Seat Belt Alarm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chuckpalmer, Nov 7, 2017.
  1. Nov 7, 2017 at 5:26 PM
    chuckpalmer
    chuckpalmer [OP] Member
    Chuck
    Chandler
    Stock White Limited
    Supercharged, towing mirrors, Air Lift air bags on rear
    Is there a practical way to turn off seat belt alarm on ‘14 Taco? I’ve did the fog light mod, cig lighter mod, electric windows mod.
  2. Nov 7, 2017 at 7:24 PM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    Go to the nearest dealer and be polite and courteous. Tell them your 4 legged buddy rides up there when your out on forest service roads or something. Just ask if they can turn the buzzer off. That worked for me.
  3. Nov 7, 2017 at 7:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    See above. It is controlled in Firmware via the ECU. Search the forums there are Techstream knockoffs from Chiina that can be had on ebay for cheap.
  4. Nov 7, 2017 at 8:57 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    Benzdriver81, TomTwo and baldridge like this.
  5. Nov 8, 2017 at 5:40 AM
    nemesis17592
    nemesis17592 Well-Known Member
    Nate
    Comstock Park, MI
    2010 Tacoma DC LB SR5 4x4
    You can turn the actually beeping off through the odometer button... Unless you are referring to the little red light blinking.
    llamasmurf likes this.
  6. Nov 8, 2017 at 6:47 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    How sir, do you do this magic you speak of?
    Jerry311SD and Tac0maSteve like this.
  7. Nov 8, 2017 at 6:56 AM
    nemesis17592
    Nate
    Comstock Park, MI
    This worked for my 2010, and a buddies 2008
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    Benzdriver81 and Doogz like this.
  8. Nov 8, 2017 at 6:57 AM
    llamasmurf
    Wes
    Northern Ontario
    I see you have a 2010, is this for all 2nd gen up to 2015?
  9. Nov 8, 2017 at 7:00 AM
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    gonna try this after work today....
    Benzdriver81 likes this.
  10. Nov 8, 2017 at 7:02 AM
    nemesis17592
    Nate
    Comstock Park, MI
    I am not sure what years it works for. I would assume it would work for all 2 gens.
  11. Nov 8, 2017 at 7:08 AM
    llamasmurf
    Wes
    Northern Ontario
    Nope, I think its 2010 and before if I remember correctly. It does not work on my 2015.
  12. Nov 8, 2017 at 7:16 AM
    nemesis17592
    Nate
    Comstock Park, MI
    After some Research. You are correct sir. It looks like you need a scan tool at the dealer to do it.
    llamasmurf[QUOTED] likes this.
  13. Nov 8, 2017 at 8:55 AM
    TacoLarry
    TacoLarry Well-Known Member
    Larry
    PacNW
    14 Tacoma DCLB Myca Pyrite 4WD
    Easy enough to remove the spring under the activation tab in tbe buckle. The tab remains down, keeping the switch engaged and the rig sees a connected belt. disabling buzzer and light. Also easy to reverse by simply reinstalling the spring.
  14. Nov 8, 2017 at 8:10 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    That doesn't work on a 2014 like the OP has.
    That stopped working in 2012 AFAIK.
    nemesis17592[QUOTED] likes this.
  15. Nov 8, 2017 at 8:27 PM
    Taco'09
    Taco'09 Well-Known Member
    The ODO thing was one of the first I tried on my '14. No good. So I got a Techstream from the far east and did it that way.
    nemesis17592 likes this.
  16. Nov 8, 2017 at 10:05 PM
    navynuke
    navynuke Well-Known Member
    Lake Wylie, SC
    2014 TRD Off Road DC
    Not sure I would feel comfortable disassembling something that is there to keep my alive in a wreck.
  17. Nov 9, 2017 at 8:58 AM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
  18. Nov 9, 2017 at 9:05 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Just copy the outline of your locking tab on to some 1/8" stainless. I had plenty of it at work and the tools to make it in about 20 minutes.IMG_20170430_134142.jpg
  19. Nov 9, 2017 at 10:08 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Here's a novel idea:
    Wear your seatbelt.
    Fitz235, Justbrian and Blockhead like this.
  20. Nov 9, 2017 at 10:56 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    only on 11- trucks 12+ trucks require the modification of the setting via the ecu.
