Seat jackers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Shubey, Jan 15, 2022.
  1. Jan 15, 2022 at 8:36 PM
    Shubey
    Shubey [OP] Well-Known Member
    Scott
    Fleetwood PA
    For those that have purchased these was just raising the front what worked for you or did you raised the rear also?
  2. Jan 15, 2022 at 8:50 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    It raised the front so your legs would be resting on the seat. Your legs are closer to the steering wheel. The seat is reclined a bit so you have to tilt the seat forward more. Head room doesn’t change. Your legs rub on the seat bolster when getting out. It’s cool but decided it’s time to sell since I don’t really need them.
  3. Jan 15, 2022 at 8:53 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I dont have them but if I were going to add them it would be to raise the front only.
  4. Jan 15, 2022 at 9:04 PM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    I’ve got them for both front and rear but I’m 5’6.5” so I’ll take the boost. But seriously my legs used to numb out
  5. Jan 15, 2022 at 9:07 PM
    2020SilverSky
    2020SilverSky Well-Known Member
    Seattle. WA
    2020 TRD Off Road 4WD 6MT
    The ones for the front make a huge difference for me. Since I have a MT I have a more limited range of seating positions due to the clutch and can't slide the seat back as far as I could with an AT. Much less leg fatigue now, but it does make it a bit of a squeeze to get out from under the steering wheel when exiting. Not to the point of it being a problem, it's just something to get used to. If only we had a little more adjustment with the tilt/telescopic wheel adjustments.
    RustyGreen and shakerhood like this.
  6. Jan 15, 2022 at 9:08 PM
    Benny blanco
    Ben Day Ho
    21 Cement TRD OR MT
    Some stuff
    I wish the wheel was smaller
  7. Jan 15, 2022 at 9:17 PM
    Shubey
    Scott
    Fleetwood PA
    Mine is a manual too and my knees ache after long trips. I think I’ll try fronts to start with and see how it goes. Thank you for the replies
    CS_AR and shakerhood like this.
  8. Jan 15, 2022 at 11:46 PM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    I did front and rear, but I also put an amp under there, so dual benefit of being more comfortable for me, and giving amp more breathing room
    CS_AR likes this.
  9. Jan 16, 2022 at 3:38 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Raised the front only.
    Due to the lack of thigh support it seemed that all of my weight was being supported by my heels and butt bones, the leg muscles were always engaged.
    I could only drive about an hour without getting achy and constantly shifting around trying to relieve the discomfort.
    With the Desert Does It seat jackers I have comfortably driven up to 700 miles in one day, they were worth every penny.
    5'11" - 30" inseam
    CS_AR, shakerhood and cryptolime like this.
  10. Jan 16, 2022 at 4:37 AM
    Nitro52
    Nitro52 Well-Known Member
    ct
    2022 SR/SX
    At 5'7", I'm interested as well. I'd appreciate it if with your response, you'd give your height.
  11. Jan 16, 2022 at 4:52 AM
    Metalskool
    Metalskool Adversity Builds Character
    Michael
    2020 TRD 4WD
    One of the things I like most about my 2020 Tacoma is the seat position. I like the lower position with my legs outward but I'm 6'-1". (and shrinking lol)
    Mark77 likes this.
  12. Jan 16, 2022 at 4:54 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    I agree, im 6-1, 240, and i dont have any issues with the seat, even for long trips. I think tacoma owners are like cross fit people, make anything for them and they will buy it because they "need" it.
    Metalskool[QUOTED] likes this.
  13. Jan 16, 2022 at 5:30 AM
    PTPinETN
    PTPinETN Well-Known Member
    Alan
    ETN
    21 Automatic OR and 6’ 3” here.
    Prior to the installation of the front only Seat Jackers, like an earlier poster, my weight was on my heels and butt bones, which was very uncomfortable for anything more than 10-15 minutes. I tried multiple seat positions also.
    Installed front only seat jackers and with a tweak to my seat position, I’m back good. I’ve driven several hours of the TAT with no problem at all.
    cryptolime likes this.
  14. Jan 16, 2022 at 5:32 AM
    taco.MARK
    taco.MARK Well-Known Member
    Mark
    Atlanta, GA
    16 T4R SR5 4WD
    I'm 5'6. Couldn't be happier with my ddi seat jackers. I only got em for the driver. My wife doesn't complain about the seat position.
  15. Jan 16, 2022 at 5:38 AM
    stuttgart1
    stuttgart1 Well-Known Member
    2019 TRDOR
    Front only. Much better support for legs and more comfortable for me.
  16. Jan 16, 2022 at 5:39 AM
    Nitro52
    ct
    2022 SR/SX
    You did just the front?
  17. Jan 16, 2022 at 5:41 AM
    taco.MARK
    Mark
    Atlanta, GA
    16 T4R SR5 4WD
    Yep. It raised me up a little. But I need the thigh support. Raising the rear seems like overkill.
  18. Jan 16, 2022 at 5:49 AM
    Doc62
    Doc62 Well-Known Member
    Dave
    SE Pennsylvania
    2025 Tacoma TRD Off Road i-FORCE Max, 2019 Sahara
    Went with both front and rear. A lot more comfortable. Just wish the steering wheel could raise higher.
  19. Jan 16, 2022 at 6:12 AM
    Ainapo
    Ainapo Well-Known Member
    SW WI
    MT+LB=sport
    I raised the rear 3/4" (before I heard about the front option). I'm 5' 10". With a manual, it seems to make it easier to push pedals. I found the seating position more comfortable also. My brother sat in the factory passenger seat and said "I'd rather raise the front to support my legs." He comes from a tundra.
  20. Jan 16, 2022 at 7:23 AM
    outdoor frenzy
    outdoor frenzy Well-Known Member
    Aaron
    Roanoke, VA
    2021 TRDOR DCLB Super White
    Goodyear DuraTracs
    Laughs in 10 way adjustable electric heated seat
    AmateurTaco1313 and henryp like this.
