seat question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FTB530, Jun 10, 2012.
  1. Jun 10, 2012 at 11:58 AM
    FTB530
    FTB530 [OP] Well-Known Member
    Yuba City Ca.
    2005 toyota tacoma
    level kit,air raid intake,
    This might be a stupid question but i am going to ask any way , I want to remove my front seats to shampoo the carpets,i see electrical wires under the seat,if i unplug them will it set off air bags or do any thing to the computer that will mess it up and have to take it to a dealer to get fixed?
  2. Jun 10, 2012 at 12:01 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I believe it won't hurt anything unless you turn the key to the on position with the airbag stuff unplugged. You might set a code that way. Not sure if you could clear the code by disconnecting the battery or if that would require a trip to the dealer.
  3. Jun 10, 2012 at 12:22 PM
    mcdowell
    mcdowell My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    ^^^ this
  4. Jun 10, 2012 at 1:05 PM
    Tuctaco
    Tuctaco Well-Known Member
    Todd
    Tucson, AZ
    2012 MGM TRD OR 4x4
    Katzkins, Redline hood struts, Pop & Lock,285/75/16 Toyo Open County ATll, 16X8 Konig Countersteer, Icon extended coilovers, Icon rear shocks, Icon progressive leaf pack, LR UCA's, extended brake lines,
    Disconnect your battery first if you have airbags in you seats.
  5. Jun 10, 2012 at 1:24 PM
    joes06tacoma
    Joe
    Central Coast, CA
    YES! I should have said that first.:rolleyes:
  6. Jun 10, 2012 at 6:37 PM
    FTB530
    Yuba City Ca.
    2005 toyota tacoma
    Thanks for the replies!!!
