Season opener trail run in Ardbeg! May. 4th - 5th
Discussion in 'Canada' started by DueNorth, Apr 12, 2013.
  1. May 3, 2013 at 6:05 AM
    #41
    Justroc
    Justroc Active Member
    Justin
    Southern Ontario
    2011 Tacoma TRD DCLB
    Smittybilt Nerf Bars Blacked out Emblems K&N Air Intake Flowmaster Dual Exhasut Total Chaos UCA OME Full 3" Lift Dakar Rear Leaf Pack 275/70/17 General Grabber AT2
    Bad news, will no longer be able to attend tomorrow :( something last minute came up that I can't miss. Such a bummer. Have a good one boys
  2. May 3, 2013 at 6:50 AM
    #42
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Okay that sounds great. Just to make sure, its the timmies where the meet and great was.
    Pm inbound.
  3. May 3, 2013 at 12:40 PM
    #43
    Geem750
    Geem750 Well-Known Member
    Brandon
    Okanagan, BC
    07 DCLB
    Grillcraft grill, ultimate toytek 3" lift, shorty antenna, blacked out badges, rear diff breather, Kenwood 6990 HU, wet okoles, weather techs, extra D-rings, Cruisin offroad bolt on sliders, Treklights 18" LED bar
    it may be a little early but happy trails and may the 4th be with you :p
  4. May 4, 2013 at 8:29 PM
    #44
    bzzr2
    bzzr2 Well-Known Member
    got back in one piece around 10pm, took 1.5hrs to get back, smooth ride, trail was great!! looking forward to doing it again
  5. May 4, 2013 at 10:55 PM
    #45
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    19 Tacoma TRD Sport Premium
    3" lift. $10K in TRD options. Richie's semi-hidden bumper, and soon his Elka suspension
    did you guys do the north trail or south?
  6. May 5, 2013 at 10:05 AM
    #46
    bzzr2
    i believe it was the south trail, we exited near the 124 not far from the 400/69. 30.5k of actual distance from trail head to pavement on the other end, this only included about 3k of 2wd area at the end, otherwise 4lo as there were really not flat spots in between scattered obstacles like a lot of trails i've run.
  7. May 5, 2013 at 3:19 PM
    #47
    cerutti
    cerutti Active Member
    Ontario, Canada
    Great weekend. Jason and I ran the black lake loop on Friday, that trail needs some major clearing! I bounced off a few trees and got a lot of new pin striping. On Saturday we ran the south trail all the way back to hwy 124, long but great run.
  8. May 5, 2013 at 3:35 PM
    #48
    DueNorth
    DueNorth [OP] Well-Known Member
    Southern Ontario, Canada
    2014 BSP TRD Sport DCSB 6sp
    Awesome run guys! :D
    No wheelin trip is complete without more pinstripping, dented skids and tires munching happily on my fender flairs. :mad: I was going to wait a lil before removing them but I may as well do that before I damage them further.
    Pics and vids to come...
  9. May 6, 2013 at 5:19 PM
    #49
    bzzr2
    i was looking at my trucks ass today and noticed that the whole rear bumper is bent up on the passenger side. this must have been from when you saw me contact it gylar, i don't even recall really feeling anything then, stock rear bumper sure is weak.
  10. May 7, 2013 at 10:33 AM
    #50
    DueNorth
    Yea I remember you come down off that rock smacking that tin bumper quite nicely. Sure doesn't take much to bend them. I think it's time for a high clearance bumper now. :D
  11. May 7, 2013 at 10:39 AM
    #51
    DueNorth
    I definitely incurred some damage myself. Still got to wash the truck to really see, but I know 3 out of the 4 flairs are barely hanging on now. :laugh:
    This spot really ate my left rear flair. Never had this issue last year with my worn KM2's but I did have quite a bit of weight in the back this time around and the duratracs are still fairly new.
  12. May 7, 2013 at 11:25 AM
    #52
    bzzr2
    lol glad i didn't give it a couple more tries, had you not said i contacted i probably would have mangled it up a more. i need to find a local welding shop that can fab me up something high clearance for the rear with a receiver in it for sure. i cleaned up the inside but have yet to wash the outside, was hoping for some tighter spots to pinstripe the pass side again since its all new paint.
    i was impressed with your duractracs, i've never seen them actually get wheeled before, they worked well in that terrain.
  13. May 7, 2013 at 4:07 PM
    #53
    DueNorth
    yea fresh new paint sucks! lol
    You should have stuck around Sunday and we could have done the loop. Mike and Jason were saying it was pretty tight down that trail.
    Duratracs did great (although lockers help ;) ) I must say tho, the side walls are definitely not that tough (I was aired down to 14psi) since I ended up cutting one tire. This would be the second tire to get sliced like this now...
  14. May 7, 2013 at 9:30 PM
    #54
    Sloweburn
    Woodstock, ON
    Hey, I did the same thing last year in Ardbeg! Probably on the same damn rock :p
    There's some pics on SONTT here:
    http://www.sontt.com/forum/viewtopic.php?f=14&t=3390&start=60
  15. May 9, 2013 at 6:10 AM
    #55
    bzzr2
    not sure if it was the same spot, i kinda had a feeling when i went at this rock ledge that it might not go well... i guess we'll have to get out there and try again!
    there were a few times that your tires looked like they were possibly getting pinched on the rocks with hard edges, the 14psi looked really low but worked really well!
    i need to go a bit lower than my 19front - 17 rear next time, truck is so much lighter and the sidewalls on the dick cepeks are fairly stout, this is a big part of why i chose this tire. your new shoes will be tougher than the duratracs once their on!
    i would have liked to stick around but wanted to be sure my new dog was gonna be ok after his slip on the bridge, he was still limping pretty good sunday morning but seems to be doing ok now, found some good cuts on the inside of his ankle and knee once i took a closer look. getting him checked out at vet today to be sure all is well.
    now to decide what i really need, lockright or the warn m6000 portable winch with synthetic line.. locker more capable, winch get me home if i fawk myself going camping without other trucks...
  16. May 11, 2013 at 4:45 AM
    #56
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    hey guys, sorry for the late response, had a late day on Sunday and didn't get to a computer until the weekend. Definitely had a great day, long but lots of fun, and learned alot. Look forward to the next one (hopefully with a lift), and thanks for helping out a newb.
    As for damage bent my skid plate
    broke a light
    surprisingly didn't break the trailer harness. Other than that a few pinstripes, and a bumped head on the oh shit handle :rolleyes:.
  17. May 11, 2013 at 7:15 AM
    #57
    DueNorth
    The duratracs did look really low once aired down but they grabbed the rocks sooo much better. It would have been nice to get a pic with the tires wrapping themselves around a rock tho. Next time I may try 16psi and see how that works. Definitely get your dick cepeks aired down to below 15psi since your truck is really light and those sidewalls are stiffer. You might really enjoy the ride a little better and not to mention gain much needed traction.
    It's good to hear Trapper will be ok tho. I totally understand taking off a lil early for his sake. Especially since you have had a bad experience with that sort of thing before hand. You didn't miss much Sunday tho. Just breakie really.
    So lockrite or winch eh? Hmmm that's a toss up. Locker in the rear certainly helps for pretty much everything but can also get you in trouble faster. I'd prefer the locker personally but only because I'm usually always winching other people and not myself. Lol. Both of those mods will get lots of use tho.
    One thing that would concern me would be winter driving with a lockrite... Definitely don't want your rear end locking around a snow covered corner at speed....
  18. May 11, 2013 at 7:18 AM
    #58
    DueNorth
    That looks familiar....
    So I did this...
    Had help from Finn of course but good welding lessons. It held up perfect climbing that super steep rock at the beginning of the south trail. Wonder if anyone got that on video....
  19. May 11, 2013 at 7:37 AM
    #59
    DueNorth
    Still waiting to get my laptop up and running so I can post the videos to YouTube but pics will have to do for now...
    View from camp...
    And of course I cut the duratracs again.... Second doing this. Looking forward to getting these MTR's on soon...
  20. May 11, 2013 at 2:05 PM
    #60
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Yeah, I have to service the truck this week, so while the skids are off, I am thinking of reinforcing it. Should be a swell time :rolleyes:
    No video of you climbing at the start of the trail. I'm sure someone got it though.
