Seat Belt Chime for 14 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheDude85, Oct 26, 2016.
  1. Oct 26, 2016 at 2:18 PM
    TheDude85
    TheDude85 [OP] New Member
    Jack
    2014 Gray Tacoma TRD OFF ROAD
    Stock
    Hey guys,
    I have a 2014 Tacoma TRD Off Road and was wondering if there is a method to disable the seatbelt chime. I have looked at a few threads on here and have only been able to see ones for 08' and 09' models. Anyone have any luck doing this with a 2014? Did the code change at all? Maybe I'm doing it wrong, I have been following this sequence(this for an 08'):
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    Any and all help is greatly appreciated. Thanks!
  2. Oct 26, 2016 at 2:19 PM
    zeekevin
    zeekevin Well-Known Member
    San Diego
    You need the Toyota software or similar to modify it now
  3. Oct 26, 2016 at 2:21 PM
    TheDude85
    Jack
    Stock
    Is the software hard to get on my own? Or do I have to take it in somewhere?
    Thanks for the reply
  4. Oct 26, 2016 at 2:23 PM
    Dwrat
    Dwrat Well-Known Member
    Dan
    Phoenix
    2014 TRD 4X4
    It's a easy fix.
    tab down....
    PUT ON YOUR SEAT BELT.
    Capespencer68 likes this.
  5. Oct 26, 2016 at 2:38 PM
    TheDude85
    Jack
    Stock
    Good one...So smart.
    Oh and its "an easy fix".
    Thanks anyways I guess
    Kingsleepy01 likes this.
  6. Oct 26, 2016 at 2:40 PM
    twhalm
    twhalm Well-Known Member
    Denver, CO
    2015 TRD/OR Manual, OME , Dual battery
    Just wear your seat belt.
  7. Oct 26, 2016 at 2:44 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You can get the software on Amazon or eBay.
    They are Chinese clones of the Toyota Tech Stream program.
    Look up Toyota techstream.
    I have my own version and it works great!
    Don't mind the retarded comments about seatbelts. Some people can't grasp the fact that you don't need a reminder to put on your belt or there could be situations where belts are not needed.
  8. Oct 26, 2016 at 3:02 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    you can disable it a few ways.
    1. take it to the dealership, they use their techstream cable / software and change the setting
    2. you buy a techstream cable, find the software, install it on a laptop, and do it yourself (not hard if you know what you are doing, but you gotta know where to look, took me about an hour to get techstream up and running on my windows 7 64 bit laptop)
    3. Use an OBD bluetooth adapter and telnet into the ecu with an android phone / laptop with a telnet program and issue a series of commands (this is how i did it before i had the techstream setup)
    TheDude85[OP] likes this.
  9. Oct 26, 2016 at 3:08 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    +1 - for number 2
  10. Jan 24, 2021 at 6:52 PM
    Kingsleepy01
    Kingsleepy01 Well-Known Member
    2014 Limited 4X4
    Hey any luck on this?
  11. Jan 24, 2021 at 8:32 PM
    lickskillet
    lickskillet Well-Known Member
    Land Of Big Sticks
    2014 Tacoma
    Take a five gallon bucket lid and trace/cut a piece out that duplicates the male end of the belt connection. Plug it in place when not wanting it worn.
    Marc70 likes this.
  12. Jan 24, 2021 at 10:19 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I pulled the buzzer out behind the dash on mine
  13. Jan 24, 2021 at 10:24 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Another option is to get a short seatbelt extender, clip it into your wired receiver to make the truck think the seat belt is fastened, and then the other end has a buckle so that when you need to wear your seatbelt you can then fasten it.
    Marc70 likes this.
  14. Dec 15, 2024 at 9:50 PM
    psilocyben
    psilocyben Well-Known Member
    2015 SR5 V6 4WD
    Reviving an old thread here but do you know, if I disable the chime via tech stream and then disconnect the battery for whatever reason, will I have to re-disable it?
    koditten likes this.
  15. Dec 16, 2024 at 6:07 AM
    koditten
    Kirk
    Central Michigan
    It will not. I've removed/replaced many batteries on several different Toyota trucks over the years. It does not change your seat belt chime setting that chose.
  16. Dec 16, 2024 at 7:24 PM
    psilocyben
    2015 SR5 V6 4WD
    That’s great to know, thanks for the reply
  17. Dec 16, 2024 at 8:06 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    The chime will stop. It lasts about 25 seconds longer than a normally adjusted person can take. It will reset and ding after shifting to R (MT experience). Can’t speak to slush box variants, but I’d advise you’d wear your seatbelt if putting on your makeup using the rear view mirror.
  18. Dec 17, 2024 at 6:16 AM
    HoosierBuddy
    HoosierBuddy Well-Known Member
    Phil
    2012 Base Regular Cab 4WD Manual
    2" Lift
    I run into this issue when my dog rides next to me in my regular cab (bench seat). He's just heavy enough to set off the sensor. The dinging eventually stops.
  19. Dec 17, 2024 at 6:40 AM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Did someone give you the good ol’ brake tap one time? :rofl:
  20. Dec 17, 2024 at 8:29 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    Under normal circumstances I used to be in the "just put your belt on" camp. But after a few months working in a shop and having to move vehicle after vehicle, all of 30 yards while listening to the god-awful seatbelt chimes that never end, I get it. I've also had moderately heavy things in my passenger seat that tripped the sensor. The beep in my truck is tolerable and stops after 58 beeps. I haven't disabled it because honestly its just the push I need to remember I really should have the belt on 99% of the time.
    But the newer chimes start docile, then escalate to juuust the volume and frequencies that compel me to kick infants. Which I'm sure is meant to be attention-grabbing, bit it's to the point that it's disorienting if it comes on while navigating a turn or pulling into a tight service bay. And I havent been able to tolerate one long enough to see if it stops yet lol. What I'd give for a "mute the chime for 5 minutes" button.
