv It's easier to get forgiveness, than permission.
    Gary
    La Grange Texas
    2022 Tacoma SR5
    TRD pro grill, Raptor Grill Lights, 2 color fog lights, rock flood lights, light bar with powder coated front bumper, X-Bull winch, K&N cold air intake, RIPP ignition coils, oil catch can, E3 iridium spark plugs, 275/70 R17 BFG KO3 tires, OPT7 tail gate light bar, black out mirror caps and rear bumper caps, sprint booster, LED interior-exterior light bulbs. Flashing 3rd brake light, infinity tail lights and Alpha Rex Nova black headlights, Seat covers, Mr. hood scoop with 18 inch amber light bar inside. 2 inch lift front/rear. 1.5 inch wheel spacers. Fender flares,
    I went with Old Man Emu 2" coil springs in the front and the bilstein 5100's all the way around. For the rear lift, I used a 1.5" spacer block.
    I kicked out the wheels 1.5" With a hub centric spacer block.
    When installed correctly. they perform perfectly.
    NO issues what so ever
  13. Aug 21, 2025 at 9:48 AM
    Garymvvvvvv
    Gary
    La Grange Texas
    2022 Tacoma SR5
    I installed everything in my driveway. Team Oil Drop has a great video on how to lift your truck without the dangerous spring compressor. You may need to buy a couple of specialty tools if you dont have them already, but youll have them forever and a LOT cheaper than the labor costs to have it done
  14. Aug 21, 2025 at 10:24 AM
    AvalonTaco
    AvalonTaco Falken Sales Rep.
    Joe
    Cabin in the woods
    2019 Super White DCSB OR
    Working on a lien delete for my title…..
    jahnd123[OP] likes this.
  15. Aug 21, 2025 at 11:30 AM
    Garymvvvvvv
    Gary
    La Grange Texas
    2022 Tacoma SR5
    Having that adjustability after install might be a good thing.
    Having said that I'm fine with my set up. I personally dont see me changing the lift on a routine basis. I would go with air shocks if I did.
  16. Aug 21, 2025 at 12:32 PM
    jahnd123
    Yesterday
    2020 trd sport
    The kit that you just linked has me really interested, I've been pretty hard set on Bilsteins but the Eibach are slightly cheaper and provide a little bit more lift, any drawbacks with eibach in your experience?
  17. Aug 21, 2025 at 12:51 PM
    Mach
    Looks like those are the same diameter as 5100s so that would be the better comparison not the 6112s.
