Seat height
Discussion in '2nd Gen. Tacomas (2005-2015)' started by baral, Feb 21, 2010.
  1. Feb 21, 2010 at 9:31 PM
    baral
    baral [OP] Member
    david
    west hills ca
    2010 tacoma 4wd
    working on them
    Just bot a new 2010 4x4 Tacoma crew cab. Had FJ Cruiser and loved it. Just thought I would add that for no reason. Anyway I am a small old guy and have a problem with the non adjustable seat. I want to raise it. I can fabricate some spacers but I am wondering if anyone has done it or knows a company that makes something. The easiest I can see is to cut the seat from the tracks and put a spacer. A spacer between the track and the car would be more difficult because the front bracket is at a 45 degree angle. Thoughts? I want to sit like I am more in a chair because the lowered seat puts pressure on my back.
  2. Feb 21, 2010 at 9:42 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    haven't done it.. nor do i feel a need to but.. one word of caution the air bags (especially the side) are designed for the current seat height... not sure how raising it will affect the performance should you unfortunately need them.
  3. Feb 21, 2010 at 9:47 PM
    ComeOnToIt
    ComeOnToIt Member
    Northern New Hampshire
    '10 DBL.CB. TRD OR & '07 DBL.CB. SR5 4X4
    Bilstein 5100's- front, Rear spring TSB, Toytec 1.5" AAL, Goodyear Duratracs, Extang Trifecta Signature Series Tonneau
    I agree- I would be cautious in moving the seats too much or cutting anything, especially if you ever want to sell or trade it.
  4. Feb 21, 2010 at 9:54 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    AFE Drop-in filter, Wet Okole seat covers, Hifonics 6.5" components in front, MA Audio midbasses in rear, Kicker 8", RE Audio 2 channel for components, Elemental Designs bridged 2-channel for sub, CB, Devil Horns, Rancho QuickLift, Rancho RS9000XL rear shocks, Toytec AAL, stickers, things and stuff.
    Seems like the seating position would have come up in a test drive or a look over...just saying...
    Also...bought...
  5. Feb 21, 2010 at 9:57 PM
    baral
    baral [OP] Member
    david
    west hills ca
    2010 tacoma 4wd
    working on them
    Yes a buddy told me to be careful about disconnecting the wire under the seat. I did not think about the height affecting the airbag but some people are taller than others so I can't see how raising my seat 1-2 inches would be a problem. Good thought though. I'll have to do it in a way that I could put it back to stock at anytime. Like the truck, hate the ticking but I'll deal with it. Thanks guys.
  6. Feb 21, 2010 at 10:06 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    Yea don't mean to be discouraging just I know they design the airbags specifically around certain dimensions. That said, just changing the seat positions, recline position, ect... would probably affect it about as much as raising the seat a bit. You should be able to space it directly from the floor, but if I remember right there was some additional bracing as it sits factory that might also affect it's performance in a crash. It's just four bolts each seat, shouldn't be bad to space up with some washers and longer grade 8's if nothing else.
  7. Feb 21, 2010 at 10:16 PM
    baral
    baral [OP] Member
    david
    west hills ca
    2010 tacoma 4wd
    working on them
    I did test drive the truck but it wasn't an issue for the five minute drive. I never had a vehicle that the seats were not adjustable. Also had large F-250's or 150's. Always hated low profile cars with low seats. Now I know why. Being 50 and a bad back it has become an issue. I'll have a friend who is a machinist make me some custom spacers. It will be as safe as factory.
  8. Feb 21, 2010 at 10:25 PM
    warpwr
    warpwr Junior Senior Member
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    DRL mod with switch, rear spring TSB, trans TSB, tailgate mod, snug-top shell.
    I'm with you. Old and short that is and sitting kinda low.
    I also have an '07 4Runner with multi-way power seat and it looks like it would bolt right in there.
    I haven't tried yet though and anyway I'm getting used to the Tacoma seat now.
    Maybe a power seat from a wrecked 4Runner would work for you.
  9. Feb 21, 2010 at 10:29 PM
    EquinsuOcha
    EquinsuOcha Bourbon
    Casey
    Ft Worth, TX
    07 PreRunner
    Hm. My dealer let me adjust the seat on my test drive...along with all the other settings...
    All I'm saying is that this is a problem that should have been looked at before purchase.
  10. Feb 22, 2010 at 8:38 AM
    tuckr2
    tuckr2 Well-Known Member
    Western Washington State
    2010 Silver dbl cab LB 4x4 It's Purdy too!
    LT265/70/17 BFG A/T's, Disabled Seat Belt Buzzer, Black and Gray Covercraft Seat Covers front and rear, Matching SnugTop Supersport Canopy, undercoat, bed mat, window vent shades. Black Weathertech Liners. Trans TSB, Rear Spring TSB Installed.
    It's yours to decide. If you can't see well or the position is uncomfortable then make the necessary changes.
    IMO changing the ride height by a couple of inches should not affect any airbag issues. However, that said Toyota might think differently should you have a major accident and attempt to take them to court for some injury that occurred after the modifications. They have plenty of bucks and you likely would not win a judgement.
    Again, with that in mind if you can't see you need to make the changes for your comfort and safety.
    Good luck. Ken:cool:
  11. Feb 22, 2010 at 8:42 AM
    doug355r
    doug355r Well-Known Member
    Phoenix, AZ
    2017 Tacoma TRD Sport
    2.5" Lift with King shocks and TC UC, 4.88 gears, ARB compressor, ARB lockers, S POD, cheap lights
    Any modification that you make to the seat attachment will also affect the way the seat and restraint system acts in the event of a collision. I work with and know the requirements that seat systems and vehicles go through to pass these test. The tests are very rigorous. The seats are designed a specific way for a specific reason. Also if you were to get in a collision and be injured due to your modification, you would be the one liable for your injuries and could no longer blame Toyota.
  12. Feb 22, 2010 at 9:24 AM
    tuckr2
    While this is a true statement many vehicles have adjustable seat heights. My now gone F150 supercrew for example had electric seats with adjustable tilt and height. Also, the restraint system is adjustable. This leads me (IMO) to believe that minor adjustments shouldn't have a major impact.
    Think of it this way. Say you were even smaller and opted to put a pillow under your butt. I believe the manufacturer would have a difficult time holding that against you in a court of law. Vehicles are designed for general sized populations. Apparently you are on the smaller side of that population. If you need the extra height due to your stature make the changes necessary to feel safe and comfortable in your truck.
  13. Feb 22, 2010 at 9:33 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    "Knock on wood," but if you were ever in a wreck, god forbid, I'm wondering if a modified seat would mess with your insurance somehow in case you got injured?:rolleyes:
  14. Feb 22, 2010 at 9:48 AM
    bigburrito
    bigburrito Local Man
    DuPage County
    '09 TRD OR
    Demello sliders, fog lights anytime, 265/75R16 Duratracs, 60" HiLift, VIAIR OBA 2.5 gallon tank, FM Super 44, TSB springs, 5100s at .85, bent tailgate
    an easier, less dangerous solution to this problem: cut out a seat shaped chunk of foam and put it under a seat cover. thermarest material would probably work good.
  15. Feb 22, 2010 at 9:53 AM
    tuckr2
    oops this is similar to the above. Just a bit more permanent
    Hey this does sound like a pretty good idea at least for a start. Also might consider rebuilding the seat bottom. Have the original foam taken out and and add taller, thicker foam. Would likely cost a bit more but then it would be unnoticable and in the event of a major accident any insurance issues likely would never come up.
  16. Feb 22, 2010 at 11:27 AM
    doug355r
    Phoenix, AZ
    I agree that vehicles can come with adjustable heights from the factory. However this must undergo severe testing to withstand the loads put through it in the event of a collision, front, rear, and sides. I have personally designed a height adjuster for a vehicle. I know the loads that go into such test to validate the safety of a vehicle seating and restraint system.
    As for the second part in bold, if you do not feel safe and comfortable in your vehicle, you should not have purchased it in the first place.
  17. Feb 22, 2010 at 11:36 AM
    doug355r
    Phoenix, AZ
    Yes it would mess with insurance. Seating and restraint systems have to be tested to be considered safe to strict "Federal Motor Vehicle Safety Standards and Regulations" from the "US Department of Transportation". My company has to have our products tested to the same standards and beyond. If our customer modifies our products, we can no longer stand behind its performance in an event and warn our customers of this.
  18. Feb 22, 2010 at 11:49 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Go old school and sit on a phone book.:D
  19. Feb 22, 2010 at 11:59 AM
    yotabeast505
    yotabeast505 The Beast
    David
    NE Hights ABQ NM
    THE BEAST
    here we go. Ford 9" rear after breaking 5 sets of gears in the stock yota 8.8, 5.13 gears with a detroit hard locker, 63" chevy leafs and custom hangers, sky's front spring hanger with sky's extream hysteer and PSC hydro assist ram and PSC pump. welded front spyders in the f-550 front dana 60 with warn hubs, pico brake lines and hoses, elecrtic fan, TRD supercharger with URD 2.1 Pully, URD Map-ECU2 and cage built by me. wide band a/f by inovations, lots and lots more...........
    dont think you can raise the seat like u can in a BMW or lexus lol i think thats what he is getting at wanted the truck and bought it but over time decided he would be more comfortable if he was sitting a little higher or maybe he shrunk a little damn lol
  20. Feb 22, 2010 at 12:25 PM
    warpwr
    Vaughn
    S.F. Bay Area
    09 Sport Access Cab
    Up & down? How did you do that?
