Seat Jackers?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Steeldog65, Mar 24, 2021.
  1. Mar 24, 2021 at 1:04 PM
    Steeldog65
    Steeldog65 [OP] Member
    JP
    Central Illinois
    Base '11 5spd 2.7L 4X4
    I've looked quite a few posts on the forum about the seat jackers but most of those seem to be based on the bucket seats. I have the basic Tacoma with the straight bench. Does anyone know if the jackers will work on that, or if perhaps I should get some sort of shim made or do you have another suggestion? That seat is just too damn up-and-down and flat for me. Thank you.
  2. Mar 24, 2021 at 1:16 PM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    The ones @EasyDoesIt makes aren't necessarily compatible, but I know he reached out to a customer to see if they'd help determine if they would work. You could send him a message.
    EasyDoesIt likes this.
  3. Mar 24, 2021 at 2:45 PM
    EasyDoesIt
    EasyDoesIt DesertDoesIt.com
    Las Vegas, NV
    2011 Dbl Cab TRD Offroad
    Icon C/O's
    @DKbik3r
    The above user confirmed that they do fit on 2nd gen bench seats.
    Maybe he can provide some additional feedback but otherwise you are good to go.
    I have an updated my product listing yet but he assures me they work. Which is not surprising because Toyota would never change the floor pan or seat mounts.
    DDI
    Yukon DoIt likes this.
  4. Mar 24, 2021 at 3:27 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    How many front feet does the bench seat use? 2 or 4?
  5. Mar 24, 2021 at 3:52 PM
    EasyDoesIt
    Las Vegas, NV
    Icon C/O's
    Pretty sure you can use two at a time (split bench) but will need four if you want to lift the entire bench.
    I'm hoping @DKbik3r chimes in here.
    Yukon DoIt[QUOTED] likes this.
  6. Mar 24, 2021 at 5:34 PM
    DKbik3r
    DKbik3r Well-Known Member
    Daniel
    Springfield MO
    1st Gen Taco/3rd Gen 4Runner
    only 2 there are no mounting points in the middle of the bench just the outer 2 for each side
  7. Mar 24, 2021 at 5:36 PM
    DKbik3r
    Daniel
    Springfield MO
    thats if you have a full bench like i do. if you have a 60/40 split it could be different id check how many mounts there are if you have the 60/40 bench
  8. Mar 24, 2021 at 6:41 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Great information, thanks guys!
  9. Mar 24, 2021 at 7:22 PM
    Steeldog65
    JP
    Central Illinois
    I have the full bench, 4 mount points but I think just two in front are what makes sense, loosen the back to allow the tilt and then tighten up everything.
  10. Mar 24, 2021 at 7:25 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Yeah, if you have two mount points in the front then just get two. I wonder if it's as drastic of an improvement on the bench as it is for the buckets.
  11. Mar 24, 2021 at 7:27 PM
    Steeldog65
    JP
    Central Illinois
    All I know is that seat... damn it is not good imo.
  12. Mar 24, 2021 at 7:31 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Well, if you end up switching to bucket seats, you'll already have some seat jackers if you go OEM :thumbsup:
  13. Mar 24, 2021 at 7:53 PM
    DKbik3r
    Daniel
    Springfield MO
    its an amazing improvment i did a 4 hour trip right after getting them and it was way better then before
  14. Apr 3, 2021 at 3:53 PM
    Steeldog65
    JP
    Central Illinois
    Have to give a testimonial for the Front Seat Jackers from Desert Does It. Easy to install, well made product that made a significant difference in the seating position. Very very happy with the purchase would suggest them to anyone even if they have the bench seat in a base Tacoma with 5 speed like me
    EasyDoesIt and Yukon DoIt like this.
  15. Apr 3, 2021 at 9:15 PM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Glad they worked out for you! Now drive that thing.
