Seatbelt bolts stripping?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moline, Jul 25, 2011.
  1. Jul 25, 2011 at 10:18 PM
    moline
    moline [OP] Member
    torrance, ca
    11 dcab Pre/10 AC Pre
    Just traded in my 06 trd or for an 11 Dcab 2.7l.
    Put on clazzio seat covers (very nice).
    Had to remove the back seatbelt FTP install rear seat cover.
    When I took it off (14mm), was difficult. When I reinstalled the bolt,
    It was difficult and sure enough, was stripped at the top of the bolt.
    I think was improperly installed?
    But the bolt looks like stainless steel? Not even grade 5 (or grade 8?)
    Wtf!!!
    Should I tale it to the dealer? Or try to regal it myself?
    Looking for a 12x1.50mm bolt now! Toyota charging $4 for a replacement!
    Tia
    Later
    Dan
    P.s. I also had a 05 Dcab 4x4 before the 06.
    Toyota using cheaper bolts?
  2. Jul 25, 2011 at 10:37 PM
    qwertypepper
    qwertypepper Well-Known Member
    cam
    canada
    2011 TRD sport dclb
    FWIW when using stainless steel hardware ALWAYS use never seize, or it will always gall up and strip.
  3. Jul 25, 2011 at 10:38 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Your complaining about a $4 bolt? A bolt that you need to save your life in an accident?
  4. Jul 25, 2011 at 10:38 PM
    BUZZCUT
    BUZZCUT Well-Known Member
    Georgia
    2007 AC TRD OFFROAD
    What was the number on the head of the bolt?
    It it is stripped @ the head side was either overtightened at the factory or when you removed it. It happens.
  5. Jul 26, 2011 at 7:30 AM
    moline
    moline [OP] Member
    torrance, ca
    Thanks for the comments. The bolt is now stripped. But it looks like the nut
    That is welded to the body frame is stripped also and was the problem.
    I'm not complaining about the $4 bolt. I'm complaining about it NOT
    Being a grade 5/8 bolt! As you said, it might save your life!
    Not sure if it's SS. Auto zone guy said it was a 'softie'.
    Wanted to know if others on the forum ever had this happened?
    Tia
    Later
    Dan
  6. Jul 26, 2011 at 10:03 AM
    jdkeller
    Jonathan
    Inland Empire, Ca
    I haven't heard any incidents of the bolts shearing in an accident. I'm sure they hold up just fine. I bet if you go check all the bolts in your truck you would find similar situations.
