Seat heaters have gone out. Anyone have this happen?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by thisnameisnowmine, Jan 5, 2024.
  1. Jan 5, 2024 at 7:34 AM
    thisnameisnowmine
    thisnameisnowmine [OP] Active Member
    I had both my driver's and passenger seat heaters go out. I took it to a local dealer for a diagnosis, and the quote I received was really high. Over 2k. They said they had to replace the heating elements and reupholster the seats.
    I'm getting a new model and want to fix this, but I don't want to pay that price. Does anyone know if you can change the heating elements without reupholstery?
  2. Jan 5, 2024 at 7:36 AM
    Bishop84
    Bishop84 Well-Known Member
    Uhh ya I’ve never reupholstered unless the material is burned.
    I’d get it quoted elsewhere
    musicisevil, Chew and joba27n like this.
  3. Jan 5, 2024 at 7:40 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    DM me your VIN, and I can look up in the parts catalog, to see if the heater element is part of the seat cover, or separate.
  4. Jan 5, 2024 at 7:40 AM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Honestly if you are patient and have a warm place to work you can probably do it yourself. I'm assuming the heating element is the heater on the cushion (odd they would both fail at the same time but assuming that is correct) I don't know how the leather is fastened to the cushion but i'd say beyond basic hand tools you may need some "hog ring" and hog ring pliers at most.
    What parts exactly are quoted on the sheet?
  5. Jan 5, 2024 at 7:45 AM
    AnotherUser256
    AnotherUser256 Well-Known Member
    Magnuson TVS1900 Supercharger with 87mm pulley, Catted OVTune dumptubes, Doug Thorley 2.5in y-pipe, custom mufflers, 76mm Tundra throttle body, 5.29 Yukon gears, JamesT custom fuel rails, Yotawerx 87mm tune, Eibach Pro Truck Stage 2 suspension. And some other stuff.
    Stupid question: Did you check the fuses? Not just the fuses listed for the heated seats but ALL the fuses (Many of the fuses in these trucks have dual purposes that aren't always documented)
    Bonus stupid question: Does the passenger heated seat work? If it doesn't the problem might not be the element on the driver side.
    MKC1911 and wilcam47 like this.
  6. Jan 5, 2024 at 8:15 AM
    Koolbreeze7
    Koolbreeze7 GRILL MAN
    Jon
    Jersey
    2017 TRD Sport 4x4 DCLB Black, Trail Limo. RIP- 2009, 2000, 91,89,87 trucks
    Rigid pod fogs, SpartanX stealth grill and hood LED's, 17" SEMA's on 275/70/17 Falken Wildpeak AT3W's, Fox 2.0 on all corners , TRD CAI, LEER 100XQ Blacked out, w/ Thule racks, and Cargo slider Flow master American Thunder "dual" exhaust, remote start, tint, TRD Pro grill and TRD shadow graphics, Alcan custom 8 leaf Spring Pack
    my dash buttons didnt respond when pushed last year, causing me to assume it was broke.... now? knock on wood, they both fire right up.
  7. Jan 5, 2024 at 10:05 AM
    grandpawmoses
    grandpawmoses Dirty Old Man
    David
    2021 Tacoma Limited Nightshade
    No money
    Both drive and passenger seat elements burning out at the same time sounds like too much of a coincidence. Is there power to the switches? Also, check your voltage at various RPM before installing new parts.
    Chew likes this.
  8. Jan 6, 2024 at 2:13 PM
    thisnameisnowmine
    They didn't go out at the same time. One went out months ago. The other recently. I wonder where I can actually buy a pair of replacement seats used?
    joba27n likes this.
  9. Jan 6, 2024 at 3:55 PM
    moon22
    moon22 :-|
    SW Mitten, for the moment..
    '12 TRD OR ACLB 6MT
    FJ AWD Swap & 3G Pro Suspension
    Wasn’t there a thing where some relay box for the seat heaters had a connection that wasn’t great and it would burn up the terminals? This was seen somewhere here and put in my Rolodex of Possible Issues in the Future but not immediately finding it..
  10. Jan 6, 2024 at 4:01 PM
    Koolbreeze7
    Jon
    Jersey
    car-part.com
  11. Jan 6, 2024 at 4:04 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    i remember there was an issue with a box related to the seat heaters melting for early versions of the truck
  12. Jan 6, 2024 at 4:26 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Ya check the connection under the seats. Common for them to burn out right there. You’ll see it very easily. My driver side melted a few years back and I’ve never got around to making a new harness for it, yet complain every winter about it lol.
  13. Apr 17, 2024 at 8:52 PM
    daberg
    daberg Member
    OP. My driver side went out over the winter. Independent mechanic quoted $1200 for parts and labor. What did you end up doing?
  14. Apr 19, 2024 at 4:49 PM
    thisnameisnowmine
    I haven't done anything yet but the best solution I've see so far is car-part.com listed above
  15. Nov 20, 2024 at 5:00 PM
    BM85_2022
    BM85_2022 Active Member
    2016 Tacoma Limited
    This has been an issue since 2016 for the tacomas. A TSB was posted around 2018 but covered only certain models. My 2016 limited had the issue on the driver but wasn’t covered. I’m in Texas so it’s not often I use the heated seats. If you look on this forum there’s plenty of postings and even fixes to buy the part (used to be ~$25 or so) and solder on.
