Seat Belt problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Drew793, Aug 27, 2012.
  1. Aug 27, 2012 at 9:51 AM
    Drew793
    Drew793 [OP] Well-Known Member
    New Jersey
    08 TRD Off-Road V6 Auto
    Weather Tech window shades, Roll-N-Lock cover with cargo manager, Led interior bed lights, EZ down tailgate strut, SpiderTrax1.25" wheel spacers, tinted windows, second filter removed, Grillcraft Mesh upper and lower grill, Castrol Syntec.
    Hi, Ihave a 2008 Access Cab.
    Seat belt won't pull out. It's all the way in the retractor.
    Took door panel off the back door to see if there is any way to un-stuck it.
    I have no clue. Both side covers on retractor say do not remove.
    Not sure what the two wires going to retractor are for.
    Can anyone help?
    I've gone through all the seatbelt posts but none of them helped.
  2. Aug 27, 2012 at 10:09 AM
    98tacoma27
    Ben
    Not Beech Creek
    The wires are the pretensioner connector. They activate in the event of a collision. It is part of the SRS system. You have have the battery disconnected if you plan on working around that.
  3. Aug 27, 2012 at 10:17 AM
    BamaToy1997
    Bill
    Navarre, FL
    The automatic tensioner may be seized or jammed. Make sure the truck is on a level surface and attempt to let the belt retract a bit, then slowly pull out. If it is too tight, and the auto-retractor is jammed, then you may need to have it looked at by a dealer. Short of replacing the belt, a safety item such as those are not something to try and play with yourself.
    I do not see any current bulletins or recalls regarding seat belt retractors for your truck.
  4. Aug 27, 2012 at 5:08 PM
    Drew793
    New Jersey
    Well, somehow I managed to get it unstuck.
    I took the cover off and lifted up a steel ball.
    Couldn't get the belt to move so I put it back together
    and as I was doing that it became un-stuck. lol
    You don't know how glad I was to see that because it had shortened up
    a bit more at first and couldn't get it all bolted back in.
    Thanks for that PDF. I kinda read it after the fact and I see what those
    wires are for now.
    I'm going to be real gentle with the seat belt from now on.
