Seat ergonomic issue
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lucy, Sep 17, 2012.
  1. Sep 17, 2012 at 7:26 PM
    Lucy
    Lucy [OP] New Member
    Calgary
    Tacoma Double Cab 4x4 V6
    The seats in my new Tacoma are comfy and well upholstered but are too low and are causing discomfort / lower back pain. Did anyone else have this issue? Any suggestions?
  2. Oct 14, 2012 at 3:10 PM
    SpecOps
    SpecOps New Member
    Paul
    Hedgesville, WV
    2013 Tacoma TRD
    Some...I do wish it had a height adjustment.
  3. Oct 14, 2012 at 3:35 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The cheapest way would be to find some cushions to sit on, or something to add to the stock seat to add support.
  4. Oct 14, 2012 at 7:01 PM
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    you could cut out everything below your seat and reweld it at a lower position. i had a 95 reg cab and the seat bolts went down and i put a longer bolt in them with washers under the bracket for about a 1" seat lift. i changed out the seats in mine when i first got my 05 but can't remember if the bolter down or in (for lack of a better term) u could check it out and if its down you could "shim" it up a bit that way.
  5. Oct 14, 2012 at 7:07 PM
    NHCrewcab2008
    NHCrewcab2008 Well-Known Member
    Thornton, NH
    SR5 TRD
    I have the same issues, these seats kill my lower back.
  6. Oct 14, 2012 at 7:12 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    I'd try this:
    http://www.staples.com/Fellowes-Off...t_645282?cid=PS:GooglePLAs:645282&KPID=645282
    My wife has horrible lower back issues and recently got this for her Rav4. She used to use a pillow like someone mentioned but this is a godsend.
    You can probably find them cheaper on Amazon or whatnot, just google "mesh back support". The one my wife has doesn't Velcro down great (although I know I could just get a longer strip), but when you put it on the seat and sit down it's not going anywhere.
