Seat upgrade ideas for a first gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2004TacomaSR5, May 2, 2015.
  1. Aug 17, 2021 at 8:21 PM
    #61
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Haha, I want like lazy boy comfort at this point :D I’m not ruling out Recaros, let’s just say that.
    The biggest frustration is I’m used to getting stuff to work, but there’s a limitation obviously when you’re dealing with the aftermarket
  2. Aug 17, 2021 at 8:51 PM
    #62
    Bubba’sTaco
    Bubba’sTaco Virtually-Known Member
    Spencer
    Ogden Utah
    Toyota XJ
    If you haven’t got it dialed in with your skill set then I know I’m gonna have to get creative. That’s why I’m so grateful for your willingness to share cuz I would’ve had to pay someone mucho dinero to run into the same dead end. I’m gonna play around with it this weekend so if I somehow get lucky then I’ll be sure to post here.
  3. Aug 18, 2021 at 7:38 AM
    #63
    DMZ
    DMZ Having no destination, I am never lost.
    David
    North Carolina
    '04 Xtra Cab 4x4, 2020 AC MT 4x4
    I put Recaros in my 1st Gen and it cost a heck a lot more than $1,000. However, they are THE most comfortable seats ever and one of the reasons I'm reluctant to part with my 1st Gen. IMG_0095.jpg IMG_0096.jpg
  4. Aug 18, 2021 at 8:34 AM
    #64
    Laxtoy
    Maltby, WA
    Are those the Experts? That’s kind of where I’m looking, and yeah, they’re $1045 a piece from what I’ve been seeing
  5. Aug 18, 2021 at 8:44 AM
    #65
    DMZ
    David
    North Carolina
    Yes, they are the Experts and they cost me $1,089 each back in 2016. Recaro Slider Kit was $135 each and the seat brackets that were fab'ed by the installation guys cost $145 each. Labor was 8 hours. Expensive, but OH so worth it! :thumbsup:
    Laxtoy[QUOTED] likes this.
  6. Aug 18, 2021 at 8:47 AM
    #66
    Laxtoy
    Maltby, WA
    I’m leaning that way for sure, seems with it to me. I have sliders and can do install myself so it would just be the cost of the seats
    DMZ likes this.
  7. Aug 18, 2021 at 9:51 AM
    #67
    Laxtoy
    Maltby, WA
    A few more questions since you’ve been kind enough to share this info-
    1. The seats are ambidextrous, meaning same seat for driver and passenger, correct!
    2. How are the seat belt buckles mounted? Are they to the track so they stay in a fixed position as the seats go forward and back or are they mounted to the seat? The latter would be preferable to me so I don’t have the issues I’m dealing with now
    3. Fitment wise the seats obviously fit in the space, any clearance issues? I’m 5-10 190#, it looks like you have the M (can’t tell for sure) which has the adjustable thigh support, how does the seat fit for your body type? Would you recommend the M or does the S work which is about $100 less per seat?
    Abeyancer likes this.
  8. Aug 18, 2021 at 11:06 AM
    #68
    DMZ
    David
    North Carolina
    Here are your answers:
    1. The seats are ambidextrous with controls on both side of the seats. I'll try and take a few more photos when I get home tonight.
    2. The seat buckles are mounted to the track, so choose your position carefully.
    3. I'm 5'9", a lean 140 lbs, and chose the M style seat which does have the adjustable thigh support, though I haven't used it. However, I have adjusted the side bolsters for a tighter fit and the seat fits me like a glove. For that kind of money, I'd spend the extra $100 to be able to adjust the seat in as many ways as possible, especially for long-distance driving. You never know how your body will change as you age and I'd rather have the seat flexibility and not need it, rather than need it and not have it.
    BTW, the electrically-adjustable driver's seat in the latest 3rd Gen is very comfortable and firm. That, the MT and other electronic doohickies are what convinced me to purchase it last year.
  9. Aug 18, 2021 at 2:23 PM
    #69
    Laxtoy
    Maltby, WA
    Thank you for your input.
    I have an major issue with my current seat belt buckle mounting to the Corbeau seat base. I am thinking if there’s a way to fab up a bracket that would go between the seat base and active portion of the slider track so it travels with the seat like every oem seat belt buckle I know of, I want to make that happen. It sucks the way it’s set up now burying the seat belt buckle when you move the seat forward and back.
    Do you know what the mounting system is for the Recaro seat to the slider? It has to bolt on somehow. If it’s robust enough fabbing a bracket would work, the only issue then being the slider strength on the ones I have which have an ECE R17 approved rating. The ones I have I want to keep for the 9” of travel not to mention the Recaro sliders would then be another $280ish.
    Not sure if that means much to have that rating because most oem seat sliders are multiple times the amount required in that standard, and with Recaro’s reputation as an oem provider for Volkswagen, Porsche, Ford and several others, I bet their sliders are really well made like their seats.
    That’s another issue with my current seats- as I mentioned they felt cheap. Their 4 mounting points are literally little 5/16” nuts welded to the seat subframe, which is also pretty wimpy, like 3/8” round rod.
    FE14E8F1-66A2-4B0D-8476-DF18EF07AF5A.jpg I’m not trying to bag on these seats too heavily, but there’s an obvious difference in how stout they are even compared to the factory Tacoma seats let alone the Subarus.
    At 44 I’m at a point I need good seats in whatever I drive. I have a 2018 Silverado and drove a 2020 Ford Transit Connect, both have awesome seats. I don’t know if I’ll ever buy a new Toyota, and that’s after having owned 7 from 16 years old to current. I just don’t care for the offerings, so I’ll be sticking with my first gen- just needs to be comfortable as well as capable.
    My days of being able to drive 8 hours in a lifted Tacoma with stiff suspension and uncomfortable oem seats are long gone. I’ll update when I drop in Recaros in like half a year
  10. Aug 18, 2021 at 4:50 PM
    #70
    DMZ
    David
    North Carolina
    Below are several photos of the brackets and the buckles. Sorry for the poor quality. The buckles are mounted adjacent the bottom of the mounting bracket with a pivot point near the hinge of the seat.
    I had a 2001 Subaru Forester that had outstanding seats; put 533,000 miles on that car before selling it in 2017. I purchased my 2004 Tacoma in 2007 (at that time, 10K on the odometer), but never put a lot of mileage on it because the factory seats were so uncomfortable. That changed when I put the Recaros in (it's currently at 91K), but then I purchased a 2015 MB GLK 350 back in 2018, and that's been my daily driver these past three years. When you spend so much time in a vehicle, you HAVE to be comfortable.
    Laxtoy likes this.
  11. Aug 18, 2021 at 5:05 PM
    #71
    Laxtoy
    Maltby, WA
    Agreed
  12. Aug 18, 2021 at 5:34 PM
    #72
    Cheap Taco
    Cheap Taco Well-Known Member
    2001 Tacoma Limited Double Cab
    I have the leather limited power seats with lumbar and they seem ok. Not as good as my old Acura tl seats, but decent for a early 2000s vehicle
  13. Aug 18, 2021 at 5:37 PM
    #73
    TheloniusDrunk
    TheloniusDrunk Well-Known Member
    99 3.4L M/T 4WD 220k
    out of curiosity did you gain or lose any headroom with the Recaros? I'm looking at changing my seats in the distant future, with the main motivation being gaining headroom since I'm too tall for the cab as is
  14. Aug 18, 2021 at 7:57 PM
    #74
    Laxtoy
    Maltby, WA
    Looking at DMZ’s picks in his latest post the Recaros have adjustable mounting height. The other thing I noticed from the dimensions is they have a really low seat cushion depth, which could really help out with getting them lowered. I had this issue with the Subaru seats I had. The Procar I have now are much better. Gotta do a little metric conversion 4F13EB59-56B9-4532-84C4-B6F929BF8FAB.jpg Expert (what DMZ has)5227FEA6-49D7-4048-9A3D-2382779EE53B.jpgSpecialist
  15. Aug 20, 2021 at 6:20 AM
    #75
    Andiamo
    Andiamo Well-Known Member
    The lower back pain is a thing, I was using lumbar support from TJ Maxx for a bit, but it pushes you up against the steering wheel
  16. Aug 20, 2021 at 6:44 AM
    #76
    Madjik_Man
    Colorado Front Range
    Thank you for the honest review.
    As they say… buy once, cry once.
  17. Aug 20, 2021 at 6:47 AM
    #77
    Madjik_Man
    Inhave to go measure the current stock seat depth. But that dimension (18.5” on the Recaro) is what makes my legs/ass go numb on long drives. There’s no support from the stock seats.
    For these Recaros I wonder what the softness/stiffness is of the cushion material?
  18. Aug 20, 2021 at 7:56 AM
    #78
    Badknees
    Badknees Well-Known Member
    Kenny
    Anderson, SC
    1998 Tacoma Extended Cab SR-5 4X4
    King Front Coil-overs, Bilstein Rear Shocks, Add-a-leaf Rear Leaf Springs, 16" Toyota Wheels, KO2 Tires, Alpine 2-Din Head Unit, Alpine Amp, JBL GTO Speakers, Undercover Hard Bed Cover, Back-up Camera
    Hello. I see you're in N.C. I'm interested in doing the same Recaro gray front seats and replacing my 60/40 OEM Taco seats on my '98. Not sure how well the gray will match my bluish/grey (moon mist) interior, but assume it would look better than black. Do you mind telling where you bought your seats and who installed them? I'm in Anderson, S.C. but have relatives in the Charlotte, N.C. area. Thanks.
  19. Aug 20, 2021 at 7:58 AM
    #79
    DMZ
    David
    North Carolina
    For these Recaros I wonder what the softness/stiffness is of the cushion material?[/QUOTE]
    The cushion material is firm/stiff; that's the way I like my seats. The factory seats were WAY too soft and long trips in excess of 4 hours were very uncomfortable.
  20. Aug 20, 2021 at 8:00 AM
    #80
    DMZ
    David
    North Carolina
    This is where I purchased the seats and they did the installation as well:
    Kevin Kahle /// Customer Support Specialist
    GMP Performance
    710 Pressley Road
    Charlotte, North Carolina 28217
    Ph: 704-525-0941 x 255
    Em: Kevin@GMPperformance.com
    Web: www.GMPperformance.com
    Badknees[QUOTED] likes this.
