Seat too high..
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Maggman, May 28, 2022.
  1. May 28, 2022 at 9:24 AM
    Maggman
    Maggman [OP] Member
    2018 tacoma trd
    Hi folks I just purchased a used 2018 Tacoma and the driver seat is really too thick and I sit too high with no way to lower it. Is there anyway to remove some of the foam, or make the seat lower , thanks
  2. May 28, 2022 at 9:50 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Welcome to the forum. There’s been a few people on here who have taken their seat to an auto upholstery shop and had the seat cushion thinned out. I have a 17 and would like to get a powered seat from a 20+ to modify mine.
  3. May 28, 2022 at 10:29 AM
    5465 Well-Known Member
    South
    2023 TRD Ex Cab
    Check to make sure the previous owner did not install riser pucks at the floor mounting points. Some peeps put them on the back mounts only.
  4. May 28, 2022 at 10:51 AM
    Maggman
    Maggman [OP] Member
    2018 tacoma trd
    Great thank you
  5. May 28, 2022 at 10:58 AM
    BIGW0RM
    BIGW0RM Well-Known Member
    I hate how high the OEM seats are. At the lowest position, my eyes are well above the middle of the window. I have to tuck my head to get into my door and into my seat. They made this truck for people less than 5ft tall!
    MAVEN4 likes this.
  6. May 28, 2022 at 11:02 AM
    Maggman
    Maggman [OP] Member
    2018 tacoma trd
    Agreed, love the truck I’m 6’ and fit just ok if the seat was 2 inches lower Iwould be very happy,and yeshead duck too
    D. Lengua likes this.
  7. May 28, 2022 at 11:11 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    On one of my old trucks I put the stock seats to the curb and installed Honda CRX seats. It was the most comfortable vehicle I’ve owned
    Shveet and TLamp28 like this.
  8. May 28, 2022 at 11:22 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Eat an extra burger at lunch and take a nap in the driver's seat that should be good for a couple inches in reduced seat foam.
    71tattooguy likes this.
  9. May 28, 2022 at 11:57 AM
    Maggman
    Maggman [OP] Member
    2018 tacoma trd
    Sorry, way past the burger and nap
  10. May 28, 2022 at 12:07 PM
    su.b.rat
    su.b.rat broken truck
  11. May 28, 2022 at 12:17 PM
    donp
    donp Well-Known Member
    just gotta lean back a little
  12. May 28, 2022 at 12:22 PM
    AxisCab
    AxisCab Well-Known Member
    Dave
    Bumville, or some dam place
    2018 2.7L 2WD Auto6, utility Axis Cab
    firewood scratches, Labrador hair/slobber, American flag sticker, Total Chaos bed stiffener, Scepter H20 can, onboard air
  13. May 28, 2022 at 12:26 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    ^This. It usually takes me a few weeks to find the ideal setting in a new truck. Recline seat one click, then scootch forward one click. Take a drive and ask if it's better or worse. Visibility, comfort, and appropriate distance from the air bags.
    Don't be afraid to change things up after you think you have it dialed in. There might be a position that's better.
  14. May 28, 2022 at 12:39 PM
    batacoma
    batacoma Truck Wars
    Toyotas don't seem to be designed for head room. Mine seems ok to me, buy there isn't a lot of extra room up there. I don't know the specs in the new Tundra, but the cab doesn't look all that tall in relation to the rest of the truck. Which gives it a low sleek look, and is probably more aerodynamic, but not offering much for headroom.
    When I drove a shared work truck, those seats were always much lower than the previous time I was in it. I guess I contributed to the ware and tare as well, but I always thought how can a person be so hard on a seat?
    Toyko Joe likes this.
  15. May 28, 2022 at 12:45 PM
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    This seems likely.
    Prior to the electric seats, most people thought the factory position was way too low.
    Jesse46 likes this.
  16. May 29, 2022 at 4:14 AM
    D. Lengua
    D. Lengua Well-Known Member
    '21 Limited LB
    the electric seats actually allow the seat to be moved a bit lower than the earlier seats.
    in my case, it's still too high even with the 2021 electric seat, my head just barely touches the ceiling. it's not the worst thing in the world, but i am a little concerned about what might happen in a head-on collision.
    TDImark likes this.
  17. May 29, 2022 at 4:58 AM
    TheSt|G
    TheSt|G Well-Known Member
    ‘05 M3, '19 TRD OR, ‘21 Type R
    CSL Bits
    This is why you get one without a sunroof as a tall person. Gives you a solid 3”+ more headroom.
    xxTacocaTxx and AxisCab like this.
  18. May 29, 2022 at 5:08 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    Yes, exactly.
    I’m about 6’ and on my 2010 I installed risers in the rear as I felt like I was sitting in a clam shell with the stock seats.
    On my new Tacoma (with electric seats) I installed risers on the front as I found the thigh support to be lacking for those of us with long legs.
    With the front risers, the seat is more comfortable, but now it is too high. My legs now touch the steering wheel even with the steering wheel adjusted as high as possible.
    I just think Toyota is struggling to find a cabin seating design that keeps the floor height up for ground clearance, the roof height low for garage clearance, and a seating position reasonable for full size North American people. To “fix” one, you sacrifice another.
    xxTacocaTxx likes this.
  19. May 29, 2022 at 6:13 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Certainly no disrespect intended, but wouldn't this be something you would have noted when you test drove the truck before purchasing? No matter how good of a vehicle if it's uncomfortable to drive I would have to think twice about making the purchase.
    That said, if there are no seat jackers installed I would take it to a good auto upholstery shop, tell them the problem, and see what they can do.
    TDImark, Maggman[OP] and Toyko Joe like this.
  20. May 29, 2022 at 7:03 AM
    Nirango kid
    Nirango kid Well-Known Member
    Gilles
    Ontario
    2021 Tacoma TRD Sport Premium in Barcelona Red
    I am 5'7 and have no problems at all with the seat's height. Me it is getting in and out of the truck.
