Seat belt keeps Blinking
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kolar, Jul 2, 2011.
  1. Jul 2, 2011 at 5:01 PM
    Kolar
    Kolar [OP] Active Member
    Eric
    South Texas
    03 PreRunner stock
    Ok I cut wire #2 on my DRL relay and now my seat belt light keeps blinking. It seemed just fine at first now I am having more issues also. When I tried to turn my lights off last night the DRLs stayed on and my high beam light came on and was very dim. I have read a post on this and they said to cut the #1 wire but others said # 2 wire that at is the one I cut. Can any one help me please it is driving me crazy?
  2. Jul 3, 2011 at 3:39 PM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    Has any one out there had the same experience with this in curious?
  3. Jul 3, 2011 at 3:42 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Just so I can understand here, why did you cut a wire?
  4. Jul 3, 2011 at 6:11 PM
    Kolar
    Eric
    South Texas
    03 PreRunner stock
    I cut the wire so I could disable the DRLs. I have figured out my wiring problems though. I spliced the #2 wire back on the DRL relay and tested everything was back to normal except the blinking seatbelt light. Now that everything was in its normal state I had to find the seat belt light issue. I removed the drivers seat to find a small two wire connection I unplugged this connecter and cleaned it plugged it back in and my seat belt light issue was solved. Now on to the DRL issues. I cut and insulated the #1 wire on the DRL relay and all my issues I had with them were solved. I hope this post will help someone in the near future.
