Seat Jackers. Get them. Seriously.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ExGunner, Aug 16, 2022.
  1. Aug 17, 2022 at 9:13 PM
    #61
    NAKDELTA
    NAKDELTA Well-Known Member
    Sacramento, CA
    2022 TRD OR DCSB Army Green
    First mod I did when I bought the taco. Best decision for long trips.
  2. Aug 18, 2022 at 2:29 AM
    #62
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Gotta say I was a little skeptical of these and worried that they might do more harm than good so I put off buying them for quite a while. But here we are a couple weeks since install and I'm really pleased with them. Results may vary but so far so good for me!
    ExGunner[OP] and TacoJoe480 like this.
  3. Aug 18, 2022 at 5:45 AM
    #63
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    I'm 5'10 and consider myself chicken legged, and my thighs barely fit under the steering wheel. I don't know how anyone with power seats can fit under the wheel with these installed.
    musicisevil likes this.
  4. Aug 18, 2022 at 8:08 AM
    #64
    LTG4087
    LTG4087 Well-Known Member
    LT
    DFW
    2019 TRD Off Road
    I suppose they tilt the steering wheel up a notch or so.
    Dmesser92 and Doc62 like this.
  5. Aug 18, 2022 at 8:14 AM
    #65
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    my legs go to the side of the steering wheel. still more comfortable than stock. i don't need to cross my legs while driving.
  6. Aug 18, 2022 at 8:18 AM
    #66
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    There’s very little vertical adjustment. Mine is maxed out for height and extension and with my manual seat there’s barely enough clearance.
    The issue is getting in and out. Unless you’re lifting your leg over the seat and around the steering wheel to straddle it, you still have to slide through the narrow gap.
    I’m not a portly fella. I don’t have body builder thighs and only have an inch or two between my leg and the bottom of the steering wheel.
    At 5’11 my head is almost at the ceiling (sunroof) and these aren’t even worth trying for me
  7. Aug 18, 2022 at 8:32 AM
    #67
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    my head is at the same height as before the seat jackers
  8. Aug 18, 2022 at 8:36 AM
    #68
    musicisevil
    Alaska
    2019 TRD Sport
    Z
    I’m glad you enjoy them so much
  9. Aug 18, 2022 at 9:52 AM
    #69
    Hairless_Ape
    South Jersey
    2021 F150
    With the power seat adjusted my leg already contacts the seat and the steering simultaneously when sliding in. With seat jackers I'd need thighs the size of a small child's forearm to get in.
  10. Aug 18, 2022 at 10:43 AM
    #70
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    guess you need seat slammers then
  11. Aug 18, 2022 at 2:22 PM
    #71
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Wow, Amazon came thru five days early. Bezos must be lurking around here? :101010::rasta:
    ExGunner[OP] likes this.
  12. Aug 18, 2022 at 3:33 PM
    #72
    snowshine
    snowshine Well-Known Member
    Awesome mod, would also recommend.
  13. Aug 18, 2022 at 7:44 PM
    #73
    OldSchlPunk
    OldSchlPunk A legend in my own mind!
    Rich
    East Central Wisco
    '17 OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    Even before the jackers, I thought the steering column was too low but I don't have problems getting in or out. Then again I'm only 5'5"+.
    cryptolime likes this.
  14. Aug 18, 2022 at 7:57 PM
    #74
    iJayTee
    iJayTee Member
    Oregon
    2019 Cement TRD OR DCSB
    I cant wait to grab a pair of these. I’m 5’11 but my knees just hurt soooo bad after a long drive. I’m hoping these alleviate that because that is one of the few complaints I have about this truck.
  15. Aug 18, 2022 at 8:01 PM
    #75
    Casey182
    Casey182 Well-Known Member
    Sacramento
    '20 TRD OR - '21 T4R ORP - '66 Chevy C10 SB
    Should be here tomorrow. Im 6 foot and legs already hit the steering wheel, so I guess we'll see.
  16. Aug 19, 2022 at 7:30 AM
    #76
    SkiAZ4Free
    SkiAZ4Free Well-Known Member
    Miguelito
    2022 SR5 4x4
    Glad you asked this, because my wood-working brain was saying "DIY with edge grain oak"...
  17. Aug 19, 2022 at 10:40 AM
    #77
    Mas Olas
    Woody
    Installed in five minutes and no issues with fat thighs rubbing the steering wheel. My issue is the instructions say to grab a 14mm socket for the factory AND new bolts. I did as instructed and went to work. Everything went well until the new bolts were stamped 10.9 (mm or bolt grade?) and they sure as shit aren’t 14mm. Wiped off the locktite and screwed them in finger tight until I get home later.
  18. Aug 19, 2022 at 10:51 AM
    #78
    digitalzombie
    digitalzombie Well-Known Member
    this is a life saver
  19. Aug 19, 2022 at 10:54 AM
    #79
    ExGunner
    ExGunner [OP] Well-Known Member
    Paul
    2017 Tacoma TRD Sport Blue
    The bolts they send need a 15mm socket and the factory bots are 14mm socket. Torque all the bolts down to 27 foot pounds.
  20. Aug 22, 2022 at 6:19 AM
    #80
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    10.9 is the grade of the metric bolt similar to an SAE grade 8.
    shakerhood likes this.
