Seat Covers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wyofishtaco22, May 8, 2022.
  1. May 8, 2022 at 12:55 AM
    Wyofishtaco22
    Wyofishtaco22 [OP] Member
    Wyoming
    2022 Manual TRD Off Road Silver Tacoma
    Any ideas on seat covers? Does my ‘22 Off Road Tacoma have side seat airbags that I need to consider? If so this would mean that I need to go custom fit? Any input appreciated.
  2. May 8, 2022 at 4:08 AM
    FLAK-TAC
    FLAK-TAC Only banned twice…so far
    SW Florida
    2022 TRD OR LB
    Clazzio’s. OEM fit and designed with the airbag in mind.
  3. May 8, 2022 at 4:32 AM
    Nitro52
    Nitro52 Well-Known Member
    ct
    2022 SR/SX
  4. May 8, 2022 at 5:32 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I went with coverking neoprene covers from Auto Anything.
  5. May 8, 2022 at 5:34 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Carhartt mossy oak were easy to install in my 2020 tacoma. Easy to remove if needing to be cleaned.....after all its a truck not a luxury car.
    A1000Leaves and Chew like this.
  6. May 8, 2022 at 5:36 AM
    zoo truck
    None
    My buddy had those in his trd tacoma. We had a real hassle installing them until finally pulling the seats which they don't tell you, otherwise if bigger hands, they will look like you fought with a mean ass cat.
    Kolohe07 and Taco_mike73[QUOTED] like this.
  7. May 8, 2022 at 5:37 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    Wet Okole’s, washable.
  8. May 8, 2022 at 5:47 AM
    Taco_mike73
    York, PA
    They were a little difficult to install. There are straps and things that need to go under the seats or be tucked in somewhere. Not sure how they compare to other customized fit seat covers. They have stayed in place for me. Removing the front seats or just unbolting them so you can tip them up would probably be easier. The rear covers weren't as hard just took some patience to wrestle in to place.
    LOLLY and zoo truck[QUOTED] like this.
  9. May 8, 2022 at 5:51 AM
    zoo truck
    None
    The rears were cake vs the the 2 front seats....too many straps. Their video makes it look way too easy.:facepalm:
  10. May 8, 2022 at 5:58 AM
    Taco_mike73
    York, PA
    I know and they give you that handy tool. But that's really only so helpful with the under seat part. The drivers seat with power is really the challenge as there isn't as much room even if you set it as high as possible. Here is where you unbolt the seat. The straps need to go above all the mechanics of the power seat.
    I'd bet nearly all the brands have some similar issues
  11. May 8, 2022 at 5:58 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just installed Wet Okole's... airbag compatible. Do yourself a favor and remove the seats to install.
    RWGT22AG, Taco_mike73 and jwctaco like this.
  12. May 8, 2022 at 7:24 AM
    BobbyTacoTRD
    BobbyTacoTRD Skewps Ahoy!
    2021 TRD Off Road
    Have any photos of the covers in your truck? Curious to see what they look like in real life.
  13. May 8, 2022 at 7:26 AM
    316sherm
    316sherm Well-Known Member
    South Louisiana
    2020 Tacoma SR TSS Package 4 Cyl
    Clazzio's are definitely worth the money.
    LOLLY and FLAK-TAC[QUOTED] like this.
  14. May 8, 2022 at 7:29 AM
    CLT_Rick
    CLT_Rick Well-Known Member
    Nevada
    2021 TRDOR / 2016 TRDOR
    I don't recommend Wet Okole for the power drivers seat...material is too thick to install under the plastic trim, so hangs over seat switches. On my 7th set (multiple vehicles) and not happy with the newest for Tacoma.
  15. May 8, 2022 at 7:41 AM
    jwctaco
    Jim
    SW Michigan
    23’ T4R
    Good to know
  16. May 8, 2022 at 7:52 AM
    zoo truck
    None
    My carhartt driver seat cover went on pretty tight compared to the passenger side, but way, way easier than those coverkings a buddy bought. I think it took me about a 1/2 hr at most to do both seats. I didn't do any covers on my access cab rear seats.
  17. May 8, 2022 at 8:21 AM
    Taco_mike73
    York, PA
    Those are mine in the Black and grey. They been in almost 2 years. The rear and passenger seat still look new because I hardly ever have passengers. The drivers seat I need to clean soon. They say to use a wet rag and a solution of wet suit shampoo.
    JoePun likes this.
  18. May 8, 2022 at 8:26 AM
    Taco_mike73
    York, PA
    I had universal fit Carheart covers in my Jeep for a while I liked the fabric but they didn't really fit nice. Maybe I should have got the custom fit ones.
  19. May 8, 2022 at 10:42 AM
    BobbyTacoTRD
    2021 TRD Off Road
    Awesome man! Thanks for the photos! Really, for being used for 2 years, even the drivers seat looks good.
    Taco_mike73[QUOTED] likes this.
  20. May 8, 2022 at 1:39 PM
    tneynop
    tneynop Well-Known Member
    Charlie
    Levittown, PA (Bucks County, SE Pa.)
    '22 SR5 V6 DCSB 4x4 - Barcelona red, black w/red int
    Peragon tonneau, Vertex Offroad faux leather seat covers, Tufskinz interior dress up, Diode Dynamics stealth light bar, NFab nerf/steps
    JoePun likes this.
