seat/parts interchange question
Discussion in '1st Gen. Tacomas (1995-2004)' started by brettmc, Jun 28, 2009.
  1. Jun 28, 2009 at 8:38 AM
    brettmc
    brettmc [OP] Well-Known Member
    St Louis, Mo area
    2004 2wd tacoma
    i found some bucket seats from a 97 4runner sr5. Will they fit my 04 taco?
    is there a website or book that lists parts interchangeability between 4runners/tacomas or tacomas and other styles?
    Thanks!
    Brett
  2. Jun 28, 2009 at 9:28 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Hard to say. Worst case would be to swap the mounts from your truck to the new seats. Some minor welding may be needed if they dont bolt right up.
  3. Jun 28, 2009 at 9:38 AM
    brettmc
    St Louis, Mo area
    2004 2wd tacoma
    What WILL bolt right up? 1st gen tacoma seats? aren't 4runner and tacoma seats the same?
  4. Jun 28, 2009 at 9:41 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think they are the same, but have a different track.
  5. Jun 28, 2009 at 10:39 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    No - 4Runner and Tacoma seats are different.
    1996 - 2002 4Runner buckets will line up 3 out of 4 bolt holes if transplanted into a 1995.5 - 2004 Tacoma.
    The only seats that bolt into a 1995.5 - 2004 Tacoma 'as is' are Tacoma seats from the same period.
  6. Jun 28, 2009 at 2:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats what I thought, and why I suggested the seat traks not fitting....Do you kknow if the tracks/ mounts from the Tacoma can be bolted onto the 4runner seats?
  7. Jun 28, 2009 at 5:29 PM
    brettmc
    St Louis, Mo area
    2004 2wd tacoma
    ok thanks!
  8. Jun 29, 2009 at 4:41 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    Pre-2005 Tacoma seats don't have 'modular' bases. The mounts are integral parts of the seat frame assembly. So there's nothing that can be unbolted from the OEM seats and transplanted.
    If you're willing to sacrifice the OEM seats you can cut off the OEM mounting frame / brackets and weld them onto either (a) the new seats or (b) separate custom frame pieces.
    The '96 - '02 4Runner seats have similar 'legs' / 'tabs' to the OEM Taco seats. These can be bent / modified to make the 4Runner seats mount up in the Tacoma.
  9. Jun 29, 2009 at 5:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok....Thats what I thought.
  10. Jun 29, 2009 at 3:52 PM
    brettmc
    St Louis, Mo area
    2004 2wd tacoma
    i think i'll just keep the bench. if i put buckets in there'd be a need for a console. then i'd have to get some of those $300 wet okele seat covers, then....well you get the point. thanks for the info guys.
    Brett
