Seatbelt Chime/Airbag question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SPQR, Nov 8, 2009.
  1. Nov 8, 2009 at 9:28 PM
    SPQR
    SPQR [OP] Member
    Calgary
    09 SR5 TRD Offroad 6 speed
    Mud. Lots of it.
    On my '09 Tacoma, I took apart the seatbelt clicker and removed the thingy that activates the chime. Now I notice that my airbag indicator on the dash stays at 'off' even if there's someone in shotgun (and it's set at auto). For that matter, I wonder if my own (drivers) airbag will even work, since I did it to my seatbelt as well.
    I disconnected these things because I just use my truck for construction site supervision. To put on my seatbelt to drive halfway down the block is annoying. But even that I could handle... What's really annoying is that if I pick up a case of beer on the way home, putting it on my passenger seat activates the seatbelt chime. Ditto for my dog. So I disconnected it. But I still want any human passenger to be protected by the airbag. Is it possible, or do I have to reconnect that fucking sensor that activates the chime?
  2. Nov 9, 2009 at 7:23 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Search some more. Disabling the seatbelt chime can be done via a keyfob/odo/hold-your-lips-right thing.
  3. Nov 9, 2009 at 7:37 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your gonna have to reconnect the sensor.
  4. Nov 9, 2009 at 6:08 PM
    SPQR
    SPQR [OP] Member
    Calgary
    Mud. Lots of it.
    That sucks. I can handle putting my seatbelt on, but if I want my passengers protected, I have to connect the seatbelt anytime I have something over 15lbs on my seat? Weak.
  5. Nov 9, 2009 at 6:16 PM
    Dane-Taco
    Dane-Taco Well-Known Member
    Justus
    Wasilla, AK
    '10 Doublecab 4x4 TRD Off-Road
    Bilstein 5100s set at 0, OME 886 coils, Camburg Ball-Joint UCAs, 295/70/17 Nitto Trail Grapplers on 17x9 Moto Metal 957s, 2" Tuff Country AALs, SX8000 Gas Shocks (Rear), Homemade Satoshi Grill, Redline Hood Struts, Locker Anytime Mod, Map Light Mod, Diff Breather Mod, Fog Lights Anytime Mod, Extra Bed D-Rings, Sock's Badges and Decals, PIAA 520's, Illuminated 4x4 Switch Mod
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    I copied this from another post. I have completed this mod and it works perfectly. Now all you will have to worry about is the flashing light.
  6. Nov 9, 2009 at 6:19 PM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    no dude. You dont have to. There is a code to turn the seat belt beeps off.
    It will beep 5 times intially when you turn on the ignition, but never after that. This is how you do it.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt. :)
  7. Nov 9, 2009 at 6:21 PM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    You beat me to it. Works great, The flashing light is nothing to worry about
  8. Nov 9, 2009 at 6:26 PM
    Dane-Taco
    Justus
    Wasilla, AK
    Absolutely, beats wondering if your airbags will deploy!!
  9. Nov 11, 2009 at 10:46 AM
    SPQR
    SPQR [OP] Member
    Calgary
    Mud. Lots of it.
    You guys fucking rule. Thanks alot.
  10. Nov 11, 2009 at 10:54 AM
    Outlaw
    Iowa City, Iowa
    2006 GX470
    :)No problem man!
  11. Nov 15, 2009 at 3:42 PM
    SPQR
    SPQR [OP] Member
    Calgary
    Mud. Lots of it.
    Just finished putting the springs back in the seatbelt sensors and entered the code... Works great! Thanks again, guys!
  12. Nov 29, 2009 at 1:09 PM
    SPQR
    SPQR [OP] Member
    Calgary
    Mud. Lots of it.
    Is there a code to get the truck to stop chiming when the door is open and the keys are in the ignition?
