Seat Belt light won't come on.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma_11, Sep 28, 2015.
  1. Sep 28, 2015 at 10:53 PM
    Tacoma_11
    Tacoma_11 [OP] Member
    Leo
    2003 Tacoma TRD
    Hey guys I just bought a 2002 Toyota tacoma 4x4, but when I turn the ignition switch all the lights come on the dashboard except the seat belt light. Is there a fuse or connector that needs to be put back on? I'm having the car inspected, I just don't want it to fail because it won't come on. Thanks in advance.
    My new ride.
  2. Sep 28, 2015 at 11:12 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Prolly just a burnt out light...maybe check the wiring at the buckle and under the seat. But id expect the light to still work regardless of a wiring snafu. Thats ridiculous if they fail you on not having that friggin light! Otherwise id say "prefect!" To having that light not come on, ha.
    Im lucky enough to live in an area where i dont have to have safety checks or even emissions testing. It would drive me absolutely nuts to have to deal with that bull shit! I feel for ya on that bud!!!
  3. Sep 28, 2015 at 11:16 PM
    Tacoma_11
    Leo
    2003 Tacoma TRD
    Is it easy to replace light bulb if thats the case?
  4. Sep 29, 2015 at 12:10 AM
    Caligula
    Caligula Well-Known Member
    Los Angeles, CA
    2000 Ext. Cab Prerunner 2.7L
    Yea, all those should pulse when you turn the car on.
    You need to remove the cluster. Its not difficult per se, just time consuming. Youll need to remove the center dash section (A/C control, stereo), then the cluster surround. Its pretty straight forward.
    Some people disable this just so they wont see it when not wearing their seatbelt. Unlikely, but this may have happened. If not unplugged, the plug under the seat may have been altered.
    Being said, i doubt this would be noticed during an inspection.
  5. Sep 29, 2015 at 2:28 PM
    Tacoma_11
    Leo
    2003 Tacoma TRD
    So I figured out what was wrong. The previous owner cut the cord that goes into the seatbelt clicker, I just rewired it back and it works now. :)
  6. Sep 29, 2015 at 7:25 PM
    bry838
    oregon
    Nice!
    Now i know how to get rid of that damned light, lol, thanks! Im kinda suprised that cutting the wire makes the light stop, id figure Toyota woulda had it light up constantly if the buckle wire was cut. Which wire was it exactly that was cut? I suppose there is just two wires off that buckle??
  7. Sep 29, 2015 at 11:21 PM
    Fallguy6666
    Fallguy6666 Well-Known Member
    Its just a ground circuit.
  8. Oct 2, 2015 at 9:13 AM
    Tacoma_11
    Leo
    2003 Tacoma TRD
    Ya it was just two wires going into the buckle. Both wires were black unless they color coded different. It was dark outside when I looked at the wires.
  9. Oct 2, 2015 at 9:26 AM
    ddaykpa
    ddaykpa Well-Known Member
    brent
    SE Houston, TX
    2015 MGM tacoma 4x4 DCLB trd
    n fab steps. redline hood struts, MATTGECKO bed lights, truxedo lo pro tonneau fab fours front and back bumpers old man emu 887 coils dakar rear springs ome rear sport shocks tint, removed rear seats, anytime driving light mod, anytime power inverter on. 2 ac plugs in cab, 4 constant power usb ports husyliner mats, airraid intake, fat matted floor and rear cab wall. hood deflector window deflectors, all in one flip key, painted interior plastics. trd pro wheels. rear molle panel.homemade trailer plug bracket. added Signal Stat 77-570 for rear cab area lighting. tacodane hoodlight kit Total chaos UCA. Ac Max mod
    on my 01, I just unplugged the connection under the driver seat in 01, didn't have to cut anything to have the light go out. I need to figure if I can do the same for the 15
    Not sure where you are, but we have emissions and safety check in Harris Co TX, but that is not anything they look for.
  10. Oct 2, 2015 at 10:00 AM
    Tacoma_11
    Leo
    2003 Tacoma TRD
    Ya thats reason I wanted the light back on for the safety and inspection. For a 2015 i wouldn't know. I wouldn't do anything personally. It does make me wear my seat belt though haha.
  11. Oct 2, 2015 at 10:06 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    So glad I don't have emissions/safety checks to worry about here in MT! The airbag light in my truck has been slowly blinking on and off since I got it a year ago. The seatbelt light is always pulsating as well because I'm too lazy to wear it around town. I only ever put it on traveling at high speeds down the freeway. Unsure of what the airbag light means, tried to get a scanner to pick up a code on it and it returned nothing. And I'm too cheap to take it to a shop or dealership for something like that.
