Seat Wiring Help Please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The67beast, Apr 27, 2019.
  1. Apr 27, 2019 at 11:10 AM
    The67beast
    The67beast [OP] Active Member
    2009 Tacoma Reg Cab 4x4
    8D5F9636-92F0-4291-A821-B10C642FD6F3.jpg Well, I know this is a long shot and I have already looked at all of the bench seat to bucket seats conversions posts and still need assistance. I have an 2009 bench seat (airbags) that I have taken out and have put 2010 buckets seats in (also airbags). You would think that it would be plug and play; and it was for the driver side. The passenger side is a different story! The airbag plugs are the same but the other plugs are different. I have most everything figured out except for 3 wires on the truck side. Anybody have a schematic or a pin out for the following plug under the passenger seat? Need to know what the purple wire is, what the lite green wire is and what the dark green wire is.
  2. Apr 27, 2019 at 10:32 PM
    caribe makaira
    Caribbean, Puerto Rico
    Are you showing the replacement harness (separate seats) or the bench harness? I can't find that 10 pin connector in reference to the seats...
  3. Apr 27, 2019 at 10:37 PM
    tcjacado
    tcjacado Well-Known Member
  4. Apr 28, 2019 at 4:11 AM
    The67beast
    The 10-pin connector pictured above is the connector under the bench seat. Here is a photo of the 6-pin connector attached to the bench seat. If I can figure out the wires I can just splice them together and should function. Of course it is always a challenge when trying to match up 10 wires to 6 wires. 481F2543-A6C9-41AD-AA01-F493196DB798.jpg
  5. Apr 28, 2019 at 10:13 AM
    caribe makaira
    Bench seat info:
    Steves104x4 and TireFire like this.
  6. Apr 28, 2019 at 10:32 AM
    The67beast
    Perfect! Thank you!!!!
  7. Apr 28, 2019 at 10:38 AM
    caribe makaira
    There's more to it..the SRS system is simplified for the Bench but for the bucket seats they add a occupant classification ECU...
    Jimmyh and TireFire like this.
  8. Apr 28, 2019 at 10:41 AM
    The67beast
    I think I just about have it figured out thru some trial and error and some good, old fashioned troubleshooting.
  9. Apr 28, 2019 at 10:43 AM
    caribe makaira
    • srs.pdf
      File size:
      80.6 KB
      28
  10. Dec 15, 2021 at 4:50 PM
    802Toyota
    802Toyota New Member
    Eric
    Single cab 4x4 5 speed
    Hey there I realize this is an older thread but I am doing the same installation in my 08 and was wondering if anyone had figured out those exact 3 wires from the original bench seat? The purple, dark green and light green wires. I was curious as to what anyone may have tied these into.
  11. Dec 15, 2021 at 8:19 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Seat belt tensioner
  12. Dec 16, 2021 at 2:43 PM
    802Toyota
    Eric
    Thank you very much!! This has been an on going project and that airbag light is a real let down when inspection time comes around.
  13. Aug 18, 2023 at 2:43 PM
    Tnlee
    Tnlee New Member
    2009 Regular cab Tacoma
    I have 2009 Tacoma regular cab with bench seats. I purchase bucket seats from a 2013 Tacoma. I installed the driver seat with no problems. The harness plugged right in.
    I am in the same situation with the passenger side harness connections. The 2013 seat has 6 pin connector and the 2009 has 10. I have identified the 6 wires, but I have a lt green, dark green, violet wire that I do not know where they go. I noticed the post above but, it was not mentioned what was done with the 3 wires?
    The same problem The 67 Beast had.
    E3g likes this.
  14. Oct 5, 2023 at 8:45 AM
    farmerfromkansas
    farmerfromkansas Active Member
    2014 regular cab base truck
    Thought I found another thread that said you have to take the bench seat cover off and change the seat sensor into the passenger seat. Have not found that thread this morning.
  15. Dec 17, 2023 at 8:02 PM
    Tacoma932
    Tacoma932 Member
    Sean
    2013 Regular Cab Tacoma
    hello
    i am looking to do the swap i have a 2013 and got seats from a 2014, i have the same problem with the passenger seat having a 10 pin vs 6 pin connector. can you tell me what you did in the end?
  16. Dec 25, 2023 at 1:40 PM
    farmerfromkansas
    On the passenger side, I took the wiring harness out of the old bench seat, wrapped cable ties around it, plugged it in and laid the bundle under the passenger seat.
