Seat bolts
Discussion in '1st Gen. Tacomas (1995-2004)' started by 06toyoboy, Dec 11, 2015.
  1. Dec 11, 2015 at 4:08 PM
    06toyoboy
    06toyoboy [OP] Well-Known Member
    so i took of my seats yesturday and when i went to re intall them i stripped the threads on the bolt and in the bolt hole idk how i did this but it happened. I ordered new bolts but is there anyway to re thread the bolt hole
  2. Dec 11, 2015 at 5:09 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    bout all you could do is run a tap through the bolt hole and try to clean it. issue with this is the bolt hole will become weaker. so a bit of a safety concern. buy an extra bolt that has the same thread from an auto parts store and drive it into the bolt hole. if you do it right and get it straight on the first shot, it will hopefully kind of reform the threads. using a tap will cut new threads.
    if however you just put the new bolts in, use some blue locktite. it will help hold the bolt in and kind of undo that damage done.
  3. Dec 11, 2015 at 5:56 PM
    06toyoboy
    I just ordered the new bolts and i have a re threading kit so i am hope i fix it tomorrow when the new bolts come in.
  4. Dec 11, 2015 at 5:57 PM
    CodeSeven
    Serge.
    Coachella Valley
    make sure to use red threadlocker with the re-threading kit. otherwise the new threads you put in can slip out or further in.
  5. Dec 11, 2015 at 6:26 PM
    06toyoboy
    A re threading kit? I thought all i had to do was tap the holes with a bew thread and thats that....
  6. Dec 11, 2015 at 6:45 PM
    CodeSeven
    Serge.
    Coachella Valley
    no, rethreading kits come with little springs that you have to drive inside the oversized thread that is made with the tap from the kit. see video.
    this guy didn't use threadlocker. is it that bad to not use it? no. can it be a nuisance later if it doesn't have threadlocker? yes. it's still recommended though.
    Snowman likes this.
  7. Dec 11, 2015 at 6:59 PM
    06toyoboy
    I just saw that video too. I will be using threadlocker for sure. And ive been looking for the springs online but i cant find them.
  8. Dec 12, 2015 at 12:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Search thread replacement kits
    A simple matter to use the thread replacement brand of your choice.
    We are talking the bolts holding the seats in mine get never seized
  9. Dec 12, 2015 at 7:00 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Thread replacement kit may be overkill. I guess it depends how wasted the original thread is. I would run the tap through the hole and test the bolt for engagement. From experience those helicoils or whatever they call them are a pain in the but. I would probably get a bolt 2"longer tap the hole and put a big nut on the other side before I would duck with putting in one of those.
    Edit: I actually just stripped one of mine when I took the interior out to move the floor for the clocked tcase. I found a proper bolt in my spare hardware pile and threaded it in. I don't think I managed to damage the nut welded to the cab at all.
  10. Dec 12, 2015 at 8:36 PM
    06toyoboy
    I think i messed up to the point that i need to rethread i went to toyota dealership and got bolts wich is what I will be using
  11. Dec 13, 2015 at 12:28 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Respectfully disagree. The seat belt is attached to the seat so there is a lot of force applied to those bolts in an accident.
    +1. The brand used at the rebuild shop I worked for was Helicoil. They are super strong, would be used if head bolts stripped going into the block. Held the very high torque settings on giant diesel engines. Seriously strong.
  12. Dec 13, 2015 at 7:17 AM
    06toyoboy
    My seatbelt is seperately connected to the floor not my seat. But i will be purchasing some coils to fix my issue.
  13. Mar 13, 2016 at 9:00 AM
    TacoTruk2
    TacoTruk2 Active Member
    Templeton, CA
    07 Double Cab 4x4
    I'm in a similar bind. While trying to re tap the threads on mine, the welded bolt broke free from the cab. I'm thinking of putting a bolt and nut, but I'll have to cut a small whole to access where the bolt would go on.
    any other ideas? Advice?
    Thought of a nutsert, but not convinced it will be strong enough.
  14. Mar 13, 2016 at 9:20 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Through bolt and a washer, unless you know someone who can tack a new nut on for you.
  15. Mar 13, 2016 at 11:30 AM
    CodeSeven
    Serge.
    Coachella Valley
    +1 on this. any welder should be willing to tack for 40 bucks so long as it's easy to get too. maybe ask for 2 or 3 tacks
  16. Mar 13, 2016 at 12:15 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    was it the horizontal bolt that goes on the rear/right side on the driver side? I stripped that one out.
